The Harbor Freight PASS/FAIL Thread...
groucho
I buy those little air powered die grinders when they're on sale for $4.99. I keep a different burr in each of the 4 or 5 I have so I don't have to switch burrs in the middle of a job with my greasy hands. Hell, for $4.99 ya don't lose any sleep when one gets tossed in the trash (which hasn't happened in the 2 yrs yet)
larry4406
Northern Virginia
Harbor Freight 91938 Abrasive Cut-off Saw - Fail
The "2 HP" motor is grossly under powered - the 15A motor draw willingly trips a 20A circuit and stalls readily. The index marks for the fence are not square to the blade but you can compensate by adjusting it with a square and lock it "out of square" to be square. The table is thin sheet metal and flexes so as you cut, the table deflects downward cutting a significant unwanted bevel in your piece - almost 1/4 inch bevel top to bottom on a piece 1.5 inches tall. Mind you, this bevel effect occurred when trimming an end of a piece (stock largely on left side of the blade, making a trim cut of about 1/4 inch). If you are cutting stock in the middle somewhere, it is support by both sides of the table, so the table does not deflect and does not produce this unwanted effect.
I replaced the included 1/8" thick abrasive blade with one from DeWalt (slightly thinner at 7/64) and it cut a little better, but not much.
If all you want to do is make random cuts to make material manageable for throw away, this is a great saw. If you actually want to make accurate cuts with a square and plumb end on the piece you cut, walkaway from this saw.
I am returning it. Not sure what I will get to replace it. HF has a "industrial" saw 68104 for $20 more, may check that out. Not sure how it can be 3.5 HP while still at 15A draw.
The Hitachi's, Dewalts, Milwakee's are all about $100 more and seem to have the same cheesy table.
IONH
Central Massachusetts
It is so unfortunate that no one includes pictures when they make claims like this review did... or better yet, video of use.
I have the older orange version of this saw and it performs as well as I expected. If you push down too hard, the blade flexes and you won't get a straight cut. The stop wasn't square, but I rarely find any of them don't require a little tweak with a real square, big box store or HF.
As far as being under powered, you're probably the same type to complain about air powered grinders being under powered when you jamb it into a piece of steel with all your body weight. If you want a clean cut, let the disc do the work, not your arm. Yes, the stand is sheet metal, no surprise there. It flexing for you is probably another sign of pushing way too hard.
I am not claiming the newer gray ones are as good as the older orange ones, we all know HF quality has become more and more questionable in recent years. But there is a lot of user error out there which is tough to differentiate from with the anonymousness of the internet.
mtkst19
blitzburgh pa
i swung in hf yesterday to try and buy the extended reach cutoff tool. they only had 3 and the were all on raincheck--so i couldn't get one.
however, the hansen knock off socket racks were on clearance sale for 3.77. In addition, all the socket sets looked streamlined-- all similar packaging and "upmarket" if you will. It looks to me that hf is making a push to loose the "cheap" image.
air
100 Ft. Steel Hose Reel - PASS
http://www.harborfreight.com/100-ft-steel-air-hose-reel-46342.html
Seems to do its job just fine, so far so good.
40 Piece Alloy Tap and Die Set - Pass/Fail
http://www.harborfreight.com/40-piece-alloy-steel-tap-and-die-set-39424.html
It's cheap, but I managed to fix some stripped stuff on my leaf blower. I highly doubt it would hold up to any real use, but for the average joe, I suppose it's fine. Oh, the 'T' Handle is an absolute joke, and the tap wrench itself also *****.
6 Piece Socket Organizer Set - MEGA FAIL x Eleventy Billion
http://www.harborfreight.com/6-piece-socket-drawer-organizers-99717.html
Sockets don't fit, nuff said. They should seriously pull this from the shelves. It's a defective product. :mad:
BQuicksilver
BQuicksilver
Black & Orange Bar Clamp/Spreader
FAIL - Used about half a dozen times. The other night, it was about 40F in the shop, tightened it, and the end snapped right off.
FAIL as well.
My Dad keeps friggin buying these....and they keep breaking. I'd bet I've seen 10 break now.:)
BQuicksilver
I have the 4' version. PASS. It was on sale for $10-15?
48" Box Frame Level
Item # 92994 Manufacturer: Cen-Tech
Pass as well. Mine has taken abuse and still working fine.
