Channel lock type pipe wrench: fail
I have had these for years, when in the middle of a big DIY project the wrench bent and jumped locks. It is difficult to see in the pictures but the hinge is still engaged and the locks are bound on top of each other. Also of interest is the pictured gouged teeth edge: I was working with brass fittings, I don't think anything I was working with should be harder than the teeth, I'm pretty sure it wasn't my knuckles...
Anyways same project, HF (Icon) pliers wrench knock off: PASS, sort of.
I have the icon 10" pliers wrench, the Klien 10" pliers wrench and a knipex 150mm pliers wrench. The Klein wrench wouldn't fit as the reversible jaw fowled another fitting, the icon's just fit.
I had the icon's on a 1.25" fitting with a 3' cheater pipe and the job got done. I love the cam design which allows force to be put on one handle in use, unlike the slip joint style which need you to squeeze handles together while applying turning force.
Icon pliers held together and got the job done, so it is a win.
However the icon's are a little loose in the hips/joint now. Still perfectly usable and acceptable IMO for the abuse I put them through, but you can feel the slop when compared to a new set. I believe it perfectly reasonable to expense the pliers wrench for a job like I performed and consider them disposable after significant abuse (clearly outside design parameters). Like many others I am suspicious of HF metallurgy vs knipex metallurgy. My 150's are too small to have been of use however the Icon pliers have sold me on the design, and I will likely buy a set of genuine knipex in a large size if I get into another mess like this.
