X1 Mike
I think hes talking about a 12v plug for IF you dont have a battery. As a backup.
Oops, my bad. I get that, but I have never even thought about a plug in adapter.
How does the internal volume of your airbags compare to that of a full-size truck tire? Have you tried it out on tires yet?
This is another tool that I'm eyeing up to allow me to stay compressor-less in my garage, but the performance of my Ryobi 18V inflator has my expectations low for battery powered inflators. My 18V Ryobi works well enough for bike tires, but it takes several minutes to add a couple PSI to a truck tire.
For discussion sake (since I've never done a flat but more just topping off /adjusting), how long does it run continuously before thermalling out
I don't have the Ryobi to compare, but what's nice with this is you can set the pressure u want and just walk away. It shuts off by itself. It's not suppose to be run for more than 10 min continuously though. 10 on, 5 or 10 off to rest (can't rem if it's 5 or 10). It really is a handy little tool. You gotta get a $5 quick connect and then it's really easy. I haven't used a service station pump since I got it. Never filled a tire up from being flat - but adding 5-8 psi to a tire takes a minute or so.
That little inflator has proved to be a great purchase for me.. it just stays in the car. My tires need to be replaced soon anyway, so i stopped pulling nails out..
Does anyone know if you can have Milwaukee swap out the chuck on the super hole hawg for the quik lock version?
HD has the super hawg bare tool for sale $199. Tempted to get it but I really want to get into the quik lock since all my Milwaukee hole saws are the correct size.
HD $199
I have a question for all of the M12 owners out there. Are there are M12 tools that we should stay away from or not buy? Maybe the first generation tools, other than that? I was looking at the jigsaw or a sawzall. Any opinions?
Anything non-Fuel in my opinion, M12 hackzall, drills, and impacts are homeowner grade, hardly worth anything.
Fuel only unless there is no other version, but...
M12 multi tool, is ok, not great, a future Fuel version would be awesome.
Non-fuel ratchets still some of my favorites even though I have all the Fuels also.
M12 jigsaw is pretty wimpy and slow, again a future Fuel version would be great.
Dont know, but the keyed chuck is prefered so much more than the quik-lok, so your not stuck only buying Milwaukee bits & such.
$199 for the Super Hawg is a great deal, ordered 3 for buddies, its gonna sell out probably soon. Keep in mind there is a Gen2 out now, this is Gen1
Yeah, too good of a deal to pass up. I'll go ahead and order it. If there is a deal on the quik lock version, I'll just sell this one
Why not buy one of these instead? And leave it in? https://www.amazon.com/dp/B0048354D8/?tag=atomicindus08-20You can absolutely swap out the quik lok version with the chuck key version. I'm not sure if Milwaukee would do it for you, but you could always just order the gearbox output assembly, which includes the output gear, bearing, output shaft, and quik-lok chuck and swap them out yourself. I've done it several times the opposite way (quik-lok to chuck key).
Why not try this? https://www.amazon.com/dp/B0048354D8/?tag=atomicindus08-20Yeah, too good of a deal to pass up. I'll go ahead and order it. If there is a deal on the quik lock version, I'll just sell this one
Looking for some suggestions/confirmation here.
The work is mainly tightening bolts from M6 to 1" and drilling a few holes in tight spaces. Repetitive work, daily use - the below list once/day for assembly and about half that for disassembly.
8) 1" bolts ~600 ft-lbf
2) 7/8" bolts ~400 ft-lbf
8) 3/4" bolts ~300 ft-lbf
12) 5/8" bolts ~200 ft-lbf
10) 1/2" bolts ~100 ft-lbf
16) 3/8" bolts - tight
3) 5/16" bolts - tight
2) M6 bolts - tight
The torques are very approximate minimums - all the fasteners use crimped lock nuts so you typically run them down until they seat then let the impact rattle for a few seconds, longer on the biggest bolts.
Drill
1) 1/2" hole + 1/8" pilot
3) 3/8" holes + 1/8" pilot
2) 5/16" holes + 1/8" pilot
Shop is currently using all Snap-On tools
1) PT850 1/2" pneumatic impact (for 1/2" and larger)
2) CT8810A 18v cordless impact wrenches (for 3/8" and smaller)
1) CDR8815DB 1/2" 18v cordless drill
The biggest thing that I want to try and improve on is the inefficiency of having to use the 1/2" pneumatic impact on the majority of the bolts, dragging the air hose from one side of the vehicle to the other and back/forth. The other is the drill doesn't really fit in a couple of the spots causing the hole to have to be drilled at a slight angle.
Here's my proposal
1) Milwaukee 2767 or 2863 High Torque M18 with HO6.0 battery
1) Milwaukee 2852 Mid Torque M18 with HO6.0 battery
1) Milwaukee 2503 1/2" drill M12 with 3.0 battery
Might still need to use the pneumatic impact on the 1" bolts, but can probably use cordless for everything else and/or use both if there are multiple people working on the same vehicle without having to wait.
There is not room for the big 1" drive (the pneumatic barely fits with an 1-1/2" socket length wise.) The length of the 2767 is 1.19" longer than the PT850 but can go with a shallow socket instead of a deep to make up the length difference.
Thoughts/opinions/comments/suggestions welcome...
Why use 2 different battery platforms? Buy any cheap m18 drill. (Unless thats your plan to later say “well we already have m12 too, so why not get “xxxxx” next). The real world difference in size between m18 and m12 drills, (esp with m12 running XC packs) is not nearly as big as some people think. A lower tier m18 drill should still (without looking up specs) be stronger than a fuel m12. Not to mention that getting a drill that you KNOW wont struggle, will get better runtime than a smaller drill that you may be asking a lot from.
And i dont know what current kits are coming with - but if your goal is make this sound attractive, and money IS an object - go with whatever batteries come with the kits and ditch specific batteries “just because” you want those. If the kits come with 6.0’s - great. If not, use what they are bundled with. (Meaning dont suggest a 6.0HD over a regular 5.0 ‘just because’) 5.0 packs WERE the big batteries not very long ago.
And if you go all m18 you can get a 6 bay charger. Or two of them.
I'm assuming the HO pack will deliver more power than a 5.0 without all the bulk of a 12.0.
Where did you find a quick connect for the compressor. Now that I am reading this, it would be awesome of me to go buy one. such a PITA to screw it on every time right now.
I think I ordered mine from Amazon. But you can prob walk into any chain auto parts store and find one in there for like $5 . I think mine is from Slime. It's much easier. Milwaukee should have included one.
This is exactly the one I have. Probably $2 cheaper in a store, but I did not think of that when I bought it.
Slime 20332 Inflator Hose Adapter https://www.amazon.com/dp/B01MY55BT5/?tag=atomicindus08-20
I purchased from Home Depot and the only 2 minor gripes I have are that:
1) I could either get my 10% military discount or the free battery.
I never heard of them not giving the freebie with military discount. I use HD 10% or other coupons with the promos all the time, even Lowes non internet printed coupons work with promos.
Just caught some Home Despot ad for Dewally "ATOMIC" cordless tools.
Is that like a "FUEL"![]()
None of the packages had anything but a 1.3 AH battery wtf![]()
Well, I just converted from Dewalt cordless (way back to the old 18v NiCad stuff) to the Fuel line - still charging the first battery in fact. Can't wait to give this near gear a try.
2) A bag would be more useful than the hard case (for me).
On a good note, the drill bit set was $5 off. Either way, been waiting to make this jump for a while!
