Crusarius
How's the jack work on its side like that? How often do you have to reset it? Looks like you have almost enough stroke to do a 90 degree bend?
Voltage is not the concern at all, amperage is what will do the damage.
A 1/3 hp motor will probably pull 7-8 amps when loaded down, I don't know what your rheostat is rated for, but most wall mounted light dimmers/ceiling fan speed controls are rated for 1-2 amps.
Its not the amps that kills you, its the power. P = IV, both voltage and current contribute equally to the dead factor.
Has nothing to do with what we were talking about weeks ago. No one was talking about electrocution, but burning up his rheostat.Supposedly a transmission cart, picked it up at one of those material handling outfits for $25. Added the plywood with purpleheart edging and it's been doing yeoman service for more than 10 years now. The thing can support a LOT of weight. It would be nice if it had locking casters, but I've made due without.
Fiber optic cable spool, converted to a hoop rotisserie for my 55 truck cab...
Did you drill a hole through the cam to get the wire to the top or is the wire behind and out of site in the pic?![]()
my one contribution![]()
The cam is hollow, so I just had to cut the top and bottom off so I was able to run the wire down the cam and the bulb sock screwed right on.
Interesting. I don't claim to be a rocket surgeon or brain scientist, but I've never heard of a hollow camshaft.LS engine cam?
Multi quote:
As an example, if you have three posts you want quote, click the MULTI-QUOTE button on the first two then click the "QUOTE" button on the third. You won't see anything happening when you click the MULTI-QUOTE button but when you click the "QUOTE" button, it brings up the edit window with all three quotes.
Posted this in its own thread but hey, it fits here. Grinder stand made from a GM truck differential...
Good eye and very creative!I have had an oil caddy (a dolly that clamps onto the bottom of a 5 gallon oil bucket) for years that was designed for the old steel oil cans. It is too big to hold the new plastic buckets (they taper and are much smaller at the bottom than the steel buckets), and I have been shimming it with blocks of wood, which wasn't working very well.
At a garage sale last summer I noticed a couple of variable-drive cogged v-belts that were much wider than a normal v-belt. It occured to me that they might work as a spacer to hold the bucket in the caddy. They cost me $3.00 for the pair, one of which appears to be new.
I cut the used one in half and it fits perfectly!
Now I need to find three more old-style caddys.
The second photo shows the other half of the belt and the fit on the bucket.
Do any of you get this company's emails. They have some great offerings to be re-purposed. www.repurposedmaterialsinc.com
Sweet!Good eye and very creative!
It looks like you can get a code for the safe with a couple of easy steps. Just a thought.
Good idea, however no ID# we already contacted the manufacturer. Could take it to a locksmith but its got a fair amount of corrosion from old batteries.
Its safe days are behind it. With me anyway.![]()
A question on repurposing. Saw on another site that you can use a Turkey roaster as a hot tank for small parts. Recommendation was simple green so not a volatile solution.
Has anyone tried this? Thinking of buying a used one to try.
Movin/on
