jshillin
PA
You know it's bad when I was pretty excited when my $82 vacuum showed up yesterday! Not sure on battery life yet, but it definitely has good power for a battery vac.
DFB
Southern VT/Western Mass
So I was doing a little speaker research to see what exactly the loudness factor of the new Milwaukee 2891-20 might be compared maybe to other similar sized BT speakers on the mkt right now. Usually most of those have built in batteries system and often use USB style charging
Since most people don't seldom own multiple BT brands of speakers at least in this price range to make comparisons with it Is hard to know which ones may really be louder at least in measured decibels .
Obviously there can be many other factors to consider when purchasing a speaker too. Things in general like overall sound performance, range and distortion, speaker size, the wireless connection, shock resistance, the IP rating (for water/dust/moisture) even the Manufacturer and warranty that's behind it if a claim may be needed.
And there may be some others things too one can factor like recharge time and/or continuous play, true 360 degree sound., even companion software features..yada yada yada
So this are the numbers I could find online
Milwaukee has 119 DB rating
Bose is 116 DB
Beats is 99 db
UE Boom 2 is listed for 90 DB
UE Mega Boom 90 DB
Harmonic distortion
Milwaukee is given as .28%
Bose .31%
Beats .50%
UE Boom ???
UE MegaBoom???
Trying to be objective but I cannot seem to find a published number that can be associated with the rest of these. FWIW certain reviews mention a noticeable distortion after 75% volume with the Booms but others say it's on par with similar BT speakers in the same categories.
Best I got for now!
:3gears:
a52-830
north of boston, massachusetts
Bose is 116 DB
Beats is 99 db
UE Mega Boom 90 DB
Harmonic distortion
Bose .31%
Beats .50%
UE Boom ???
UE MegaBoom???
one thing to consider here is that the UE and Beats speakers are aimed at younger kids listening to rap music (dont know about Bose. you would like to think they are more worried about fidelity, but these days, who knows)
so, it really depends on the kinds of music you are listening to. as an example, listening to classical music on my kids Beats headphones leaves a lot to be desired, but even Green Day sounds good on my pair of Sony Monitor headphones (every really loud).
cajunfirehawk
Ms Gulf Coast
Youtube review vids out here
and I am sure more if you have time to look...
manwithtools
Lebanon, TN
Anyone else waiting on a 0882-20 vacuum? I've had on one order since 1/06/17 and nothing yet. I called this morning and they are checking with Milwaukee to see when it might ship out to them.
Waiting on a return call now
I finally got my vacuum this week. I'm not as impressed as I hoped to be, but it's doing the job it's intended to.
DFB
I hear you about the different music.
I really have no performance issues with either Milwaukee BT unit using them with the types of music I mainly listen too especially in my work environments. And its not just a fanboy response either. I have 6 different BT 2 are Milwaukee, the rest are all different brands. And I have Logitech usb powered speaker too that is basically designed for lap tops.
When it wants to work it sounds good :p
Worked ok in the beginning when I first got it but cuts out a lot now reading different reviews that seem to be a common complaint with that brand.
Pretty much after researching it all somewhat today I feel the new Milwaukee holds it own quite well. It does have six speakers 2 high 2 midrange and 2 passive radiators. where as some of the others only have 2 each over 2 ranges plus individual speaker components also varied in size from a smaller 1-1/2 inch up to 2 inch.
Seems though that a lot of users want some serious boom boom bass response.
Interestingly also to note was many published reviewers made the point that many of the BT 's in this range don't excel at that and to get a full deeper bass response at least from audiophile standpoint you need to go up the next level
Usually about another $100 increase minimum
Must be the Fuel line :D
DFB
I asked a week or so ago about the Milwaukee Fuel Impacts.
Decided to get the compact and if I need it down the road get the high torque one. Wife encouraged me to get the high torque now rather than have it be an emergency. While at Home Depot getting the high torque, I was checking out the 3/8 ratchet. She said it looked handy and I should just get that too.
:thumbup:
Dived in head first hey :D
one9gt
San Francisco
Seems like she was in a really good mood and missed out on your chance to get the fuel 1/4" impact driver, circular saw and sawzall with 9.0 batteries, the m18 wet/dry vac, fuel hammer drill, 1/4" ratchet, boots to match all your impacts, a few extra chargers and a ton of 5.0 batteries, a few compact batteries, flood light, rocket light, and a few inkzall markers.... and measuring tapes. Prolly could of talked her into a toolbox combo too [emoji23][emoji23][emoji23]
Voi
Western South Dakota
You need the M18 Surge.
