86turbodsl
Nice looking trailer repairs and why were you hauling a combine? That's pretty far outside your usual industrial fare. Do you even have crops over in Maine?
The combine in the picture was pulled by Uncle Willie not StroutyNice looking trailer repairs and why were you hauling a combine? That's pretty far outside your usual industrial fare. Do you even have crops over in Maine?
All brake hoses expand under pressure, the cheap construction OEM brake hoses and the Teflon tubed/SS braided hoses. Generally the Teflon tubed hoses expand the least because the Teflon inner tube is much more resistant to expansion than the synthetic rubber common to OEM brake hoses. Teflon inner tube is far stronger than synthetic rubber. Every motorcycle brake system onto which I installed Teflon/SS braid hose produced better braking and better feel at the brake lever because the hose has much lower volumetric expansion (swelling) under load. Because you sensed swelling with Teflon/SS brake hose does not mean all such hose are the same.I swapped the brake lines on my bike over to braided. As I was bleeding them, I watched them expand and contract (Earl's if I remember right). I never see that, even with chain store brand production style lines. Nope, never going to use braided again.
Strouty. what the heck is the clock spring? My truck doesn't have air bags so need to worry for me. Seems like your burb list keeps getting longer![]()
Isn’t the Clock Spring that bit of plastic that turns off the blinker when the wheel straitens out ?
Nope, they are still using a "clockspring" as it's a hardwired connection with the airbag. When we first put airbags on our cars, they used a horn ring type of connection. There was a high percentage of false SRS lights so the engineers designed the clockspring to provide a solid connection and eliminate the intermittent false codes. The downside is whenever you are working on the steering, you must be careful to keep the steering shaft in the center position as the clockspring will break if rotated too much to the left or right.The clockspring is the power feed to the airbag. It is a more secure connection than a horn ring could provide. I am sure they have some computerized method of doing it in newer vehicles.
I was kinda right, can I get partial credit?Nope, they are still using a "clockspring" as it's a hardwired connection with the airbag. When we first put airbags on our cars, they used a horn ring type of connection. There was a high percentage of false SRS lights so the engineers designed the clockspring to provide a solid connection and eliminate the intermittent false codes. The downside is whenever you are working on the steering, you must be careful to keep the steering shaft in the center position as the clockspring will break if rotated too much to the left or right.
SHHHH!!!!!! He's probably working his **** off filling The Wall of Lista, taking care of paper work, and getting trailers loaded up for the auction. I hope he stays on a roll.Has anyone seen/heard from Strouty?
Strouty You are going to need some of this: https://www.riteaid.com/shop/vaseli...FlFeOM8Dj1QSTu-8qgTFpCLVQYUbdblgaApXfEALw_wcB search for an institutional supplier, as that is going to be aI will most likely have a bit ... over, I still have to find or buy some aluminum Diamond plate, that is going to be a bad one, I think I need 3/8” thick on that too.
Start a post on here with a list of everything you have done, lots of good guys on there who know a thing or 2 about 6.5sIt is a 1996, but we replaced the no name one with an NGK (technically NTK), GM stopped making them and I couldn't find any NOS. The only thing I haven't done and I will do, is a reset procedure to relearn the timing, I should have done it, but the thing started and ran great. I am out of sensors and theories, now I am just throwing spaghetti at the wall to see what sticks.
Yes, because neither is heavy enough to haul the engine in the military trailer. Two questions, why are you buying the military trailer? What is the engine in the trailer? I know you probably already told us, but I'm trying to get out to the shop and do some work.
