Above 1200 Sq/FT The Salvage Garage
Strouty
Southern Maine
Went out on the highway, speedometer was still off, so I am trying another calibration. It was doing 70 by GPS when the speedo read 60, so I think I used the wrong RPM for the tries, this will give me an idea and I should know if I went the right direction or not. This is the back of the speedo.
Strouty
Southern Maine
That fixed it, now it reads a little faster than the GPS, I would rather be reading one or two over versus not realizing I am speeding. Now all I have two do is figure out my headlights and it will be 90% ready to work, I still have to strip off the old painted lettering, not really looking forward to that.
Strouty
Southern Maine
Thanks!
That is what I am planning on using, I watched a bunch of videos on removing the lettering from trucks and boats, so I know it should work, just nervous that I could eff up the paint under it. I have some vinegar and that is supposed to stop the easy off from acting, kind of like an emergency situation. I am going to pull the door latches since it looks like they got paint under them. Also want to install all new mirrors, I want heated and power, but I need to understand how they ran the wires from the door to the cab, it doesn’t have any place to do it like a normal door would.
Strouty
Southern Maine
I was going to change those, figure I might as well get some Freightliner or generic ones.
I was looking at what I need to do for a decent receiver tube, going to be a bit of a pain, but I want to easily be able to haul any of my trailers.
Strouty
Southern Maine
Went to get mirrors this afternoon and they had this out in front of the counter.
Strouty
Southern Maine
I am sure I could get some more if anyone else needs any. ;)
Today I need to clean up the shop at TH so I can try and get a few things done on the OGMC, I need to get it off the lift, it may end up on the ramp truck for a bit. Would be nice if I could get it to move under its own power, only need to replace all the fuel lines, all the brake lines, inner and outer driver side fenders and I am sure I am forgetting something.
Strouty
Southern Maine
Kind of depressing working on the OGMC, it has some more serious rust issues than I originally thought, will actually have to remove some riveted brackets and replace them in order to get it inspected. Only good thing is that I already have the fuel tank out, so it will be easier to get to the bracket. I am not 100% sure what my repair timeframe is, but I think it is going to get dragged out substantially as my top priority now is Perk and getting a trailer setup and working. I am also probably going to register Bev to use as my secondary "pickup truck", will be useful for this year, sticker runs out in October and will need more attention at that point.
Right now half the things I want to do are almost undoable thanks to viruses, I figure it is almost going to be like a reset, I will work towards having things ready for when I can get back to things.
Strouty
Southern Maine
Got the maroon burb ready to fix a few things and change over the tires. Found a big rust hole that was covered with tape and undercoating :( oh well.
Tried to remove the lettering from Perk, just the vinyl parts, but the air compressor setup is awful, started to get water coming out of my air tool.
I knew things were not great, but there isn’t even a drain or drip leg on anything, so all the condensed water is going right into the tools.
I guess tomorrow I need to come up with a solution that will work quick.
86turbodsl
Better get a leg up on that drainage. Corrosion increases under pressure. I have drip legs on all my air containers.
Strouty
Southern Maine
Yup, I am going to drain the tank tomorrow, hope I can come up with enough pipe to make a quick and dirty drip leg off the main section. All I need is a up and down section of steel, with a couple drains at the low points.
harley jim
Cleveland Tn..........out in the sticks
I did mine last year, I used schedule 80 PVC I hope it holds up time will tell I guess. I did put a drip leg at the compressor with a valve on it. I just need to run a line from it to outside so it doesn't dump inside. So far so good on moisture getting to the tools.
Sent from my SM-A102U using Tapatalk
Strouty
Southern Maine
Don’t tell anyone else about that PVC.
I used a heat gun, the fake gold leaf is weird, it has multiple layers, the clear comes off first, then the gold turns into sticky stuff.
PelicanPines
Bob Heine
Boca Raton, Florida
Strouty, The traditional glue (size) for gold leaf is oil-based and slow drying so I suspect you are just waking it up. Bon Ami or Brasso is supposed to take the gold leaf and size off quickly (once you break through the clear).
Kev442
Wi
Goo Gone might be your friend too. Used that to get the glue residue off after removing the vinyl.
Strouty
Southern Maine
I have a love hate relationship with goo gone, seems like it is hit or miss for me. It didn’t work well on OMO’s doors, it works really well on glass though. The rubber eraser I have works very well, it takes everything off except the painted lettering without damaging anything else. Also makes less of a mess than any other way, well, except when the stickers or lettering isn’t that old, then everything usually peels off with a bit of heat.
I would be done with the vinyl if it hadn’t been for the water in the air lines. I did buy parts to make up some sort of catch all for the moisture, should be able to get to that tomorrow, hopefully.
Strouty
Southern Maine
It is supposed to be mid 50s tomorrow, except all that is getting ruined by this:
May end up with 6” or more. :(
PelicanPines
I will start... perhaps we should all be bathing in Goo Gone...
I love asparagus… Used to grow it... I prefer eating their young... ok that sounds creepy.
Hope all is melted Strouty... stay safe... avoid people, they aren't worth it anyway.
Strouty
Southern Maine
Got a call this morning, Dad says: "Well, you got your way, employee has given notice". I did tell him that it wasn't my way, but that doesn't matter if he doesn't remember the whole situation, regardless, it will be a good thing long term. Short term is a different story, that will probably make my life a living hell. :(
Snow is still clinging to stuff, my local town has locked down people starting at 5 tonight for next 5 days, not supposed to leave the house at all and they are fining people $500 if they do. I technically fall under an essential service clause, but not sure I want an argument over 5 days. I am going to get some things from the office and do what I can remotely.