BQuicksilver
Also the first person to say the Craftsmen torque wrenches are any good. The locking rings always break, the internals come loose, and they don't hold a cal. Just had a fairly new Craftsman fail on me this Summer. Everything I could find online said the HF ones are very good. Ran across a post by a guy who claimed to be a professional calibrator and he said the HF and Husky brand wrenches hold their cal as well as any Snap On. HF wasn't having a sale that weekend so I bought the Husky.
I'll FAIL their torque wrenches. I can't speak to holding calibration, but their "click" is so fine you often don't even notice it. Of course with the big lever on a torque wrench that's bad news to keep turning. Both of mine went to eBay.
rayzor32
Buffalo, NY
the click is weird it varies with how much torque you dial, I use the 1/2" for torqueing lug nuts and its perfect for that one job I dont use it for anything else.
rustynewyorker
Upstate NY
3/8" breaker bars: Pass/Fail. Every one I've had lasts about a year before the end eventually twists off - which is a pain in the *** if you're using it with an extension. On the bright side it's warrantied - in fact the first one I broke they replaced it with a 1/2" because they were out of the 3/8ths.
Impact sockets, deep-well: Pass/Fail. Occasionally you get one that has internal flaws and they crack instantly - I've had one and one store had several sets on the clearance table with one missing from replacements (one had a cracked one right there in the box). Otherwise, they're fine.
4" Grinder: Pass. The orange one died only because after 3 years of rough use it got some sand into it cutting away on some trans crossmember bolts. The blue one's lasted about 18 months now, rough use, no issues, and it was all of $9 when I bought it. By rough use I mean it stays in the back of the truck almost all the time, if I have to go out in the yard to cut up something using a generator it may get dropped in the dirt, mud, snow, etc.
I notice they cleared out the socket racks/shelves, looks like a new line or new packaging coming in for all of that stuff.
3/8"-1/2" combo ratchet: FAIL. First thing I tried it on, a clean bolt, stripped it. Clicks sound like the guts could be plastic. I only bought it because it was on sale and I promptly returned it. (I looked at some ratcheting box-end wrenches recently and passed because they sounded the same when clicking).
Hand riveter set: Pass/Fail. I've gone through three of them; the jaws slowly strip out, they're made for doing like one job. I suppose if you strip the jaws for the small 1/8" rivets you could step up a size and keep going; the last one I used the large rivets until I used them all up and it worked okay. They did exchange it no problem, but I haven't seen them in the store the last few times.
18V cordless drill: Fail. Mine is an older one, but two things happened to it - first, the battery didn't last, it stopped taking a charge after a few months. I had a 14.4V that lasted much longer (had about another year in it at that time) - I only bought the other one because it was cheaper/faster than driving home to get the one I forgot that day. So it sat in the back of the truck and one cold day I opened the door, it fell out, fell about 3 feet to the ground and the top half broke right off at the button. While it worked it was fine, it would be a good disposable piece, but plan for it to not last forever.
14.4V cordless combo kit: Pass, more or less. I see these seem to no longer exist. I had no issues with the kit other than I now can't replace the battery that after several years won't charge, and when running the sawzall to cut metal it only lasted about 10 minutes. After pricing out better quality kits, I just bought a cheap 1000W generator and use the regular tools.
Magnetic tow light kit: Pass. The only problem I have with the damn thing is it's wired backwards so the wires stick out the wrong side of the right light to go across to the left light, some one of these days I'm going to remember to pop off the lenses and swap them side for side to fix that. For $10 with coupon they're hard to beat, I've even used them as trailer lights.
subarub4
Connecticut
Pass: 800 lb capacity transmission jack
http://www.harborfreight.com/800-lb-capacity-transmission-jack-3185.html
It retails for $149.99. It was on sale for $129.99. With my 20% off coupon it cost me $103.99.
The cashier stated that the 20% off might not fly. I stated that it was not a floor jack (no coupons can be used on floor jacks), but a ****** jack. He tried to scan it and it worked.
I used it on the 300lb ****** in my F250.
Worked very well. I figure I got my money's worth on the one job. I was surprised that the big joints in my driveway didn't stop the small casters from rolling.
wow thanks for the heads up.. damn no 20% off on the aluminum jack then :(
mrholeshot
MEMBER EMERITUS
I think I have one or two of these in drawers all over my house. Had I not known about Pittsburg and HF I would be actively hunting a set. Noy only great for the money but just great period. I think I own about 30 of them. I wish I could find them in Torx
The HF ad I saw showed that the following items I MIGHT be interested in getting would be on sale starting Jan 20th. I did not happen to see these reviewed here yet...
