The making of a table
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Since you guys are talking saws, I hope you don't mind me asking this. Been thinking for a while about modifying a wood cut off saw for metal, swapping the gears to slow the blade down? What do you two think, worth the effort or not?
I have never seen it done before, I am not even sure you could get OEM gears to do this??
Maybe its a question you could put to a thread?
Cheers
R
RivennHewn
PNW
Made some good progress today.
Cut some 1/4" steel for a transition plate between the cast iron leg and the wood top.
I was going to thru bolt the legs/top, but couldn't bring myself to have exposed fasteners on the top. If I had some cool vintage hardware, I would have, but new shiny bolts wouldn't have looked good.
I then routed out for the plate, bolted the legs to the plate, and screwed the plate to the table.
Drilled the tabs for the C-channel legs, and installed them too.
I need to replace the castors, as they are shinny silver and light grey rubber.
Yuck
nine4gmc
Dallas
For vintage bolts, you could take carriage bolts and remove the finish from the head, antique them with vinegar to rust them, then clear over them but I like your idea better. Great job!
R
RivennHewn
PNW
Well, the table has been done for a few days now, but on my commute home I came to the conclusion that the two legs don't go together.
I love them both, just not on the same table.
I'm going to leave the cast iron lathe leg on the table, build another C-channel leg and start yet another table.
Going to have to come up with another idea to match up with the lathe leg.
R
RivennHewn
PNW
Thanks for the idea, 1/2Cup. Just might have to consider that.
While I'm still pondering what to pair with the cast iron lathe leg, I made some progress on fabricating a mate for the C-channel leg.
Love having a stash-pile of metal in the shed!
F00d
brSE
R
RivennHewn
PNW
Toxic,
You probably should have spent the winter here.
We had the warmest winter I can remember.
No snow!
And now, how about something a little less "Table-ish"
G42s
4g2D
R
RivennHewn
PNW
A little after dinner putz'n around in the shop:
s1nj
With a few boards:
TG5z
Actually kinda comfortable.
R
RivennHewn
PNW
Legs completed.
Need to decide on a width, then cut and weld up the stretchers between the legs.
The backs are left long, and will be cut off once I can sit in the chair and determine a good headrest height.
dHnK
R
RivennHewn
PNW
Dang near 70 degrees this afternoon in Seattle. Too nice to be a work anyway.
Came home and welded up the mating C-channel leg. Still need to crank out the mounting tabs at the tops of the legs.
h9Hu
Decided to play carpenter too. Brought home some Jobota (AKA poor man's Teak).
Need to work out the top detail for a headrest but I wanted to see it start to look like a chair.
EPNp
Wifey is going to be happy with this one!
R
RivennHewn
PNW
And an unrelated picture of my job site today.
Das Bierhaus
42' long bar. The longest one I've ever done.
dJHP
R
RivennHewn
PNW
Thanks 1/2 Cup,
Flexibility at work is why I do what I do. That, and I love building stuff.
Pic of the chair frame, all welded up and ready for wood.
wrnF
R
RivennHewn
PNW
Ran out of time this afternoon to get much done on the chair.
I did manage to cut and fit the mitered edge boards for the angled front.
All glued and clamped, ready for tomorrow.
sGeMM
I also drug out the welding table, and did a little clean up of the welds in preparation for installing the wood.
Since I never posted a pic of the completed table, here it is.
NuHJ
And a close up of the light mount, which I'm loving. It just slides onto the top edge anywhere, so it's never in the way and it's super easy to move.
2KyY
R
RivennHewn
PNW
Looking forward to seeing the completed chair.
Did I miss the details on the light on the welding table? Where did you get it?
Thanks,
The flexible gooseneck light came off a demo project I did awhile back, I added the switch and fab'd the bracket.
I have spot and flood LED bulbs, depending on what type task I'm doing.
Good lighting has helped my welding greatly. The eyes don't work like they used to.
WhoWhatNow
Collegeville, PA
That's exactly why I want one. My TIG is suffering because I can't see the weld. Yah that's it....
