Use yogurt containers for mixing paint, works awesome and free.
I spend a lot of time in salvage yards looking for parts to use in my project builds. I welded up a quick "bolt on" for my two wheeler to make moving rear ends out of the yard and back" to my truck a little easier.
I used the cabinet from an old Air Force vacuum to make a roll around work bench. Welded on a steel top, bolted on a vise, shot a lacquer base coat and top coated it with some 35 year old Imron that I still had stored away. I use this thing all the time.
Drewski......you have more than one build????? I thought all you had was the truck in your avatar WHICH SHOULD BE PAINTED BY NOW!!!!![]()
And no comments on the state of my shop and bench which needs a real good clean out.
Turned an old steel kitchen cabinet into a kitchen island for my loft.
Made a desk out of a length of roller conveyor, old workbench supports & wood from a tear down for a friend:
Took Ducati shipping crate square tubing, offal from roll bar builds from Izzy's Custom cages and wood from a 100 yr old rehab and made a side table:
QUOTE]
Just looked at your web site.. VERY COOL! I like your work!
JP
Okay......I'm really thinking that we need to see some better, larger pics of this repurposed materials. So far I am VERY impressed.![]()
QUOTE]
JP
Thanks guys, appreciate the compliments. Kevin54, there are more pics on the site/blog. http://architecturalelements.co/
Also the FB page, sees more "in process" pics: https://www.facebook.com/ArchitecturalElement
Have a reception desk and bench upcoming.
That is like my dream box setup. Sady (and don't let the truck brand fan boys know) most of those cabinents are built much better than standard "tool boxes". That thing has actual ball bearing rollers. What are the external dimensions? I found a stack one time that I really wanted (only $100 for all 3 sections) but it was ~48" deep x 55" wide. I couldn't even reach the back of the drawer, let alone fit them in my garage.
I went to the "repurpose" link that Doghouseforge posted up, looked around on there (great ideas on there also) and ended up on a FBook page and ran across this. Although I would not imagine the concrete culverts were cheap, BUT it's a pretty cool idea.
https://sphotos-b-ord.**.fbcdn.net/hphotos-prn1/21386_542038339165952_205035102_n.png
Here's a few. Most I've posted before.
Funnel storage. Some old PVC pipe and a SS trench drain remanent found in the dumpster.................
I love this idea!
I too have tools in a file cabinet.
I love this idea!
The only problem with the funnel storage is that it will attract dirt unless you clean the funnels after every use and even then I would wipe it out before use for an engine, etc.. I keep mine in a plastic diaper pail left over from when my son was a baby (he's 27 now). They stack inside of each other and hardly ever require cleaning. I keep two different size funnels at the shop sink for dirty jobs. Mike
TOXIC......where are you picking up your unique bulbs from? Just like this one, I have never saw one with the reflector like that. I mean we made bulbs at work for aircraft, but nothing like you are showing. I did go to your site and I have to say that you do over the top work. Absolutely fantastic!!!!
Just finishing up a sand blast cabin.
Ordered an old shipping container had it cut down to 10'.
Welded up the open end to fit a roll up door.
Cut a hole in the side to fit a man door.
Put an exhaust fan on the roof and hung lights inside.
Painted the box to match the barn.
Ran the hose from the sand blast pressure pot thru a round hole in the side
of the box and made a holder for the hose from 2 1/2 " pipes
Still need a table to work off of and I am looking for some grate material for that
and I am ready to start cleaning up old gas pumps, compressors lubesters etc.
Do you have any more info on these knives? That is an amazing repurpose!
