The Klein Tool addiction thread! :)
LXCam
So my jury is in and it’s another f this pos. It’s rare I’m in the field so me being this picky probably isn’t justified. But what ***** with Klein would design a pouch layout that can’t atleast support a complete set of nut drivers in order. It’s not like there wasn’t room.
Ya dropped the rarely used ones in the bottom
genog
Silicon Valley
I need the bit holder/shaft (whatever it's called...) for a 10 in 1 handle
Middle piece in the pic (the part that the bit goes into)
LXCam
Those flush cutters are excellent Jeff. Just don’t use them on the wrong material ;)
genog
Silicon Valley
Well.....once more, thanks again. 👍
But I am past that
Way past
I also did the Keyboard Commando thing...that's the first thing that I tried
Please, to be clear....I don't need the hex bit holder (Part #32556)
Klein calls it a bit holder
but.... it holds the small 1/4" bits.
I needed (past tense) the shaft, also a bit holder that holds the reversible screwdriver bits
The shiny metal shaft that's above and to the left in the pic
That shaft holds the reversible screwdriver bit AND can hold the hex holder bit (#32556)
So, my search took me to Klein's website
The only part that is cataloged is part #32556, which is, once again, NOT what I need
Then called Klein customer service and the nice lady only found part #32556 for me
Klein apparently does not sell that Reversible Screwdriver Bit Holder (the shiny shaft) separately.
So, I went a huntin' on my own
No computer, just did things the old fashioned way, put boots to the ground and found the part I need (that shaft on the left) from a local Tool Flipper Dude
So, I am good now
Thanks to all 👍
Please....there's no need for more links
I am good :D
GJ member @Mr. Roboto posted his D275-5 Klein flush cutters in the "New Tools" thread this morning.
I needed to clean up an install on something and needed a pair - I don't own any - so I drove over to Platt and picked up a pair.
U.S. made. $12 bucks out the door with tax.
I have no baseline to make any comparison with. They seemed to work okay although I was dismayed that the end of the zip tie wasn't actually cut flush. Maybe I'm not using them correctly.
They had some Knipex models for $33, but I only had to cut two zip ties, and I simply could not justify that.
Maybe I'll try that jazzy "Tsunoda" model the guys rave about in the "Tools of Japan" thread. :unsure:
oldpliers1
It’s a nice item for the price, but if you go Japanese Fujiya are the go The diagonal cutters and plastic cutters are excellent, as I buy them for our guys who trim a lot of cable ties, the guys all give them the thumbs up,
oldpliers1
1939 Hardware Age Klein ad pp 53
1954 Hardware Age Klein ad pp 805
1956 Hardware Age Klein ad pp 97
Thank you for the post it’s great ! Just a question we’re the 201 pliers the first of the Klein linesman with their box head ?
^ I think that all depends upon whose catalog you're looking at. ;)
Unfortunately, "black and white" in the world of tool nomenclature is a rare thing... gray being far more common.
oldpliers1
Well, this pretty much settles the debate. “Side cutters” are linesman pliers, and not diagonal cutting pliers.
Respectfully that’s a hard call, I checked some of my stuff and it differs from manufacturer and Country of manufacturer ( diagonal cutting pliers are called side cutters here even though that’s not what the manufacturer says, a bit like a adjustable wrench being called a Crescent wrench in the USA ) Bahco belzer call them side cutters Crescent calls them diagonal cutting , and the linemen’s and long nose side cutting pliers. But you asked a good question 👍
BrandonV
Arizona
Saw this set at Lowes.
These all-in-one nutdrivers always crack me up with their size.
  • Stanley 61-125 Hex-a-Matic nutdriver (patent 3339439)(ebay 364550718737 01).jpg
