My only excuse for the lack of updates is the painfully short days. Seems I go to work in the dark and come home in the dark. It's hard to find the time to take photos. Oh well, better late than never, right? We started installing window a couple weeks ago. Here's the first one;
As I've mentioned, the windows aren't your typical Andersens. They fit within the rough opening and are sealed with a perimeter caulk joint.
It wasn't long before the first level front of the main floor was complete. The frames are in for the second floor but the crew hung a poly wind break to make their life a little easier. It's getting a bit chilly up here.
The view from the inside is even better. We are using a low e glass with a gray tint.
They've got the frames in for the Guest bedroom
And have finished the opening below;
Meanwhile, we finished insulation and plywood on the basement walls;
We've also started the last bits of concrete. This is a stoop in front of the basement door. Part of our plan to thermally isolate the radiant slabs is to build stoops that extend in under the doors.
We will add a few more bars and extend the rigid insulation out about 48" to keep the frost from getting under the stoops and lifting them.
We're using the same detail for the garage door aprons. This detail completely isolates the heated garage slab from the cold.
Here's prep work for the front entry stoop. It is supported by foundation walls but we still want to keep the frost from heaving the slab.
This is the stairs leading down to the dock;
Speaking of the dock - it's gone. Always sad to see it go but we've got to pull it out before the ice sets in. I run a clothesline type rope from the stairs to the mooring to keep the dinghy in as long as possible. Ya never know when a nice day might require a little river cruise.
We've got a couple weeks of window and flashing ahead. The heating contractor is coming a week from Monday so we should have heat shortly thereafter. Now if I could only get tha damn camper sorted out. This might not have been my best idea.
