So I made this little bit holder out of scrap
Table desk project by
Derelict Garage, on Flickr
Ah but where did I ever get such wonderful scrap? Glad you asked.
So I dragged this big heavy crate home from work.
Was gonna build a desk. Took all morning to get this sucker torn down. Its all oak...and very heavy!
Untitled by
Then the "minister of design" says she doesn't like the color. -- Pretty standard--
Says she wants more "weathered looking". So I go around to the side yard and get the one that's been laying out there for a year.
Untitled by
Tore this one apart. Then set up a frame.
The mandate came down from SWMBO that the legs are to be in the shape of an X. Scratched my head. Figured the only way to achieve (semi) consistent results was to layout on the floor.
by
Layed the legs down, marked 'em as good as I could, then got out the circular saw.
by
Slapped em together and laid em down.
by
It was difficult to get the legs square, since the lumber was warped and split, but I called it "close enough" and put it together.
by
Then the top. Also made of oak - a bunch of pallet slats I tore down a while back.
Untitled by
They also looked too "new". I was thinking about staining or aging them somehow when I found the answer.
Burn them.
It is an old Japanese technique know as "Shou Sugi Ban". I didn't follow it exactly...but the results are nice.
First, you burn.
Untitled by
Before/After
Untitled by
I thought "Wow, it instantly looks 100 years old!". So much character was added.
Then you wash. Water and a wire brush.
Untitled by
Clamped the boards between two cauls to help straighten. Actually left them like this for over a month. I got sidetracked in the middle of the project as typical.
I was also given the design brief that the boards shalt be laid in a "vee".
Untitled by
The lady has a good eye. Usually results in a lot of extra work. Its worth it though...wouldn't you say?
Untitled by
For finish, a couple coats of this stuff:
Untitled by
Its SUPPOSED to look like mayo. Weird stuff. Its consistency is that of cake icing. I found the best technique was to put it on a little heavy with a cheap brush, then immediately wipe down the excess with a rag to prevent pooling or runs. That first coat was a bear because the wood is real rough, but the second one went down real easy.
Untitled by
Gotta do some painting before I can move it into the office. It is designed to be both a desk and workbench for indoor projects since we seem to do a lot of em these days.
