subarub4
Anyone every try any of the LED work lights? How is the light output?
. It's not like the reasoning for 2 is well defined.
Wow, it does look good. They must have just put it up.
I still have no clue why they have 2 of the same damn sites. It's not like the reasoning for 2 is well defined.
The new HF site sure does look and act a lot like the Sears site...![]()
About how long on a charge? I will be working in a tight space for about 5 hours or so.
it says only two hours![]()
digging out of prison are we......
they stay bright for about 2 hr on full power about 3 on low power
I don't know any rechargeable light that will work for 5 hr straight
I would not be able to stay in any place like that for that long and if you need 6 hours take 3 lights in with you there cheap enuf
Electronic freon and halogen leak detector. Pass:
http://www.harborfreight.com/electronic-freon-and-halogen-leak-detector-92514.html
Always wanted a sniffer as my truck has a very slow R134a leak that I have not been able to find using dye and soapy water. I stopped by HF today to buy a 3/8" breaker bar and saw this on the closeout table (the box was opened but the detetor itself was still wrapped in plastic) for $35. Opened it up and scanned the engine bay, nothing, went inside and stuck the sensor in the passenger vent and bingo the actual temp control module is leaking.
I bought one of these last year to figure out the leak in my car and couldn't find it. If I stuck the nozzle by the can and opened it, it'd beep but that was it.. never on any fittings.Electronic freon and halogen leak detector. Pass:
nice someone finally reviews this.. too bad no replacement sensor tips.
If this the light your asking about there great i have 4 of them they last a long time on a charge and there a really great pass
I have this light, and have to say that it is great, but mine only holds a full charge for maybe.... 15-20 mins on high, if I'm lucky.
After looking for a made in USA suction gun, like the one shown below, and finding that even the one sold by Snap On is made in China, I broke down and bought one at HF for around $5.
What can I say, It ***** real good.
I give it a pass.
Chris
Maybe a dumb question, but what would one do with this?
Anyone have the HF battery charger #66783 ?
http://www.harborfreight.com/10-2-55-amp-6-12-volt-battery-charger-engine-starter-66783.html
Have a coupon for $29.
My other battery charger is very old.. Will probably get electrocuted with it soon
I don't want to throw away $30 on a HF one though, if it *****, or will blow up a battery.
I had the previous model and took it back. It was pretty junky. The 50-Amp engine start mode was fed through a 15 or 20-Amp breaker. The wire was 18-gauge and the alligator clips were junk. It did charge batteries, but I think you're better off with a higher quality unit.Anyone have the HF battery charger #66783 ?
By "couple bucks" you mean 50% more. The diehard is probably also made overseas.I was on the fence too when I recently bought a battery charger. I spent a couple bucks more and got this DieHard:
http://www.sears.com/shc/s/p_10153_12605_02871222000P?mv=rr
