RivennHewn
Fyrme,
Stairs are awesome. Love them.
Nice work
Nice work
Elevator doors, turned heat shield.
No, I dug them out of a scrap dumpster at a job I was on. I didn't realize they weighed nearly 80lbs each when I went in. At 7' tall, they nearly kicked my *** getting them out by my self.Ooh shiny [emoji106] Were those an Ebay find too?
Audio visual cart repurposed to shop cart/desk/workspace.
You pick this cart up on CL? I swear I saw one just like this up there very recently. Was tempted to grab it myself![]()
So my friend bought a small salsa company. Production wasn't very efficient. A Hobart Simplex dosing pump puts two 7.5 oz squirts in each tub in just over one second. 1/2 second later, you better have another tub ready, or product is going on the floor.
filled tubs are handed to a lidder, if you are good, you can do two at a time with a lid in each hand, another one comes along every second. The lidder sets them on industrial cookie trays, and slides trays of a dozen to the skirter who puts a heat shrink skirt atop the lid of each tub, and makes sure no lids are loose. The choke point is here;
a manually spun 'sculpting turntable' is spun with one hand, another holds the heat gun, and another tries to set the tub in the middle of the table so it doesn't fly off. about 3 revolutions, and the skirt is shrinked. the turntable might hold enough spin for 2 tubs. Except nobody in the crew has 3 hands. 2 operators to keep up with the pump.
So here is my machine, it took my job
Shrinks skirts in one rev at 45, and plays Madonna.
I spent $5 on the record player, and welded it with flux core. The heat shroud started life as a can lid.
Because the robot overlords need to supervise, and our decorating supplies were taken from a 4 year old.
I turned part of a Soloflex workout machine
into my new mailbox post.
Nice. Did you have to bend it yourself, or was it shaped like that right off the machine?
No, that part was made like that from the
factory. I just welded on a steel plate and
drilled 4 holes so I could mount the mailbox.
Sunk it about 26” in the ground and it’s still
a little high I think.
I found it for 30.00 on craigslist.
Huh, how about that. I've got one exactly like that out back in my scrap pile.....
Do you have the square ballast tube, that weighs like 50lbs? I've been trying to figure out what to do with it.
Okay Mag that is cool as ****!!!
Acer66, is the little stuff bamboo?
Looks way better than my Mason bee home.
View media item 85390
Insect hostel turned welder housing.
