ChrisLS8
2nd Milwaukee tool I haven't liked recently, coworker lost my favorite DeWalt tape and replaced it with a 25' Milwaukee. Standout is low in comparison and used the way I use em the Stanley/dewalts last 6-8 months before replacing, this one lasted three weeks before the tape was ripping at the 4 inch mark.
I did pick up their 100ft tape and will put it through the ringer as well. I don't use that as often for work mostly starting layout but the DeWalt one was ******* junk and locked up after 2 weeks of light use
rmsg0040
Toronto
Used my 0882 milwaukee vacuum earlier this week to clean up under the fridge, the amount of dust build up was insane!
DFB
Southern VT/Western Mass
Curious to specs on those power inverters. What they offer in RUN time vs AMP draw :headscrat.
All I know from my small experiences using a DC power inverter to power my multi chargers is that they don't go very long off a basic vehicle battery before low voltage alert kicks in without the engine running
Locker537
Massachusetts
A few of the online retailers have a special on personal lighting. Pick 2 for $99.
The USB rover, USB flashlight, and USB headlamp are eligible. I have the rover and like it, considering the flashlight and headlamp.
Ign
Butte Peak ND
I can't stand the Milwaukee tapes, but I'm very picky about tapes
Ironically the magnetic tips are the worst thing for a metalworker - at least IME - 'cause it'll grab **** and drops and throw off your measurements when bumping it up to something like a bandsaw blade.
But I also don't like the size, feel or tick marks. I just find 'em difficult to read
DFB
I have two Milwaukee tapes the 25 ft 48-22-6625 and the 16ft magnetic with the markings on both side sides of the tape. Overall they are just about the same size, though some of the 25' tapes Milwaukee are larger
The 25 foot is nothing much to write home about for sure, the end tip is the same as a Stanley Power Lock and triple riveted, the clip holds tight but blade is extremely thin.
The mag has much bigger end catch, and the blade waaay stiffer, belt clip is wire loop not particular crazy over that style but it works ok.
I don't have the general issues the mag causes for others because I don't do much metal working but that big tip does catch pretty good and sometimes is difficult to get out of tight joint
The 25ft was $10 on promo for me and the mag was free so I don't complain too much, but there's ALOT of feedback over broken blades I have read on other talk boards.
What's the new one oh ya the "STUD" :lol_hitti
Ign
Butte Peak ND
Yes I also snapped some of the "wings" off my Milwaukee tape (the V1.0s) 'cause it was just TOO MUCH
In typical Milwaukee fashion they've just tried TOO HARD to reinvent the wheel. Some may like it and that's cool but it's easy to come across as gimmicky
roguegts
I'm considering purchasing the 22" Packout tool box to store misc. supplies in. Does anyone who has bought and used one have any regrets of their purchase?
Bought the Packout 3 box set when they were first released in Nov 2017. Use it constantly and have zero regrets. Ended up with a one of the 15" totes and it's equally awesome.
dacan23
RI
Only regret would be if paying full price. None of the pieces are cheap. Retail of all my packout pieces is about $3400, probably cost me 2/3 of that. Dont know when packout will be on sale again. Last year in the spring one retailer had 30% off all packout which was nice.
a52-830
north of boston, massachusetts
for what it is, it is great. it seems robust, and I dont foresee any issues for a long time. I have a bunch of it now, and dont regret any of it.
I assume you mean this:
https://www.milwaukeetool.com/Products/Storage-Solutions/PACKOUT/PACKOUT-Tool-Boxes/48-22-8424
note that it is ten pounds empty. that is something to consider if you are going to be lugging it everywhere as opposed to buying a stack and wheeling it around.
toddoky
Bowling Green, Kentucky
Thanks for the input guys. Yes, the 48-22-8424 is the box I am looking at. The empty weight doesn't bother me as I'm going to be stashing it on the floor under my tool box at work for its entire life more than likely. Even if I end up having to pay full price ($69 it seems to be) I'll be OK with it as I'm only buying one and am not put-off by that amount for the convenience it will provide me with.
Ign
Butte Peak ND
I think it's been posted but if you need to warranty a 9.0 you've gotta call 855-702-7152 and they'll start a claim and send you a special prepaid box. I just started a claim today.
Ok quoting myself from 1/28.....just received my 9.0 back today 2/26. So, it's not a quick process, figure about a month.
I'm not complaining, merely observing.
roguegts
My old trusty 2650 felt like it was losing its balls recently. Actually the M18 tool that led me down the milwaukee path, several dozen tools amd thousands of dollars later.
Needing a quick fix, picked up the 2853. Dare I say on high it's almost too much, especially with a 5.0 battery. But awesome how compact it is!
Ordered a new brush plate for the 2650, hope i can kick some new life into the old girl.
DFB
I can certainly agree with that assessment. Once these drivers started peaking 2000 rpm 3000IPM or more it takes some finesse if not SOME attention not to JUST slam home a screw into some softwood. I watched a guy split the side casing on brand new prehung door install like that.
Still it's ALWAYS great have a new tool! :beer:
roguegts
Still it's ALWAYS great have a new tool! [emoji481]
Yeah, skinning a subfloor with 5/8" ply, using 1-5/8" deckmate screws, it will bury the head through both layers of ply if youre not careful. Been running it on the mid setting and it's much easier to control.
With a 3/8" socket adapter it will run the s&*$ out of some big lag bolts though!
