The Bimmer Basement
Skellyii
KC Area
Nice!
But, you're making me feel guilty. There's a couple of things I need to get done on my 944, but I've got several other vehicles with pressing needs I need to finish first. :(
fouckhest
Greer, SC
Couple of small updates.... I looked at the price of a battery for this thing, and decided to go with an Odyssey pc680 since I get them cheap at work.
I am guessing you know this, but just have to post it for common knowledge, those batteries are great, but getting a trickle charge meant for AGM's that has a de-sulfating feature is key to keeping them happy in my experience.
Car is coming together nicely, looking forward to seeing your first C&C or trip to get an Xmas tree with it! :cool:
Mpower5266
Newnan, GA
Yep, I have a few of them kicking around the shop.
Mpower5266
Newnan, GA
I finally did a garage thing. I kinda got fed up with having to roll my dehumidifier/ac unit of of the garage every couple of days to drain it. I also never really like where I had to place it due to electric and window locations, its been venting out of a window on the front of the house.
54942824364_0a2627b143_h.jpgUntitled by Nick Wood, on Flickr
Quick trip to Lowes for some supplies and two burnt up hole saws later, I installed a dryer vent.
54942875185_02b19bcb89_h.jpgUntitled by Nick Wood, on Flickr
I had to adapt the 4" duct to the 6" hose.
54942875190_fa50cdfbb0_h.jpgUntitled by Nick Wood, on Flickr
And moved to its semi final location, I want to make some adjustments and see if I can get it sit closer to the wall.
54942764948_715cb97499_h.jpgUntitled by Nick Wood, on Flickr
I still want to find a way to drain it. I may tap into the drain from the water heater, or just drill another hole and make a pvc drain.
As for the 944, we started on the brakes. I think it might need some work.....
54937024402_a84b764051_h.jpgUntitled by Nick Wood, on Flickr
Rotors are trashed, so they are on order.
54937903096_ffb49ac96f_h.jpgUntitled by Nick Wood, on Flickr
Calipers are pulled and I shipped them out this morning to be rebuilt. They should come back zinc coated with new lines.
54938211415_7d47200136_h.jpgUntitled by Nick Wood, on Flickr
After that, I need to find some wheels. I like the cookie cutters but there arent many tire options for that the size, so might grab some boxter 16's or some 17 inch twists. We also need to replace the cross member, a bunch of bushings and shocks/struts. I may be able to test drive it by the end of the year.
Mpower5266
Newnan, GA
Glad to see the car fired right up now.
Does the unit have a pump? If not, just grab one of these and tap into the overflow line right behind it as you mentioned. Put a T in the line with a coupler on top and a barbed connector for the hose.
https://www.amazon.com/Little-55441...e-Removal/dp/B00BYFQQ8U/?tag=atomicindus08-20
When I opened the plug, I felt air blowing out of it so it is forced in some way. I have been draining it into a old washer fluid bottle and that is working great, so I am just going to run a piece of pvc out of the house an hook the hose to it.. I think its going to work.
Mpower5266
Newnan, GA
I have kind of lost track of updates on the 944, so forgive me if any of this has been previously posted. The center support had a chunk missing so we sourced another one. It was cleaned and painted, before installation. All of the rubber on the suspension was also replaced at this time.
55087246915_5b54c14d9c_h.jpgThe by Nick Wood, on Flickr
Installed the rebuilt half shafts and new shocks and struts all around.
55087085378_ed0100ac7e_h.jpgThe by Nick Wood, on Flickr
We had the brake calipers rebuilt and zinc'd.
55086690976_ac8eda3744_h.jpgUntitled by Nick Wood, on Flickr
And then the brakes wouldn't bleed correctly so the master cylinder was replaced.
55085989702_a122964e79_h.jpgThe by Nick Wood, on Flickr
55087144314_dd15eb7fc8_h.jpgThe by Nick Wood, on Flickr
I also sourced fabric for the seat inserts.... I think its going to come out awesome.
55086689016_cee1494b70_h.jpgUntitled by Nick Wood, on Flickr
All of that lead up to driving it for the first time in 20 something years on Saturday. The brakes and clutch were very weak(they both need to be bled) so I just putted around the neighborhood with my co-driver. Over all it was successful... It ran fine, got a little hot but not too hot, and from what I can tell all of the gears worked. The tires were awful but that is to be expected. Hopefully I can drive it more in the next few weeks.
55086686986_0cfb5f0e6f_h.jpgUntitled by Nick Wood, on Flickr
Other than that, I have been basically daily driving the Grand Wagoneer and I have been complaining to my dad that it doesn't have cup holders or a place to put my phone. He and I slapped a center console together.
55086880396_bd7b6b0f55_h.jpgThe by Nick Wood, on Flickr
I added some of my wife's vintage fabric to one of the compartments.
55086024292_6325b738da_h.jpgUntitled by Nick Wood, on Flickr
My wife and I have a little weekend trip planned to a cabin coming up, and 4X4 is recommended. I wanted to take the GW but the tires were old, so I picked up some slightly more aggressive Goodyear Wranglers.
