measuredtwice
I think you can also get them at Bed Bath & Beyond over by the dishes.
And in the audio aisle next to the record players in RadioShack during the 1970s
Braun 4 ft. LED Shop Light 64410 - PASS
These have probably been mentioned before but they are great lights and often on sale for $20 each. Even at full price they are worth every cent, I wish I bought these a long time ago. You have no idea how bad your garage lighting is until you have good lighting.
Does this have or need a 3 prong plug with a ground?Braun 4 ft. LED Shop Light 64410 - PASS
ok thanks, lot of the micky mouse wiring here is old with two prong only.Yes.
l'm hoping to get out of here, but, who knows.
Yeah, I can do that.3-2 prong plug adapter?![]()
So I don't really "need" the ground, just for safety, right?
bought a cupped wire wheel- fail
I admit it wasnt big money but still expected it to last longer than it did
Got you, Sounds good, Thank You!The ground is there so the aluminum housing isn't live at 120V if something goes wrong. If the light is going to be out of reach it isn't super critical. If it will be somewhere that incidental contact is likely you could paint the bare aluminum.
The best course of action would of course be to ground it. My house had nothing but two prong outlets when I moved in, but it turned out that all of the outlet boxes were grounded and I was able to ground three prong outlets there instead of with an earth wire. Might be worth checking out.
It's an overhead light, built in the 21 century.
Personally, I would not sit up nights worrying about it.
You can always manually ground an adapter, if you are worried about it.![]()
OK, Thanks Guys!Im with this guy, wouldnt even think twice about using an adapter for that. The house I rent is from the 50's the whole house except the garage and washer/dryer are two prong. Have adapters everywhere. Just the name of the game for me right now.
https://www.harborfreight.com/long-reach-ratcheting-bypass-lopper-62681.html?_br_psugg_q=pruner
Pass
Long reach loppers. I'm taking into consideration that after a coupon these were 11 bucks.
Had storm damage, a cedar ~50 feet tall blew down. I chopped it up with a chainsaw and moved it to the curb for pickup. I used the loppers for the small stuff.
No issue cutting through 1" cedar. The picture doesn't show it but the handles extend for added leverage.
even had a 4 glass fuse box.
I had that same trouble in another place. (From the compressor starting also)Wow I had houses like that most all my life, ungrounded 2 prong outlets, black and dirty white wire that looked black tooeven had a 4 glass fuse box.
Bought my first non contact voltage tester because of all that stuff
I remember trying to run my 15 amp air compressor was almost impossible...yup needed a slow blow fuse
With my new house almost forgot all about all that old stuff![]()
Oscillating Multifunction Tool 62866
https://www.harborfreight.com/oscillating-multi-tool-62866.html
Pass.
Tons of uses. Works fine. Just get one. I think I got mine on sale for $5.
Pass.
That's pretty common on things that are handled like meters. I'd take the POS back and then ***** if they try to charge the restock fee.The battery compartment...and requires a philips screwdriver to open and close the battery compartment.
Here is a HUGE fail. You used to be able to find manuals to any product HF ever sold. Just punch in the number along with the number range and there is was. I was able to find manuals for 20 year old tools on their website. A PDF takes up like no space on their server drives. But I tried today and NONE of the manuals of some of my older tools were available. Not one! And yes, some of their tools last decades and I have long misplaced the paper manuals. Now, for the most part I have downloaded the manuals already and have them in my Tools folder. But noticed today the older ones are no longer on the HF website. It would seem they are trying to force folks into their high end tools to boost profits. So they just end support for anything over a couple of years old to get people into a set of new tools. Well, I'm a handy guy and their tools are generally pretty easy to figure out. ....But removing their old manuals to squeeze their customers really made me mad.
LOL, I just ditched one of those! I think it was the Kmart brand from the early 1980s: thin metal box with 2 little skimpy metal latches that popped open on their own, sloppy casting from at least 3 different suppliers, plastic insert full of cracks, shiny paper sheet glued off-kilter inside of the lid, ill-fitting pieces...had the feel of something assembled at gunpoint.With that thin cheap plastic organizer. Specific memories of Kmart and Buffalo sets are popping into my head.
Here is a HUGE fail. You used to be able to find manuals to any product HF ever sold. Just punch in the number along with the number range and there is was. I was able to find manuals for 20 year old tools on their website. A PDF takes up like no space on their server drives. But I tried today and NONE of the manuals of some of my older tools were available. Not one! And yes, some of their tools last decades and I have long misplaced the paper manuals. Now, for the most part I have downloaded the manuals already and have them in my Tools folder. But noticed today the older ones are no longer on the HF website. It would seem they are trying to force folks into their high end tools to boost profits. So they just end support for anything over a couple of years old to get people into a set of new tools. Well, I'm a handy guy and their tools are generally pretty easy to figure out. And on that note, I just want to mention that I have never wore out any of their air tools. I oil them, seal them if they leak. I have lots of spare brushes for their angle grinders and other electric powered tools. I also take them apart once in a while to clean and lubricate them. Yeah, burned up a few plastic bearings and things like that. But overall, my tools have lasted a crazy number of years. But removing their old manuals to squeeze their customers really made me mad.
You managed to pick the absolute bottom tier sockets & ratchet at HF. Not only will it not compare to Snap On, it won't even compare to the basic Pittsburgh Pro sockets that they sell. 40 pieces for $5.99 what did you expect?
Oh that $5.99 socket set I needed something really quick the ratchet is a POS when you are wrenching the drive backs off to not engage forward or backwards..
This guy has a fair whack of HF manuals available on his website:Here is a HUGE fail. You used to be able to find manuals to any product HF ever sold. Just punch in the number along with the number range and there is was. I was able to find manuals for 20 year old tools on their website. A PDF takes up like no space on their server drives. But I tried today and NONE of the manuals of some of my older tools were available. Not one! And yes, some of their tools last decades and I have long misplaced the paper manuals. Now, for the most part I have downloaded the manuals already and have them in my Tools folder. But noticed today the older ones are no longer on the HF website. It would seem they are trying to force folks into their high end tools to boost profits. So they just end support for anything over a couple of years old to get people into a set of new tools. Well, I'm a handy guy and their tools are generally pretty easy to figure out. And on that note, I just want to mention that I have never wore out any of their air tools. I oil them, seal them if they leak. I have lots of spare brushes for their angle grinders and other electric powered tools. I also take them apart once in a while to clean and lubricate them. Yeah, burned up a few plastic bearings and things like that. But overall, my tools have lasted a crazy number of years. But removing their old manuals to squeeze their customers really made me mad.
I have not been in this thread in awhile but how are the Icon stuff?
Pass = Bauer Trim Router https://www.harborfreight.com/14-in-65-amp-variable-speed-compact-router-64944.html
I wanted a trim router to use so I didn't have to keep taking my standard size router out of the router table. I've been using this a lot for about a month making cutting boards for Christmas. It has worked flawlessly on hardwoods with various bits. I did grab it on-sale.
I'll second this. I never thought an oscillating tool could be that handy but at HF sale prices I picked one up on a whim and damned if I know how I got by without one now. With the right blade I've cut stucco (masonry) steel, wood and drywall. Every now and then it gets kinda hot, but I'm usually ready for a break myself by then.
