It is still around because in the thirty years I've been around it, it was the first time anyone ever used it. Lobster claws are basically useless no matter where or when they are made. It was fun though.
from my understanding, the other side of that wrench should just have Drop Forged on the other side. I believe that's a Vlchek made wrench. I've seen the identical font on some sometimes have their logo, but never with anyone elses logo.
Well, lobster claw is a new term introduced to disparage Cman raised panel wrenches when they went Chinese.
I have never been a fan of these large wrenches as they simply add more work than a modern narrow wrench. How? The conduit I tightened was in place up against a wall. I had to turn 1/6, then move onto the next hex. A modern wrench head would have fit between the wall and the box, allowing nearly 180 degrees of swing.
I did not throw the wrench away, but once every 30 years is not exactly earning its keep. Our need for a 1" wrench is very low in our shop, we work on small stuff, so 5.5 and 7mm are used daily.
I will say that unlike several other older wrenches I have, this one has almost zero wear/slop.
Because of the serrations, those wrenches ended up being called "alligator" wrenches over here. Most were much larger than your sample, I think they were popular for locomotive work.
I will say your example looks exactly like a lobster claw.
