The Harbor Freight PASS/FAIL Thread...
Ed ke6bnl
Agua Dulce, Calif.
I just have to mention that I had to remove a damper pulley on my Honda, and used my 1" 1200 ft/lb impact reduced to 3/8 snapped the sears 1/2 to 3/8 in an instant and the HF took off the bolt in a instant. so a pass to there ratchet reducer adapters.
subarub4
Connecticut
1. 3 lb Neon Orange Dead Blow Hammer --- PASS
2. 24 oz. Ball Pein Hammer --- PASS
3. 18" Heavy Duty Pry Bar --- PASS
4. 3/8" Drive 17" Breaker Bar --- PASS
5. blue nitrile gloves --- PASS
I use these every day in an auto repair shop.
Good to know about the dead blow hammer I was a little scared so I got a 3lb rubber mallet.. It's held up to all the pounding I've done with it.. Might pick one up tomorrow.
jimdi4
1. 2 ton engine puller (got it for $147.00 4 years ago) --- PASS
2. Digital Caliper - just replaced battery (3-4 years now) --- PASS
3. 18" Heavy Duty Pry Bars (2 years ago) --- PASS
4. 3/8" Drive 17" Breaker Bar (just got)--- PASS
5. blue nitrile gloves always use --- PASS
6. White nitrile gloves always use --- PASS
7. 4.5" cutoff grinder metal discs (always use) --- PASS
8. 4.5" Orange CE grinder (just got) --- PASS
9. 4.5" Blue ($9.99) grinder (just got -stopped working opened up; wire melted inside) --- FAIL (returned for another #8)
Thanking Obama for killing Bin Laden is like going into McDonalds and thanking Ronald McDonald for the hamburger:rocker::3gears:.
It's the guy cooking the burger that should get the credit, not the clown.""
jimdi4
Mig cart. I bought 2 of them for $39 each. They didn't have one on display at the store, so I knew it was a gamble. Bad idea. These thing are terrible quality. Thin sheetmetal, typical Chinese "easy-strip" fasteners and the famous HF wobbly wheels and wandering casters.
Fail X2.
I had the bearings on the front casters fall completely out...but i have my cart overloaded...I replaced them with bigger casters and this cart is pretty decent
jimdi4
http://www.harborfreight.com/air-tools/hammers/super-duty-air-hammer-with-chisels-47868.html
Got this air hammer yesterday to break up some ceramic tile floors for a bathroom remodel. Performed flawlessly. Havent tested it yet on anything metal like rivets or anything, but it saved my *** yesterday. Cant beat it for 13 bucks.
Dude,
you got to get the quick disconnect HF sells...It replaces that stupid spring which is hard to get the bits off and do a quick change...HF sells the Quick changer for about $5.000 and it works great!!!
subarub4
Connecticut
Has anyone tried the walk out and walk back in to use another coupon? I have one for the engine crane and generator but I don't want to make two trips back to the store.
Racr350
Rochester, NY
Dude,
x2. Got one for my dad and his olddd Snappy Air hammer and works great. He had no idea these even existed until i showed him my IR that came with one. Well once he saw it he had to have it. But i was in no way gonna spend the money to get him a Snap-On version. The HF version is great and does what its supposed to. All he'll ever need. :)
greasemonkey44
memphis
Anyone ever try the Pneumatic brake bleeder kit? I bought one,but have not had a chance to use it.
ive got 92924
works great, not as good as a name brand but a def pass
used it today infact and it works well
SQ is the SQUAD
Boston MA
Dude,
..mine just failed the second time iwent to use it. seems like all the air is blowing past the seal. i will exchange it, i have faith another will work.........
SQ is the SQUAD
Boston MA
Just had to chime in, that I'm Youngstown born, Youngstown bread! lol We're still doin alright in these parts!
Reviews:
Impact Screwdriver - PASS/FAIL - Broke all phillips head bits on my Honda rotors, but those suckers were STUCK on. Not the tools fault.
6in C-Clamp with quick-release slider - PASS! Obviously I did a brake job, and this thing worked beautifully pushing the piston back into the caliper. Plus the quick-release was a big bonus.
what part number do you have for the clamp?
i need to grab the inpact screw driver. those honda screws are the hardest to get out. i had to put my odyssey kunckles in press and press the rotor off. the rotor snapped before the screw broke.
i did buy the pnumetic brake bleeder, but i have not got a chance to use it yet.....
toxicz28
NY
I do it all the time. Especially when my 6 year old doesn't want to go tool shopping.
jhelrey
MN
Don't put the screws back in...
SuperSocket
Two general coupons
Use them both at the same time. You just can't use more than one 20% off coupon per transaction.
As always with HF, YMMV.
Correct. I have never had a problem with using multiple general coupons as long as you are not trying to buy more than the max per item allowed (for example, 16 of the same hammers with two 8 per coupon limitations).
The 20% off coupon is only one coupon per customer per visit... so that you would have to bring someone with or make multiple trips.
emeraldcoupe
spring hill, florida
subarub4
Connecticut
So yesterday I picked up the following..
