ricleh
Sacramento, CA
ricleh,
I am a newbie when it comes to removing gaskets with scrapers. I want to be prepared when the time comes with the necessary scrapers and information.
Would you care to elaborate on the situations when you would use steel, ceramic, and plastic scrapers?
Are ceramic scrapers safer to use on aluminum than steel ones?
Thanks,
Dave
No, you can gouge aluminum just as easily with steel or ceramic. Aircraft maintenance workers use hard plastic scrapers like I mentioned - the Snapon mastic removal kit. Go to this link and read the description.
NYROC
marcusicp
NC
I did a search for mac scrapers and didn't see it. I'm not sure if it was a Mac that I used, but it had a square piece of carbide about a 1/4" thick at the end of a long handle. Best scraper I've ever used.
Dose anyone know where I can find a scraper like that? I have been looking online for about 2 hours trying to find one and have had no luck.
trexdoink
Iowa
Search for Super Scraper. It's made by Johnson MFG in Princeton IA.
rowbow41
Kansas
Kyocera Advanced Ceramics Ceraplaner Utility Ceramic Scraper CP-12-BK
It is listed on Amazon. Copy the Item, paste in google and search.
dede2897234
Northern, Ohio
Yesterday, I received from Amazon the Kyocera CP-12-BK ceramic scraper. I was surprised to see "Made in Japan" on the back of the packaging considering its low price.
Dave
Gunpilot
SE USA
Interesting thread. Just this past weekend I was displaced from my 34+ year old KD tool scraper. Thought about this forum after improvising with a piece of scrap metal from an old mulching mower blade. I think I'll actuaully make some now in varying widths based on the model and handle from Ryan's original post. Just saying.
29bowtie
maple ridge bc can
I still miss my old "Mr Gasket Co." steel scraper that disappeared from my roller cabinet.:( Always held an edge, perfect stiffness and didn't rust.
Shadowdog500
Down the shore
If it's always sharp why would you need a replacable blade?
I think he means it's always razor sharp, because you can put a new razor blade in it. I have to sharpen my old favorite gasket scrapers.
For aluminum I use a razor blade and brake clean. I tried a plastic hotel room card because a friend loves them for that, but if you are patient a razor seems better to me. I hear a new parting tool for a lathe works pretty darned good but I never tried one for that.
It seems like o-rings are the standard today, and creeping corrosion is what you need to remove. A sanding block with fine wet/dry sandpaper covered in oil seems to work well for that.
I really loved using skotch brite rite pads, but that is now considered a no-no.
Chris
bochnak
Mt. Prospect, IL
So most of the stuff that I work on is old and old stuff has the tendency to be stubborn. By stubborn, I mean that often it just doesn't want to come apart. A great examp...
I just bought one of these super scrapers. I'm working on a 76' Honda CB550 top end and a regular razor or cheap $5 scraper won't touch the head gaskets!
Will this super scraper plow through this?
toplessHO
central florida
Try using one of the multi tools
I love my Dremel for cutting urethane gaskets off my car parts
took an impossible job and turned it into 2 min one
dont buy the cheap HF one
get one with a variable speed