Ign
Butte Peak ND
I've still got my trusty M12 2450 which was what got me into M12
It still works great and while the newer stuff certainly is a little better I often reach for the 2450 'cause I'm impressed it still works and works so well
dacan23
RI
Well price is now $1500 on the new 56.... that *****
New Milwaukee tool chests finally posted. $1200 for the new monster 56" combo and $600 for the new mobile station. I need to figure out a way to fit that 56" monster in my garage.
https://www.homedepot.com/p/Milwauk...-Chest-and-Cabinet-Combo-48-22-8556/308749708
https://www.homedepot.com/p/Milwauk...with-Stainless-Steel-Top-48-22-8540/306329606
https://www.homedepot.com/p/Milwauk...oller-Cabinet-Tool-Chest-48-22-8557/304688605
https://www.homedepot.com/p/Milwaukee-High-Capacity-56-in-8-Drawer-Top-Chest-48-22-8558/304688606
Surprised the 56 doesnt have 6 casters... it weighs 650lbs!
DFB
Don't much remember hearing that Dewalt came out with brushless Mid Torque impact wrench. :headscrat
I ran a search on the part# here on TGJ and nothing really come up. With all the banter on these forums even though its been out for about a year now, seems no one much talks about it, just most often the Milwaukee Mid Torque and the Stubby :dunno:
awill47
Akron Ohio
first shot at using kaizen foam, this stuff cuts like butter!! super excited not to have these things clanging and banging in the case now! just gotta get another couple of cases for my other batteries and i’ll be good to go. considering getting the packout rollers and a few large boxes for my impacts and what not for four wheeling trips. would be much easier to grab a case with everything in it rather than looking through bags to make sure i have everything. a7935dccd927184c6e7a11694bb37675.jpg
dacan23
RI
I have 10 2x4 sheets of kaizen waiting for me to cut and use in my packout mountains. Thanks for the pic which should motivate me lol
a52-830
while I know that several packout cases with inserts and tools in them are not available anymore (like drivers and oscillating tools), have any of the actual packout cases themselves been discontinued yet?
other than black cases in Europe, have any been upgraded (assuming you view the color change as an upgrade)?
techieman33
Kansas
The tools with packout cases are promo items. So I expect we'll see them again in the future. Probably around the holidays.
macs_rock
Idaho
dacan23
RI
I got 2'*4' sheets, five 20mm sheets and five 30mm sheets shipped for $170 from fastcap directly, cheaper than Amazon.
I bought 1 precut of each box from kaizen inserts for $17 each so I don't have to make my own templates.
Haven't figured out yet how many I can cut from 1 sheet
You can get it from Fastcap and Amazon. Check prices at both places as sometimes amazon is cheaper if you have prime.
https://www.fastcap.com/product/kaizen-foam
This company sells the inserts already cut to fit your Milwaukee case (plus a bunch of others): https://kaizeninserts.com/t/milwaukee
Fastcap seems to be a big supplier of the stuff, either through Amazon: https://www.amazon.com/dp/B007J2JJYK/?tag=atomicindus08-20
Or their own website: https://www.fastcap.com/product/kaizen-foam
I like the idea of dedicating a case to batteries. I think I might have to do that.
PeedoPie
Can anyone that owns the usb rover light do me a favor and see if their charge status light blinks while charging? Went to use mine the first time in months( was fully charged up the last time I used it) and the red light came on. Used it for about 15 minutes then went to charge it. Blinked red for a while, then orange for a while then blinked green . After about two hours I tried it again, and the light was green and the unit functioned normally. Still blinks whenever I plug it it, which according to the manual shouldn't happen. Milwaukee said to mail it in and they would look at it, but if it's normal, whey mail it back
DFB
Mines blinking Green right now :lol_hitti
Which model light is it you have
dacan23
RI
The packout case that comes with the kaizen foam is considerably lighter that comparable normal top case, much less heavy duty also. The foam is pretty much the same as the other foam I got.
PeedoPie
2112-21
Just tried charging my other Milwaukee light and it does the same thing. Weird. That one didn’t die on its own without use though. Should be holding a charge longer than a month or two
DFB
2112-21
My 2114 has been great.
I think I remember someone posting about having similar problems not too long ago on this thread with a USB light but not sure which model
Does it meet the E service requirements or do you have to pay to send it back? :headscrat
a52-830
likely the assumption is that the box can be lighter because it both won't have as much weight in it, because you will be putting things in it cut into the foam, like batteries and tools, and because of the foam things won't be rattling around.
TEKWRX
South Florida
The blinking green light means it is almost fully charged (around 80% I think?). Solid green should be fully charged. blinking read means it's almost dead. So what you are seeing is normal.
[EDIT] Yep, just checked the manual. Here is what it says:
The indicator light will display the charging status:
Red Flashing: Charging, 0-25% charged
Orange Flashing: Charging, 25-80% charged
Green Flashing: Charging, 80-99% charged
Green Solid: 99-100% Charged
Red/Green Flashing: Damaged or Faulty Battery
kctyphoon
Jersey/Staten Island
I messaged Milwaukee on facebook about this same thing.. every time i pick one of these things up after not using them for a few weeks/months - they are almost dead.. their response was they do not diagnose problems online, and to bring it to a service center.. all i asked was if there was a known issue.. apparently there is if we all have similar experiences..
DFB
Interesting to note about these earlier ones. So far I have to say my 2114 has been fully charged only once since I purchased it online at ACME (a 2018 T Day sale I believe) and has shown always green light each time I've checked it and run it for a short time.