55087085428_fd91ae4fe3_h.jpgThe by Nick Wood, on Flickr
I think it looks a lot better and the handling has been much improved. It has a hint of offroader now but it still keeps the classic look, I am very happy with them.
55085993687_f95b4700b0_h.jpgUntitled by Nick Wood, on Flickr
Hopefully my next update will involve leaving my parent's neighborhood in the 944.... and returning.
cccoltsicehockey
Charlotte, NC
Glad to see more updates on the 944. That had to be fun driving it for the first time in so long even if there are more things to do
Wagoneer looks great with the new tires. I have had those tires on my Suburban for the last almost 8 years, soon time to replace them, and they have been wonderful. Countless gravel roads in VT and PA with zero problems while not being all that noisy. They have been good to the point that I am having trouble not doing them again, but I also want something more aggressive looking like a set of Duratracs.
Mpower5266
Newnan, GA
I got the interior back yesterday...... Its loud, but I like it.
55134294255_c2297cd9a3_h.jpgUntitled by Nick Wood, on Flickr
55133013052_71b635ffe7_h.jpgUntitled by Nick Wood, on Flickr
I dont know if I am going to use this but it was so cheap to have made. I have a black one as well.
55133903501_75ced02be5_h.jpgUntitled by Nick Wood, on Flickr
I really just need to get the interior back together, buy some tires, and start doing shake down runs. I have a ton of travel coming up so it might be a few weeks before I get to it.
fouckhest
Greer, SC
Crawfords here in Newnan. The owner is 80 something and doesn't take on much work now days but he likes my dad. He charged us $200 to all of the seats.
Oh wow, that's awesome! I was wondering if it was that T&S shop that is up in Ball Ground, they seem to do nice work.
Mpower5266
Newnan, GA
That seems like a crazy good price. What was included?
He sewed in the new inserts on the front and back seats and added some new vinyl panels to repair holes.
Last night was a late night for me, and I am exhausted.... but worth it. I was supposed to meet up with a guy from FB marketplace to look at some wheels around 8pm at the Harley dealer about 5 minutes from my dad's shop. Around 7:50 he told me he was running late..... 8pm turned into me driving 30 minutes away at 9:15 and getting the wheels back to my dads shop around 10:30. It was pretty annoying and I came close to just moving on, especially since I was lead to believe that the offsets were incorrect for my car.... I am glad I didnt... The offsets were perfect and I love the wheels.
55139237551_e1520e911f_b.jpgUntitled by Nick Wood, on Flickr
They are mint, and the perfect fitment for the car.... I was really worried that I was going to have to mess with spacers but now all I have to do is buy a set of tires.
Mpower5266
Newnan, GA
I made a little more progress on the 944. The rear seats are pretty much installed.
55164825647_f6d2f855ed_b.jpgUntitled by Nick Wood, on Flickr
The front seats are done and will probably go in soon. We did find that the speedometer cable was bad, and to replace that the cluster has to come out, which means the steering wheel has to come off.... Since it was coming off anyway.....
55165970364_2dafa509e5_b.jpgUntitled by Nick Wood, on Flickr
I picked up a silver prototipo to match the bezel around the gauges.
55166105235_98a12819e9_b.jpgUntitled by Nick Wood, on Flickr
We also, mounted tires on the wheels.
55165171854_9840f9e5d1_b.jpgUntitled by Nick Wood, on Flickr
Wagon things.....
55165568710_cbbea9f114_b.jpgUntitled by Nick Wood, on Flickr
And of course I did a quick test fit.
55165089713_122f0771cb_b.jpgUntitled by Nick Wood, on Flickr
I just put them on the drivers side and didnt move the car around. I am hoping that the rear will settle down a little but if not, I will look at some options for lowering it. I am leaning towards cranking the rear torsion bars down two clicks and getting new springs in the front. Either way, I am happy with the fit and offsets.
55164926551_d0bf447ce5_b.jpgUntitled by Nick Wood, on Flickr
After that, I took the wheels back to the house to clean them. I was hoping that I could just hit them with a quick hand polish and coat them, but they are raw aluminum so its going to be a little more involved. More soon.
55165187046_cff0be004e_b.jpgUntitled by Nick Wood, on Flickr
burger
Erf
Those wheels look fantastic! Good choice! I like them as they are without center caps. They are perfect for the car. Tire size is good too. Could see it being a tiny bit lower to close up the gaps.
fouckhest
Greer, SC
If you do decide to open up that can of worms, there are two companies (Renegade and Zephyr) that make really nice polish kits that use wheels/rouge that work with a standard buffer and they do a great job.
runit
Raleigh NC
Man....I think the black/silver wheels looked so much better, especially if running the polished wheels with no center caps.....looks incomplete
since I was asked!
Mpower5266
Newnan, GA
I have had really good luck with the Nuvite stuff. I used to polish my dads plane with it.
since I was asked!
The stock wheels?