Would you suggest that to someone who didn't want to own both a regular impact driver as well as the Surge? My impact driver is on its last legs and I can't see owning both types.
I have a project coming up where I'll have to run a bunch of long timber lag screws. They're torx drive (T50, I think) so I can't use an impact wrench with a socket. I could use an impact wrench with a square to hex adapter I guess. But I'm wondering if the "regular" Fuel impact driver (or the Makita equivalent) isn't the right tool for the job.
My gut reaction is these oil impulse drivers are a good choice for someone who also owns (or plans to own, in my case) a compact impact wrench. To me it seems like there is less overlap between the tools. But I have this "in between" project coming up and I don't want the Surge to come up short.
kctyphoon
Jersey/Staten Island
Got my hardline knife from that eBay seller, $40 shipped - well worth it for the 3.5" model.. that's half the price of retail.. guy has a few more if anyone wants one...
My initial impressions are this - it's all business.. well made, but not exactly a high end knife.. I would not suggest paying retail for this.. if you're willing to spend $80 plus tax - spend another $20 and buy an HK that's made by Benchmade instead.. there's only a grip on one side, the other side has the frame lock and it's all bare metal... if you want / need a knife that you are truly gonna use and beat up at work, this is a great option at a discounted price.. if you instead want one for EDC, and it's just gonna be used for "light duty" stuff, and want something more comfortable and ergonomic, and you were willing to spend the retail on the hardline, look at an HK instead with a d2 blade..
That's my honest opinion.. seems like a very well made, heavy duty knife, but it's not big on ergonomics and comfort when you compare them to another $100 knife... so just keep that in mind.. for the $40 I spent I got a good deal on it and won't be too upset if it gets stolen at work like my Leatherman did.
whitetailhntr
Mine will be here soon, I'll post my thoughts aswell.
dsimatt
Had to waste time yesterday and there was a northern tools nearby so went there and picked up a couple things and they have the Milwaukee wall of lust :bowdown: its a dangerous thing they have going.
I'm a diesel tech and 95% of the cordless tools in the shop are Snap On but must of us are leaning towards Milwaukee when it comes time to upgrade. The different tools they have for home use or whatever makes it a no brainer to go to them once you invest in their batteries.
DFB
I'm not seeing why you cant also use a T50 sq. drive socket in 1/2" or 3/8" on a impact wrench but hey any excuse to get a new tool I say! :D
Obviously I don't have one (at least not yet) as my earlier post points out but its my understanding they can be superior to driving screws under certain conditions being not just quieter but that the pulsing is constant and consistent so it actually does the job a bit faster where as a standard spring and hammer impact seems to slow down slightly as the friction increases
But on the other hand its seems they are not meant as a mechanics tool for hex adapter and socket work because you don't get that sudden burst to loosen fastener :dunno:
I'm of the opinion be best to have both styles but if it just screw driving you want to do a SURGE would suffice
Ign
Butte Peak ND
Sometimes I get so wrapped up in paralysis by analysis I overlook the most obvious solution.
Yeah I was confused on that one too so I just didn't say anything.
In other news I just opened my 6177 chop saw I got from Intl Tool for $139. It comes already loaded w a new blade which I thought was cool.
But the big news is despite being MIC they use a nice heavy, flexible SJ cord. Kudos Milwaukee. Stiff, plasticky cords are more and more prevalent to save cost and they bug the fawk out of me.
tarbellb
Oregon
I had that exact saw... for about a week. The quick adjust fence mech broke, stripped the threads. Other then that it had good power and the base was beefie. Its also what drove me to buying my dry cut saw.
Funny you mention the cord, I recently researched and invested in better cord and plugs. SJOOW, SJEOW, SJO... is the good stuff. Thinner then plain S, and as long as no T in the name its usually nice and flexi.
danski0224
Near Naperville, IL
I have the M18 Jobsite radio and the M12/M18 bluetooth speaker.
In my unscientific testing, the M12/M18 BT speaker is every bit as loud as the M18 radio, and it certainly sounds cleaner/crisper. The BT speaker does lack the bass punch of the M18 radio, and I consider the M18 radio to be the best portable radio that I have heard so far out of the Milwaukee/DeWalt/Makita/Bosch group.
I have not used either with the aux input feature, which may sound better than BT.
I worked with someone that had the UE BOOM, and that sounded pretty darn good for the size.
