The Everything 3D Printer Thread
XJSuperman
Central Iowa
Yeah I tend to think similarly, but I also read through the project page for any important settings and compare the profile differences. I had someone download my Roku case, ignore my profile which intentionally did not use supports, and then give me a bad rating because he couldn't remove the supports. I specified in the page and in my profile that supports were not enabled.
People definitely can't read. I just got a bad review because someone believed one of my socket holders was supposed to be for gridfinity and it didn't have squares on the bottom to align it. I don't do gridfinity and its not mentioned anywhere on my models.
quadrcr87
Travelers Rest, SC
Ok I'll admit, I am late to the game, and I have not read all 103 pages, yet. Just picked a Bambu A1 as a first printer. Started with PLA but I want to try PETG and TPU. I am limited by the A1's capabilities so no engineering filaments. (ASA, ABS, etc)
Looking for a quick suggestion on an entry level but effective filament drying setup. I am already planning to build a sealed Tupperware for storage with desiccant and humidity meter.
Citation
Indy
One idea is turn on your other build plate to 50C. Place the spool on the plate with a cardboard box on top. Now you have a heated dryer. This of course is a quick solution rather than a fixed setup.
Other people have done plastic cereal containers with desiccant. There are files on line for such a setup.
quadrcr87
Travelers Rest, SC
Thanks for the idea, I would rather have a standalone dryer. I have seen some use a food dehydrator rather than a filament dryer. I am just a hobby printer so drying 1-2 spools at a time should be plenty.
draco_1967
Utah
I just got a Sunlu S4 (does up to 4 spools). It seems to work well. They sell a single and dual version also. Alternatively, you can use a food dehydrator.
Poolshark314
MD
Do you have a hygrometer to get an idea of what your humidity levels are currently in your printing environment? I have never owned or used a filament dryer and have never had an issue in the 5+ years I have been printing
kaymccampbell
Upstate New York
I've got a couple Tupperware like containers with desiccant and a humidity gauge. Stuff only stays dry in them so long. I picked up the little single reel Sunlu dryer, and it's doing well. Filament goes from brittle and foamy results, to flexible and clean prints in several hours. Then I stick it in the Tupperware in the hope that I'll use it again before the humidity comes back.
moab11
Thunder Bay, Ontario
I have the Sunlu S2 (single spool) and S4 (4 spool) and really like both. They seem to work well and hold temp, I do open the lids on each occasionally as they are running to let out any moisture, but no complaints other than the limited max temp.
To solve the max temp, and because I seem to have a problem buying new gadgets, I've preordered the Sunlu E2 dryer, and can't wait to try it out, but looks like it won't ship till March.
loganb
Omaha, NE
If anyone needs ideas of things to print, Printables just finished a "Pimp your Workbench" printing competition:
Yankeefarmer
Connecticut
Mrs. YankeeFarmer has been taking jabs at my recent purchase of a 3d printer. One of the projects I had planned for it was to produce new brackets for the railing on our front porch. The originals, installed about 20 years ago, were improperly secured and fell victim to restrained thermal expansion/contraction. After successfully designing and printing my replacement in ASA material, I decided I should also add an additional support under the bottom rail. After mulling over what that design should look like, I decided to have some fun with the Mrs. and ask her what she thought of my design concept, pictured below. Turns out, she thought it was funny and wants me to use it! IMG_1524.jpeg
ed_
Maine
My new to me (used) Prusa MK3S arrived a few days ago and I'm super impressed with it. It just jammed out my first large print with no issues after I finished calibrating it. I was previously printing on a modded Ender 3 v3 SE that worked decent but had some quirks you had to be aware of.
The print is a paint gun holder. Needs more bracing and some revisions but the end goal is to make a rack for my 4 hvlp guns with a small cubby underneath them to hold spare parts.
loganb
Omaha, NE
Nice! If you want some spare parts and extra nozzles send me a PM and I'll put what I've got left from mine in a mailer to you
zanyad
NE Ohio
Careful uploading anything with proprietary information to a service that doesn't guarantee data privacy. The free brain version of ChatGPT, for example, does not guarantee your data will stay private. Not sure about paid version.
Edit: swipe-type fail
Black300zx
Elkton, Md
I had a need to make some flexible parts for my Z with good heat resistance, so I started playing around with TPU. Fun stuff. Still have to tune things in to reduce stringing, but parts do what I need them to do.
Years ago I replaced the multi-piece hard clutch line with a flexible one-piece line. Until now it was just zip-tied in place to the stock lines. The aftermarket line is larger in diameter so I wasn't able to route it into the factory clip.
