Old Man Roger
You never watched Mountain Men?What did you cut the saw blade with?
Are you sharpening the blade with a double bevel or a single?
What do you envision the blades being used to cut?
This blade weeeeeel Keeeeeeeel.What did you cut the saw blade with?
Don't watch much tv. Assuming it is a tv show.You never watched Mountain Men?
Alleged Reality TV.Don't watch much tv. Assuming it is a tv show.
I cut them with a angle grinder with a cutoff wheel. I have a grinder holder that has a grinder mounted so I can cut down with it. I trimmed it up with the blank in a vise then ground and filed it to get the curves.What did you cut the saw blade with?
It’s useful for working on things that are close together.How would you use that?
How do you remove the handle, heat?I repurposed two old screwdrivers I didn't care for and made them into a single custom screwdriver. I filed the tip to fit things like the fasteners that secure the lower engine splash shield on my car. I also think it will work great for those plastic coin cell battery covers. The screwdriver leftovers I guess I could still repurpose somewhere else?
@Beerhippie You make the coolest stuff—-always enjoy seeing your projects.
Beer kegs are 304L and/or 316L stainless steel. Some firkins were once made from aluminum, but not standard Sanke kegs. Since most chemicals used for keg cleaning are caustic, aluminum wouldn't last long (nor would it make a good woodstove).Are those kegs aluminum or steel?
The bike doesn't have a flat. It's just really hot out and it has sunk into the heat-softened concrete.
(on the racks , not the joke
)Aw. hell, I made two of them and if you look closely, you'll see two versions in the pictures.Ha!, nice try.
You make much better bike racks than you do jokes.
Really nice work!!!(on the rack , not the joke
Right you are, I'll fix it.Aw. hell, I made two of them and if you look closely, you'll see two versions in the pictures.
Ha!, nice try.
Really nice work!!!(on the racks , not the joke
Honesty?What stops someone from taking the entire rack?
Seriously, "paranoid" around here is taking the keys out of the ignition. Not necessarily out of the rig, 'though--that would be really paranoid.What stops someone from taking the entire rack?
The only folks who would be prone to stealing stuff around here are the tourists--and it'll be hard to walk off with a full bike rack when we're open.
If you're really worried about someone stealing your $15K carbon-frame wonder while you sit ten feet away, chain it to your ankle.
In South Florida, you can barely leave your vehicles in the driveway without worrying..lol A sport bike, outside, over night! Almost guaranteed to be gone in he morning.lolHaha, fair enough. I guess I am hyper paranoid due to where I live.
South Florida? Likely the entire neighborhood is gone!In South Florida, you can barely leave your vehicles in the driveway without worrying..lol A sport bike, outside, over night! Almost guaranteed to be gone in he morning.lol
Pictures?Built a high vacuum chamber from a beer keg. Perfect SS and electopolished.
No pictures, still have it, I’ll get a couple. Been a while, I want to say we were pulling 10^-8torr, but I’ll double check that. Was used on a particle accelerator. So roughing and turbo pumps on it.Pictures?
How much vacuum can a keg take? Our fermenters have 1/2 Bar vacuum-relief safety valves to prevent collapse.
Since nuclear fusion is still thirty years (or is it twenty now?) in the future, that should be perfectly safe.
Fusion happens all the time! The getting over net or unity is the difficult bit.Since nuclear fusion is still thirty years (or is it twenty now?) in the future, that should be perfectly safe.
My boss has forbidden me from conducting any nuclear experiments in the brewery shop.![]()
I should have said that the boss forbid any further nuclear experiments after my ale-mediated cold-fusion experiment went horribly wrong....Since nuclear fusion is still thirty years (or is it twenty now?) in the future, that should be perfectly safe.