Can anyone provide some feedback on these:
Cost: $1
http://www.harborfreight.com/2-x-4-inch-phillips-screwdriver-94707.html
zer0cell
Pass and Fail. I bought this, and as i walked out realized it was bound up/broke. The next 3 I grabbed were as well. I finally found one that worked, and it's been no drama for a year now. i guess draw your own conclusion??
Okay... so make sure I test it well before taking it home.
Looks like the screwdriver is a pretty big hit too. Now for the most important question... does it stink like dirty diapers? :lol_hitti
subarub4
Connecticut
Anyone know about powder coating and if this 30,000 BTU heater will work for the paint?
67856
I have a gas oven and it's not good for that.
Muffduster
Arkansas
Tried out my newly purchased 1/2" deep well SAE socket set (purchased on clearance for ~$12), as well as the wobble extension set (item # 31203)
http://www.harborfreight.com/9-piece-wobble-extension-set-31203.html
I'm mildly disappointed with both. The wobble set has a very poor, cheap looking finish, but I'm ok with that (as long as they work). I used them a few times tonight, with both 3/8 and 1/2 impacts. The retention slots in the extensions are -worthless-. The extensions I used were literally falling off the end of the gun. I replaced the retention o-ring / steel ring on my 3/8 gun last week. It works WELL. Maybe too well, as I've had to pry off a socket or two (Craftsman). These extensions, however, just fall off the gun. I HATE it when sockets / extensions fall off my ratchet / impact gun.
They did give good wobble action, and the 1/2 held up to use with my SO MG725, so those are positive points.
Is this guy for real? You were using chrome extensions with an impact gun? And a beast of one at that?
Oh my.:headshake:dunno:
dodge610
North Canton Ohio
67856
I own a father son powdercoat bussiness and i cure 60% of my parts with a Mr Heater that is like that one and i also use my electric stove all my customers parts come out lookin fine so yes you should be able to use that heater curing time should take approx 15 to 20 minutes in a heated shop.
subarub4
Connecticut
I have some wheels to do and they are 16" I was just wondering..
dodge610
North Canton Ohio
Wheels are our specialty we have done quite a few and they all come out lookin better than new and hold up very well its all in the getting the wheel prepped correctly too bad you dont live closer i could cut you a deal oops guess im not aloud to say that it might be spamming.:)
subarub4
Connecticut
I do have a question about the wheels is it necessary to hang them when spraying? If so I would have to rig something up for that.
dodge610
North Canton Ohio
Yes they need to be hung i went to my local weld supply store and got some1/4 inch brazing rod and made hangers make sure its the no flux brass they make the best hangers to support the weight of the wheel hang them at eye level from the rafters in your garage or shop you should be good to go yu also need to mount the propane heater on a 100# propane tank and set that on a HF movers dolly bingo your ready to cure.:thumbup:
scott37300
Wisconsin
#92374
http://www.harborfreight.com/11-piece-snap-ring-pliers-set-92374.html
Bought 1set yesterday and a bunch were pretty lousy. Misaligned tips, twisted handles. Went in today and opened 4 kits and made myself a proper kit. For the 10 plus bucks with coupon these are hard to be if you get a good set.
This is one of the tools I would not buy from harborfreight. Like you said the tips are all messed up crooked and misaligned. Even if you do put a halfway decent set together they still have weak tips.
subarub4
Connecticut
Im still trying to figure out what is supporting the wheel I'm trying to think how the brazing rod is being used..
and a 100 lb tank that sounds a bit too much don't you think?
I will pm you for more info so we wont hog the thread because Im sure those heaters are seasonal at HF.
motoguy
MO
Yup, I'm for real. My other chrome extensions have worked well so far (Craftsman, SK, Snap On). My main concern with the extensions above is the fact that their retention is poor, and they won't stay on the gun (or hand ratchet).
motoguy
MO
Agreed. These are near worthless. The tips may as well be made of butter. I think I'll have to **** it up and buy some Snap On units.
Wes28376
Lacey, Wa
Have to agree. I received this set for Christmas and broke a tip trying to pull the snap rig off of a CM raised panel ratchet.