New clips modelled and printed to accommodate the aftermarket line:
Nicely routed behind the factory heatshields, alongside the factory brake lines (as intended)
Jehannum
Albuquerque, NM
I did the same thing all up and down my 240Z's transmission tunnel for the 3/8" fuel feed and return lines. I used ABS, as it's somewhat more resistant to heat and more rigid than TPU.
I should do it for the Z32's O2 sensor wiring, since mine aren't in the stock locations.
Black300zx
Elkton, Md
I did the same thing all up and down my 240Z's transmission tunnel for the 3/8" feed and return lines. I used ABS, as it's somewhat more resistant to heat and more rigid than TPU.
Oooo - another z32 owner here? 🤘
If my ender 3 max could print ABS I'd have went that route. I'll definitely be printing some sort of clips for my wodeband O2 sensors
Jehannum
Albuquerque, NM
Funny enough, I put an e3dv6 on my (then) Ender 3, and it printed ABS and nylon all day (though it was very slow).
I moved the V6 over to my CR-10 when I got that.
I own a lot of old slow cars, and my Z32 is the first one I ever bought back in 2005.
Poolshark314
MD
Just received a 1 star rating on my Engineering Flowchart profile because the print kept warping on them. Warping and bed adhesion issues have nothing to do with a model, especially when the model is a flat rectangle with no overhangs lol
loganb
Omaha, NE
Reply back to them that they should follow the flowchart and get duct tape instead of blame others for their incompetence!
loganb
Omaha, NE
This thread makes me want to buy a printer.
Then I’d need a new computer, evidently a dryer too, etc.
Tempting
The dryer is cheap and not needed for most users if printing PLA. petg, abs, tpu will benefit from or need it but PLA doesn't care as much
Computer....it depends. The slicer that takes the CAD model and converts to the code for the machine to use isn't that resource intensive and if you have a computer in the last 10 years that is capable of browsing at a reasonable speed it should be fine for slicing. If you want to do CAD and design your own things you probably want a machine made in the last 5 years....preferably with a dedicated graphics card but the computer doesn't have to be a beast for a home user. The old adage that CAD machines have to be these incredibly expensive and powerful machines isn't as accurate anymore and the real resource drains come with very large assemblies, motion and advanced analysis....all things the 3d printing home user won't be doing.
Yankeefarmer
Connecticut
For those concerned about CAD software, take a good look at OnShape. Developed by the same guys that built SolidWorks, it runs in a browser, so the heavy computing is performed by their servers. Free for hobby use, as long as you don’t mind your files being available to other OnShape users.
Boosted1
Georgetown, KY
I’ve been using a Mac desktop at home for 8 years or more because I got so tired of keeping up with windows updates and anti virus updates
I have a work laptop that is really nice, but that’s for work and I don’t have to worry about the updates as the IT dept does that.
First world problems, I know
Rccrawlerguy
Damn you guys... Showing off all of your projects. You're making me jealous over here. I've been wanting to get a printer for a while, finally pulled the trigger. I ordered a Tronxy X5SA. Its a 400mm x400mm x 400mm machine. I didnt get any upgrades for it yet. Figured I would atleast getting it up and running. I do want to add the 2in-1 out extruder. Only thing I ordered for it so far was some corner brackets. A couple videos I watched suggested adding them for extra rigidity.
I bought this almost 2 years ago. I got it 50% put together and then got sidetracked( project ADHD kicked in haha). Finally finished it last night and did the calibration and leveling on it. I'm doing my first print ever now. I am getting some stringing. I am using the machine settings and ELEGOO PLA. We'll see how it turns out.
Citation
Indy
I've got to say Windows 10 and later really is much easier in that regard. My current daily driver laptop is a 2014 Dell M3800 (a slim line CAD model). It's been a great computer for the past 11 years. Anyway, with Win 10 MS started really moving to an update push model. The experience is much like it has been with my iphone.
I'm not an Apple fan because in the past they didn't offer high resolutions screens (pre-retina models). In more recent times I just really dislike how much they charge for things like memory and HD upgrades. I do appreciate that they don't cut corners. I do think you can get a really nice Windows computer (most Thinkpads, Dell Precision and XPS laptops) but Windows also offers the choice of low cost decent and low cost garbage machines. The problem is knowing which you are buying.
For the most part Macs haven't supported the programs I've used most (Solidworks, a few games, some other random programs) so I've stuck with Windows. I do appreciate much of what Apple does well but I also like not being in a walled garden with nice but limited options.
