I'm a homeowner DIY car maintenance and wood hobby guy. Here my updated opinions:
FAIL ( so much that I returned the item )
Magnetizer - didn't do anything
Thumbwheel ratchets - so coarse, and the selectors locked up needing to fight with it
Snap ring pliers with interchangeable heads - kept falling apart on me, the spring lock wouldnt keep the heads on
Headlight lens restorer - total waste of time and money. Major fail.
FAIL (i wish i had returned them, but they were either free or past the 30 day return period)
Nail punches red/yellow/blue ones - business end mars up with one nail!
Picks - wimpy, heads bend and break too easily
Black free screwdrivers - phillips 1 tip just snapped while trying to take out a rusty screw. I thought my regular CMan screwdrivers wore out too quickly, these don't last 1/4 as long.
Snap ring pliers (non interchangeable head) - way too wimpy. bend too much
3Ton orange steel hydraulic jack - has started to leak after 6 months. Meh. Better than my duralast jack.
The cheap tap and die set, is pretty much just used to clean threads. I tried cutting external threads 5/16, and wound up chipping off the teeth of the die on the second rod.
Marginal pass (They work)
Pliers - blue handled - teeth mar up easily, seems like soft metal, not hardened. plastic handles crack/break apart too easily. The tongue in groove pliers are in the FAIL category- the metal bends when you squeeze the handles so much the pliers skip out of the setting to the largest position.
1/2 in torque wrench - 5-6 ft lbs off on calibration
Scissors (black multipurpose) - feels wimpy
Cross pein 3lb hammer - handle came loose after 5 months, got warrantied.
Rotary dremel tool (weak motor, but works)
12" plastic wood clamps - a little unstable and weak
Pry bars with hard black handles (they bend a bit)
Dash trim tools (blue) (they bend a bit too much)
Drill bits (titanium coated) (dull somewhat quickly)
Screwdriver bit sockets (phillips heads cam out a bit too easily)
Blue 1700psi pressure washer (weak power, barely passable to wash away algae from brick walls)
Reciprocating saw blades. Wear out quickly, But good for 2-3 projects.
PASS (I'd buy it again)
Offset box end wrenches
3/8 breaker bar
Metric impact sockets
Stubby claw hammer
Ball pein 1.5 lb hammer
Grinder cutting wheels/grinding wheels
Flap disks
Black drill
4.5in angle grinder, black
Rare earth magnets
Free flashlight
3/8-1/4 dual ratchet
Torx set with 1/4 bit adaptor
Knee carpet kicker
24" rip guide
Hex bit sockets, regular and ball end
Push pin pliers
1/2 metric deep well sockets
1/4 torque wrench
3/8 locking extensions
Drill point gauge
Black rubber wheel chocks
Drill bits HSS
NEED To Use more before deciding
Oil filter wrench
Wobble extensions
Dial indicator
Circle cutter
