There's lots of reason to have a computer in the shop. I guess the biggest reason is research... There is nothing like have Google at a moment's reach. However, placemen...
That's a good idea, but wont it restrict the air, cause a little more heat?Right now I normally just use my iPhone if i need to look something up, but my iPad is usually handy as well. I have an Airport Express hooked up to a receiver in the garage, so I can pipe music wirelessly from either device very simply.
Eventually, if/when I get a true shop, I'll probably have a Mac Mini sealed inside a filtered box, or even an old Macbook that I can tuck away when not in use.
One thing you guys running desktops in your shops might consider is picking up a roll of fiberglass filter material, used for AC filters. Cut it to fit in the air intakes and let it pick up all the **** that gets sucked in. then just replace the filter every couple of months (or more frequent, depending on how dirty your shop is).
I like my setup better its enclosed away from all the metal, wood and paint dust!!
I have also seen a computer set up in a tool box but sorry I can not find the photo at present.
Very neatly done and the way it folds away and looks like part of the tool area is very clever.
I have my own office space away from the works area and designed it this way for a purpose as well as keeping the computer away from dust and dirt etc. Easy then to have a warm place when it is colder and a cool place when it is hotter. As I am also Solar powered running two systems one is the for want of a better term a UPS system seperate from the grid with its own two small Solar Panels and batteries but can charge from the mains (bigger Solar System) if needed, that small system runs my office space, being phones and answer machine, fax, computer and scanner printer etc. as well as a few lights. The property also runs on Solar started with 12 panels and recently added another 12 panels (yes 24 in all on the bigger system) with battery back up that on a good day it exports to the grid so the location of my computer in the office area in the works in future will be important as I will add a monitor system for the grid power export invertor.
The Computer as well as all the Solar is contained in the Shed / Works (all panels on the roof) and I have no computer in the house.
Very slick, I like it.
Thanks! I also did my stereo the same way!
Again very clever. You should start a topic and just show us all your ideas as not only is it clever it makes for a tidy work place.![]()
