Between 265 & 485 SQ/FT The Jungle
K
Krang
Hawaii
While I was cleaning up I started thinking about cutoff / scrap storage. My scrap is mostly metal, 6-24" long. I'm thinking either the place its at now, underneath the benchtop, or, in these filing cabinets in the second picture. Anyone have a good solution that doesn't take up too much floor space? That's really what I think I'm limited by...
K
Krang
Hawaii
This drill press and small cabinet. Part of me wants to chop the drill press and put it on top of the cabinet. The other part wants to set up a cart as they are oriented in the picture and leave myself the flexibility of a floor-standing drill press. Either way, it would be on casters so I can move it around depending on the project.
I had completely run myself out of 75/25 cO2/Argon, and 100% Argon, gas.... a few weeks ago. I exchanged all of those tanks today so I'm set and can start sticking together some more storage hangars, probably this weekend.
K
Krang
Hawaii
Finished the last pieces of overhead storage today. One side is tire storage and the other will eventually be a French cleat wall for yard tools and things I use often like the chainsaw, pruners, brooms, etc. the idea being I open the door and it’s all available, and ready to go.
Tire storage complete:
Eventual French cleat wall:
Welding magnets are very useful for positioning and holding when constructing in a container I’ve found:
K
Krang
Hawaii
Drill press station will likely be complete tomorrow. Small cabinet on the left, drill press on the right, still floor standing.
Welded up a rolling frame from scrap I had. My #1 goal was to keep it as low to the ground as possible for stability.
TIG welded this part because I finally had gas and was excited =p
All welded up, test fit the cabinet which still needs to be refurbished:
Casters delivered today. Only 3” high, 500lb rated per, and with a locking brake. Hopefully the small wheels don’t bite me later.
Rust inhibiting primer and paint:
Two layers of 3/4” ply I had left over from cabinet installs. Stainless carriage bolts through the bottom for securing the drill press base. Great news is I can still read a tape and they aligned nicely!
Finished product tomorrow hopefully.
K
Krang
Hawaii
I would keep the drill press floor-standing. It's hard to go back once you cut the post.
That was my conclusion as well. I figured it was a trade off between 12” of width and the ability to drill something taller than 14”, which doesn’t seem worth it.
So I’m keeping it floor standing for sure.
K
Krang
Hawaii
Cleaning up the short cabinet that will move with the drill press. Scrape, then wire wheel, wipe down with mineral spirits, and a coat of rust inhibiting primer.
off to take a load to the dump, might find some other cool stuff, who knows!
K
Krang
Hawaii
Since the drawers don’t have slides I put some thin strips of Teflon tape on the undersides, really helps them slide freely once some weight is in them:
And it’s in the final resting place. I think I’m going to cut some plywood to inlay in the top as protection and a sacrificial layer:
I dig it. Going to give some thought to how I pack it, might use it as an excuse to buy some nice bits only for the drill press.
K
Krang
Hawaii
While the paint was drying I loaded up and made a dump run. I always find some interesting stuff, today was no exception:
Three pieces of 36”x3” bronze 90 - I have no idea what to do with it but I’m thinking edge protection for something nice once I clean it up:
Two toolboxes and some random tools, seem to be some good USA made craftsman stuff:
All aluminum Rockwell sawzall, this thing has some serious torque. Not sure when I’ll use it, but it’s just good looking and it still works well:
Good day today.
K
Krang
Hawaii
Laid some non-slip liner on the top and drawers. Most used bits on top, rest in the drawer. I put my tube notcher in the cubby underneath. So far so good. Probably going to make a holder for my oil bottle to hang off the side somewhere.
K
Krang
Hawaii
The way my family ended up here in Hawaii is the result of my Father. He doesn’t have a mechanical bone in his body, but is a great sailor. In 1982 he sailed a 43’ monohull cutter, a Hans Christian, from Longbeach to Honolulu with my Moms Dad, my grandfather, with plans of continuing on to Asia. The continuation never happened obviously, and that’s how we all got here.
That boat was eventually sold, but my Dad kept the wheel. After sitting in storage for 30+ years it has seen better days, and my plan is to restore it and fab a stand along with a picture of the boat underway, as a Father’s Day gift. I’m not a Father yet, but I think he’s going to like it.
Before sanding:
The wheel is about 30” in diameter, and more intricate than the photo shows. I fear I’ve bitten off more than I can chew. I explored dismantling it, then making replacement plugs and assembling again, but the plugs and interior spaces are all stuffed with epoxy… I doubt I could get it apart without destroying it.
So here I am. I’ve found a good way to get in most areas but I’m having difficulty with the tight places near the handle bases, and the hub.
Anyone have a hack for sanding tight spaces like that? I’ve tried folding a piece of sandpaper around some light gauge metal but the edge just gets beat up.. I’m figuring there must be a bette / faster way.
The dark spots you see are salt damage and I will likely need to remove all the old varnish to get clean wood, so there is some work to be done. Any suggestions would be appreciated.
Bob Heine
Boca Raton, Florida
Krang, you can attack that project with hand tools or machines. If you do a search on Amazon for "detail sanding sticks" there are a lot of products, from nail file style sticks and abrasive q-tips to belts on holders. If you have a compressor, a small sand blaster using mild abrasive media (like corn cob or walnut shell) works well in those hard to reach places. Another option is Dremel-style bristle disks (https://www.amazon.com/dp/B07LD9LJ2C/?tag=atomicindus08-20). I would try blasting with corn cob or walnut shell first, based on seeing that die grinder in the photo.
K
Krang
Hawaii
A small media blaster is probably a cheap tool I should acquire at some point, but I don't have one now. Going to give some emory boards a try since I can just steal them from the Ms. That abrasive cord is great though, if I can find some that will ship to me I'm going to get it just to have it.
Thanks!
K
Krang
Hawaii
Beautiful, hot weather this past weekend. Took the opportunity to drop some trash trees I have been meaning to get rid of. There is something really fulfilling about stacking wood…
Little MS170 killin’ it:
Yes, I do realize dogs on a ms170 are rather useless but I’m a nerd and can’t help but tinker. The muffler and dogs are stainless, probably will outlast the rest of the saw.