Do you know how long the gooseneck is? I found 24" 2lbs capacity ones at McMaster-Carr but yours looks longer.
Great work!
R
RivennHewn
PNW
Sorry, I don't have a source. But I haven't really tried.
I'm sure they are out there somewhere.
The one pictured is 4', but I"ve got a couple 2' I'm trying to decide what to do with.
R
RivennHewn
PNW
Not much to show for this weekend besides a stack of sanded boards, and a little experimentation on blackening/ finish for the metal frame.
I thinking I'll be going with Eastwood's blackening solution and Penetrol finish.
cUAz
R
RivennHewn
PNW
Not feeling like working on projects today, but I did a little clean and organize in the shop.
Cut and bent a bunch of coat hangers to hang up all my hardhats.
Un-utilized space up and behind some ductwork there was a gas pipe.
Perfect spot to get rid of some clutter.
w-Vm
R
RivennHewn
PNW
One thing that drives me nuts, is working with indecisive people.
I couldn't decide what to pair with the old cast iron lathe leg, so I'm putting the C-channel legs on the sandblasted table.
I've decided they look good together, so now I can quit driving myself nuts.
Another project done and off the list!
PugetDude
Superstition Mountains, AZ
Great looking shirt with those pants, Rivennhewn. ;)
R
RivennHewn
PNW
Thanks again, 1/2 Cup. I'm hoping to get some better pics this week.
Planning on taking the table to work, were we just started some demo on an another old building. Might even have real photographer, with a real camera help me out.
Cell phone pics ****.
Puget dude,
Got a laugh out of me there, took me a minute to figure out what you were talking about.
Thanks
R
RivennHewn
PNW
Found an easy way to keep all the slats straight, and in plane with each other.
Spaced the frame off the wall, and shimmed it so it sat flat/level.
Slide a board into position, clamp, drill, tap and screw. Again and again.
UIYH
The back board on the seat needs adjusting. It's only about 3/32" out of plane, but it really shows.
PugetDude
UIYH
Gotta get that gig line straight. ;)
R
RivennHewn
PNW
I didn't really need this, but it needed a good home.
azBA
I wonder if PB Blaster enjoys a good challenge?
Vujq
Anybody speak Craftsman?
w9fy
R
RivennHewn
PNW
It's been a slow week around here due to a bad back.
Can't stand, sit or walk for too long. There's been a lot of laying on the floor.
The PB Blaster has yet to loosen the bolt holding the base on the C-man vise.
I've tried heat, and some lite taps with a hammer. Also wrecked my new DeWalt screwdriver when I tried to use a Cresent wrench with it to get the stupid bolt to break loose.
Thought I'd let it soak in the electrolysis tank for awhile.
lTQD
e_Qa
R
RivennHewn
PNW
Some great looking projects. Wish I had some of your metal skills.
Toolfool,
Coming from a person with your skills, that means a lot. Thank you.
I was a cabinet, stair, mantle, trim guy for years. Similar projects to what you do, but my area of interest changed to metal a few years ago.
Compared to others on this site, I'm still working on getting out of the 'novice' category.
Love your shop!
Toolfool
Tallahassee, FL
Toolfool,
Love your shop!
Thank you. Give me a yell if you get over to the island. Love to show off the shop. Maybe you can teach me how to use my little Lincoln welder.
R
RivennHewn
PNW
My back is still feeling less than wonderful, but a few trips to the chiroquackter have helped straighten me out some.
Still keeping myself on light duty, I figured I could at least get the chair slats finished.
Ran an 1/8" round over bit over all the edges, finish sanded the slats, and applied a 1st coat of Profin.
aCpl
The Profin really brings out the color. My favorite finish.
rY7N
PugetDude
Nice job on finishing those slats. I like Daly's products, too- much better than the stuff from the big box stores.:thumbup:
My wife and I were over in Seattle last night, went to Hwy 99 Blues Club under the Alaskan Way Viaduct- they had some unique welded steel tables that screamed "Rivennhewn was here"..... :)