2 stroke generator
1 ton shop crane
1/2" 14mm 12 point socket
metal ruler
Automatic float charger
Since they seem to always be out of the free flashlights I got the free screwdriver set instead since you can never have too many!
So far the float charger works fine.. I will check the generator a little later on.
Quint
Youngstown, OH
Not sure the part No. on the C-Clamp..sorry
The impact screwdriver works great most of the time! I bought a 2000 CX hatchback as a daily, 3 years ago. Just now had to replace the brakes. Those screws were absolutely rusted on FUBAR! My buddy's dad is a mechanic, and luckily he had a Blue Point impact screwdriver. It worked, but we had to hit the driver with the hammer for every turn of the screw until it came out.
frbl
Philly, PA
Dude,
After reading this and checking it our I had to get one. It's great! Thanks for the advice!
Ford52PU
Coatesville PA
I purchased the benchtop blast cabinet on the 4th of July, using a 25% off the sale price and got it for $89. It works really well so far for the type of use I am giving it. So I rate it a PASS!
MadMark
New York City
7 Drawer End Cabinet for Roller Tool Chest... PASS
For the price it can't be beaten. The Power coat finish is excellent, the steel is thicker than any Craftsman/Waterloo side cabinet I've felt and the price is great. Heck even the shipping is fantastic ($11.99 others want 3 or more times that.)
If there is one thing HarborFreight did right, it was definitely their tool chest.
I just tried to order that 7 drawer side cart and the shipping went up to over $40, they claimed it was overweight (128 lbs)
Is it that heavy.
dodge610
North Canton Ohio
Is it that heavy.
Try and see if you can order it and have it shipped to your HF store with there shipment they get weekly maybe you can save the freight that way I think they still do it that way.
Vinny
Simi Valley, CA
Bought a Pittsburgh Pro 1/4 drive ratchet set today. Came with a bunch of Metric and SAE sockets. Used it in conjunction with a twelve point screw to do my CV Axles, probably the messiest thing I've ever had to do in my life.
For me, I say they are PASS, but something quirky kept happening: the ratchet kept locking up. I don't know if it was because I had some Moly grease pushed in (I was covered in the stuff) or what, but quickly rattling the thing got it going again. Kind of strange, I'll see how it works in the future, but I don't have much need for sockets that small on a regular basis.
By the way, if anyone knows a good way to get grease off of a rubber or silicon handle with out destroying it much, I'm all ears!
Indy_500
Appleton, WI
Who all has the 2.5 HP 21 gal. compressors?
It's a PASS for me
I've had the new black one for 4 months now, still works great! I probably fill up the tank 2-3 times per week (on average).
I probably should do a whole new list of everything I've purchased and how it's performed. Just would take a LONG time. One of my most recent FAILS is the tire iron I purchased. It looks poorly made, and doesn't seem very useful trying to take tires on and off.
I've also been enjoying my "new version" 1.5 ton compact alum. floor jack for the past few months also. Paid $60 out the door, jacked up plenty 1/2 ton trucks with no problems. Just wish it lifted higher, but that is why it's called "compact". It seems built REALLY well and is a PASS in my mind.
SuperSocket
2 stroke generator
1 ton shop crane
metal ruler
I'd like to know what you think of the generator.... would be just a cheap generator to have just in-case for various things.
subarub4
Connecticut
I like it so far and I used my coupon so it was $89 I've only used it for about 3 hours now (going to be using an hour meter) but it was easy to mix.. I did change the spark plug out.. I can't figure out how to get the picture off my other phone but the Chinese spark plug looked like it was worn down vs my new NGK plug and the inalator was like a dark greyish color.. not something I would want to use..
I gaped the NGK plug to .027 It's been great.. the first thing i tried it with was a heater which only had two settings and from looking on the internet the two settings are 1000W and 1500W.. It did 1000W plus a vornado fan but you had to start the fan first and then the heater.. I was getting around 107 V.
What I did get this for was I have to run some audio in a park for at least 7 hours on the 31th of this month.. the genny is a tad undersized for the need Since I'm going to be running a 1500W power amp Plus a CD deck & mixer.. the max amp draw for the amp is 8 A..
However i did a test the other day with all the stuff I would be taking and it powered it fine and I think my voltage on the power conditioner was around 113V.
I'm glad I finally picked one up, I did a 50:1 mix it does not smoke at all when running only a little when it cools and you need to restart it but it's only for a few seconds like 10 sec at best.
here is one video of me drawing power what I will be taking to the park that day.. that's a lot for not hitting the 25 hour mark yet.
and this other one I was just testing.. it's not that loud.. it's about as loud as a 4 stroke generator.
Danglerb
SoCal
That must be magic watts on the power amp, with max 8 amps at 120vac thats 960 watts going in, so more like no more than 800 watts max going out in real watts. Plus with typical music average power is only about 10% of peak power, course some peaks are longer than others. ;)
Make sure you let it cool down before refilling with fuel.