DFB
:thumbup:
Ok curious which M18 radio it was your did the comparing?
I know the 2792-20 BT often times seems to score high in reviews.
I don't hear too much about the new 2890-20
But the old 2790 was a favorite with a lot of people
Booms do have a solid following for a BT speaker. And they are smaller in size overall
DFB
I just see the 2130-20P Rocket light with 5.0AH battery is an ACME Smoking Deal of the Week.
Take $40 off
So $209 with free shipping for registered users all this week until 3/18
The 2797-22 kit is still only $249
There is a bunch of Dewally organizers and their big cordless spotlight too
JettaGetUpandGo
Pewaukee, WI
The issue may be using a torx socket with a chrome base that could shatter rather than an impact rated torx socket with a black base. While I've used chrome sockets on lighter duty projects with the impact any screw that requires a T-50 bit to drive requires a substantial amount of torque.
a52-830
i agree, you should never use a non-impact rated socket on an impact wrench.
a search for "torx impact" on amazon shows sets that include a T50 starting at 15$ for a no-name set, or 25$ starting for a sunex set.
danski0224
Near Naperville, IL
:thumbup:
Jobsite radio/charger 2792-20
M18/M12 BT 2891-20 It would have been nice of Milwaukee to make this a charger too.
I also have the M12 speaker 2592-20, which is good for low volume use
Ign
Butte Peak ND
Doing a little job at my local non-profit; Milwaukee helps me help the animals! :)
Easyjet98
Mustang Oklahoma
So do most of you DIYers that start out with M12 tools also end up getting unto the M18 tools? I have a start in M12 but the blower and vacuum I'm leaning towards are both M18. Which would require new charger and batteries etc.
DFB
Ya obviously your limted to some extent with the M12 lineup
Fan, blower, wet dry vac all M18. Even things like the 2361 floodlight. They have some ways to get started in M18 though without buying a power tool
With something like this kit
http://www.cpomilwaukee.com/milwauk...m_term=1100101516374&utm_content=All Products
one could get the battery that way and the dual chargers can be found for sale just about all over for cheap
Cripes even I might even have one or two to sell :D
Easyjet98
Mustang Oklahoma
Let me know the details!
bcradio
New Mexico
I have had m12 for a couple years now and just got into m18 this weekend for the new blower, weed whacker, and vacuum. Got many other m18 tools also as a bonus :bounce:
JettaGetUpandGo
Pewaukee, WI
Yup. I started with an M12 drill and impact to replace 18V ni-cad Dewalt. At the time the M12 circular saw didn't exist, so I bought the M18 version. I suddenly had a foot in both doors to buy bare tools in each line as needed.
On the M18 side I use the circular saw and octagon flood light quite a bit, but I always reach for the M12 drill and impact before the M18. The smaller size and lighter weight is just easier to work with and it handles just about anything I ever need them to as DIY. The only benefit I have found for the M18 drill is for hole saws. The few times I need to alternate between two different sized drill bits on a project it helps do have a second cordless drill, but it doesn't need to be the M18.
JettaGetUpandGo
Pewaukee, WI
http://www.cpomilwaukee.com/milwauk...m_term=1100101516374&utm_content=All ProductsD
Wow! The light alone is typically $50 and the 4.0 battery is $120 on its own from CPO, but I'm sure it could be found cheaper elsewhere. I don't need another battery or light at the moment, but $80 for both seems like a steal.
The dual voltage chargers are great too. I keep one M12 charger in the back hall for the jacket battery and gave away the rest to friends/family. There's no reason to have them when the M18 chargers have both. Anyone find it odd that Milwaukee includes dual voltage chargers with the M18 tools instead of a standalone M18 charger and the dual voltage as an accessory?
dacan23
RI
Was comparing the camo knife that comes in the fastback utility combo with my spring assisted one and the hardline that comes with the M12 mag. Think the camo and spring assisted was 3.5" though some places say the blade is 4" and the hardline I think is 3", but the sharpened edge of the hardline is the same length as the others.
The spring assist is nice, but once worn in the regular one opens very easily. The hardline flip is very easy to open, while spring assist would be nice, I think they can be opened equally as quick. I think the hardline has bearings in the mechanism which makes opening so fluid.
dacan23
RI
Could of used the Mid Torque today. Could not get the Fuel 1/2 impact on caliper bracket bolts without a u-joint, though when I did the other side I did try the Fuel 3/8 impact and it just barely broke them loose. Really need that Fuel Mid 1/2 for tight situations.
