The completely overkill compressor project
American Locomotive
Rhode Island
Not my own project, but I'm helping with it, and I figured you guys would like it.
So a buddy of mine found "make your own compressor" deal on Craigslist. It was a large electric motor and cast iron pump bolted to a steel base plate for $100. It was being sold by a local company that hadn't used it for several years, and it had no tank, switch gear, etc... For $100, it was probably worth it for the motor alone. Well my friend went and picked it up, where he quickly found out he got a lot more than he expected.
For reference, it's sitting in a full-sized F-350 bed. Approximate weight of that setup, just the motor, base-plate and pump is about 750 pounds.
What my buddy ended up getting was a Blackmer HD372 pump with a 15HP 3-phase electric motor. (He had no use for the motor, which I'll be taking to build an RPC to power my Lincoln dc-250 mk motor-generator welder, but that's another project for another thread).
It turns out this isn't an ordinary compressor pump. It's an industrial "gas compressor" pump, using a cross-head design that seals and isolates the pistons from the crankcase. It's rated to compress basically any kind of gas: air, natural gas, propane - even gaseous ammonia. The crosshead design also increases durability, since the pistons only move up and down, with no side-load.
Here's a cut-away diagram showing the cross-head design:
This particular model is a twin-stage design rated to pump 24 CFM with a maximum working pressure of 600 PSI. It's also got all sorts of features on it, like an oil-pressure cutout switch, electronic/pneumatic unloaders, full-pressure lube system with a spin on filter, etc.
Luckily at reduced speed, pressure (~175 PSI) and overall flow-rate, this particular pump is rated for use with motors down to 5 HP, which is what will be installed on it. It should also live a very easy life at these sort of pressures, compared to what it normally runs at.
That's really all we got for now, still need to get the other pieces to the puzzle - like a tank and a motor. I'll be updating the thread as we progress.
Dozerhand
Illinois
That sure is a handsome pump. I think before I got to hot on parting it out or repurposing it I would research what it would take to get it back so it could be used for it's original use. After a little goggle it seems the primary use is to compress natural gas in the oil field. One company has a new engine powered one of these and wants $27,500 for it. Might be able to rework that one and sell it and buy the air compressor of your dreams. Plus a good part of a new shop.
ToddW
In the snow
That's awesome it can work on 5HP.
I had a HUGE pump that I just gave away because it needed a ridiculous amount of HP to work. Thinking back I should have kept it, and thrown on a GAS motor and then sold it, loL!!