PT Doc
I opened up 4 CM raised panel ratchets and all went as planned. Maybe this set is better than the ones with the interchangeable heads. I tried 6 of the 8 pliers.
For me for now I give it a pass.
tsherry
Panel Flanger: Pass
Air cut off tool: Pass
1/2" Torque wrench: Pass
Spring clip pliers: Fail. blew up the first time used.
Air grease gun: Fail. wouldn't work, replacement and second replacement wouldn't work.
Jackstands: Pass
Brick saw (not a shop thing, but whatever) Fail. Assembled incorrectly, came apart after about an hour. Replacement is a Pass, but I also double checked the entire assembly.
Crescent wrenches: fail. Suh-loppy.
Screwdrivers: Pass, but just.
Small socket sets (3/8") used for occasional junk yard work: Fail. Ratchets are plastic and explode.
Flux wire feed welder: Pass
Instant-darkening welding helmet: Pass
4" Grinder: Pass
6" Polisher/grinder: Pass for polishing.
3/8" reversible drill: Pass
1/2" Hammer drill: Pass
Heat gun: Pass
Parts washer: Pass
Higher quality spray gun kit: Pass. Better than my Binks model 7, although the Binks is 35 years old.
Spray gun brushes: absolute fail.
Torx-type screwdrivers: Pass
Security hex screw compact drivers: pass
Stationary belt sander: Pass, but man does it draw power.
Ratcheting tie down straps: Pass on the heavy, uber-fail on the light duty.
Tarps: Pass
Electrical splicing materials, wire ends, wire: Pass
Jumper cables: Fail.
12v compressor: Pass
Tire changer: Pass, but be ready to appreciate all the guys who dismount your tires for you. It's a pile of work.
Wood and general purpose clamps: Pass
Grinding discs: Uneven quality. Some are pass, some are fail.
Sand paper: Same as above
LED flashlights, 2 pack: Fail: Push the button on the back and the guts will blow out the front, lens first. Compress the aluminum housing to crimp the lens, and you have a pass. Last forever, and they're free.
12 ton Hydraulic Press: Pass for the press for light duty stuff; fail for the press plates. they're cast and will crack.
TheDukeofDeere
IL
Used the search feature but nothing came up.
Anyone have any experience with any of the HF air hose swivel connectors?
I have a few Matco branded 1/4" swivels and love them. Found a couple on ToolTopia as well but the HF ones are considerably less than Matco and Tooltopia.
The first one might be the standard grade version, the other two look to be higher grade.
1/4" Air Hose Swivel Connector
Item #46123
1/4" High Flow U-Joint Swivel Coupler
Item #66410
3/8" High Flow U-Joint Swivel Coupler
Item #66413
RAYJAY
UNION DALE PA
Item #46123
Item #66410
Item #66413
don't know if its any help but this is the ones i have from HF got them a while ago there stamped Taiwan on them. they work great also the 1/4 in air ratchet item #34900 is a complete full pass works awesome:thumbup:
motoguy
MO
Looking to add to my toolbox. A quick inventory found that I'm needing these sockets. I'm wondering if HF has any items that will satisfy "daily use" for these sockets? I'll be running the sockets on an MG325 and MG725.
1/2" drive 6 pt shallow chrome SAE
1/2" drive 6 pt deep chrome SAE
--basically, I don't have any chrome 1/2" stuff that isn't 12 pt
3/8" drive shallow impact, SAE
3/8" drive deep impact, SAE
--have basically no 3/8" impact sockets
1/2" drive 6 pt shallow chrome metric
1/2" drive 6 pt deep chrome metric
1/2" drive 6 pt deep impact metric
3/8" drive 6 pt deep impact metric
3/8" drive 6 pt shallow impact metric
787B
Baltimore, MD
Item #46123
PASS.
Been using this one for years on my ratchet and impact gun. Haven't failed yet. Leak a tiny bit, but never gotten worse.
TheDukeofDeere
IL
PASS.
Thanks a lot guys!!!
Good deal, I was hoping they would get the "PASS" stamp.
I love my Matco swivels on my IR2135TiMax and IR2115TiMax impacts, but at $25 a pop :shocking: , HF swivels should certainly fit the bill (pun definitely intended) for some IR die grinders I got for Christmas.
Thanks for the reply! :thumbup:
