The lowly drip pan...
RickP330
Middle Island, NY
Hello all,
I was just out in my garage and immediately got pissed, my wife stacked something on my drip pan and it cracked. I was ready to get mad, but then I though about it. I've had this thing for at least 35 years and bought it at Pep-boys for like $4. It's served it's purpose, and now I get to buy a new tool! I mostly use it to work on and disassemble stuff in and keep it all contained. Especially when it's a dirty job - like this last one, I never got to clean it out and kind of glad I don't have to this time LOL.
Anyway, I really like that it stacks neatly on my 5 gallon general purpose bucket, so it hides really well. It perhaps doesn't need to be so deep though.
So I know you guys have some opinions. I always like checking in first - you lead me down the path I'd never find on my own. What do you like? and what would you recommend. Time to move on!
Rick
R
RickP330
Middle Island, NY
I posted a picture to Grok and described the scenario. This is what it came up with. A little pricey, but I kind of like it....
Rick
Hannahranga
I'm fond of the ones that are a both a oil drain tray and a container, it avoids a fair amount of awkwardness dealing with a spill able container (I am not a well coordinated human being)
mikegt4
sw ohio
My favorite ever was the Rubbermaid that they discontinued decades ago...
But honestly if the one you had was working, grab another and continue on!
I have one, it's my main drain pan although the lid doesn't screw on any more as the plastic is hard and distorted from age. I just use it to catch the oil and then pour it into the empty 5qt jug that the new oil came in and off to recycling. I was disappointed when they discontinued them, best all around drain pan I have ever owned.
Pasha
This Lisle 4.5 gallon one is my favorite, but it's been discontinued. The new ones don't have the splash/overflow guards.
Qualitytools
SOCAL
I still have mine, I just used it yesterday for my Ranger oil change.
NUTTSGT
Northern Central Ohio
I have no idea what brand mine is but it's yellow and has a cap on the spout to prevent slosh spilling while moving it. Once it's drained, I hang it up on the wall by the handle.
ecotec
I have a drain valve, so the vast majority of oil is drained right into the container that I return oil in.
I drain the oil filter bit into a pan like Fedwrench uses. You can pour what comes out of the oil filter very easy.
I put this huge metal tray under all of it, so I don’t get so much as a drop of oil on my driveway.
swsman
Earthbound
I also have one of these when I need to work on the cooling system as it is large enough to capture all the drips that can’t be contained easily like an oil change. It’s available in 2 different size, there is also a smaller one.
I have one, used it when I serviced my F250 transmission. No spills and plenty of extra fluid capacity.
JimDon
If you’re looking for something really cheap and metal, try st. Vincent DePaul stores, or goodwill stores in the housewares department. Or other thrift type stores. Cheers, Jim don
M.Brane
1 hr N/W of LA LA Land
Most auto drip pans won't fit under the bikes so I use an old cat litter box. Then there's the gallons that come out of the F-350s so I have a huge one for those. Then there's a variety of other pans for soaking things in SG or derusting solution. No matter how many I have it always seems I need another.
hasco
I have one like that . I use it for Coolant draining,probably 25 years old.
hasco
It appears the Lisle pans are available at Advance Auto parts online.
JradM
Alberta
I think I've just been inspired to buy a new oil pan. Mine looks a lot like the OPs, it's what I've used for the last 20 years or more and I doubt I spent more than $5 on it.
It's a dirty tub into which I put used oil, temporarily, but thinking about it - it is kind of hard to pour out of and it might be nice if it had a cover so there weren't always dead moths in it. I'm at least going to look at oil pans next time I'm in the store and see if anything catches my eye!
jayemm
up high down low
I have these styles drain pans. The top one makes it easy to recycle oil at auto parts stores without transferring to another container (just dump it in their tank). The open top is for coolant and the spout eliminates the 'waterfall' when transferring to another container. Shoulda had these in my early years for those jobs.
Bert_
NW Iowa
I just use a bucket. Or a jug with the side cut out for when a bucket doesn't fit. Simple, doesn't cost a thing
mikey03
Why would anyone ever prefer a drip pan to a drain pan? You got to jack the car up enough to do the work so can prob fit a whole drain pan. But maybe your doing some work like changing a radiator and not jacking up the car but it’s a real low car and you can’t fit a full drain pan under it without jacking it?
Beerhippie
Far NE Oregon
Because the OP is looking for something to clean parts in on his benchtop.
And all the folks with nice, clean floors in the garage and Euro cars want to keep them that way....
