The guys got started on the architectural details for the next wall placement.
We decided to extend the length of the placement to avoid a construction joint in the architectural concrete. This required us to do a little additional excavation and extend the footing. We'll get it placed today.
This wall forms the gallery that runs the length of the house - you can see it to the left of the staircase on the model.
You can also see the blue water lines from the geothermal wells that we ran down the back of the site retaining wall excavation. They'll eventually make their way into the basement where the heat pumps are located.
We have a lot of footing steps as we chase finish grade around the site to maintain 4' minimum frost cover - we're actually shooting for at least 4'6".
Finally got the waterproofing crew out to spray the garage foundation. They start by sealing the tie holes and placing a fiberglass type strip over the construction joints to allow for any future movement
The first thing the operator does is turn the gun sideways and build up a cant at the base of the wall.
Then he sprays the rest of the wall. They work from the bottom up because the material is activated by salt water and they don't want it to run down on areas they haven't sprayed yet. The material is dry to the touch in seconds
Just an aside about the uncapped rebar. It is way too high for anyone to fall on it. We'll be sure to cap it before we backfill.
Here's the back of the garage all sprayed. When they come back to do the basement, they'll be able to work off the backfill to finish the top of the wall.
The four sleeves you can see at the top of the wall at the extended step is where the underground electrical comes in.
Kind of hard to see but the last step is to tack on the drainage board. Its a corrugated plastic sheet with a filter fabric applied to it that allows any water bouncing off the waterproofing to run down it.
Now we can run the under drain, connect the sanitary lines, complete the underground electrical and get the garage backfilled. Finally.
