Above 1200 Sq/FT The Salvage Garage
Strouty
Southern Maine
I am sure there is a repair induced problem, I just don’t think it was from my end, we have been chasing this issue since I bought it, only problem is that it got worse after replacing the injection pump.
csp
Franktown, CO
I have no interest in driving a new vehicle. I want to make older vehicles like new and drive them until the guberment has to pry them from my cold dead hands.....
How's that working out for you with the vehicles you've purchased?
My newest DD type vehicle, one of four, is 19 years old. There are several others that are toys. I do not want anything with a screen in the dash, cameras everywhere, heated cupholders, etc.
Only one of these four was purchased new and has been under my own driving/maintenance routines since new. The other three were in excellent condition when purchased.
It seems to me like you need to buy better. Stop buying something that you think you can get running just because you get a deal on it. Those rarely work out to be good deals if you don't know 100% what the issue is and how to fix it.
Strouty
Southern Maine
When I first bought it, I knew the previous owner had basically rebuilt everything, I test drove it for about 30 minutes and checked out the normal things, with all the boxes checked off, I thought I was good. Then it was not coming up to full temperature, and would long crank once it got warm. Fuel mileage was bad, no smoke, no real leaks. Changed the thermostats, achieved operating temperature, long cranking got worse, almost wouldn’t start. That was when I bought the Tech 2 for setting the timing, then the Burb started dying at half tank. That was when we started to not trust anything the previous owner did, he had installed a gasoline tank instead of the diesel one, they are not compatible. While in there we replaced the fuel lines, then we found an issue with the fuel filter housing, so that got replaced. Then the injection pump started leaking fuel everywhere. That lead to installing a rebuilt pump and new injectors then we went from long cranks to no starts when hot. Changed the crank position sensor when we swapped the broken radiator and block heater. After finding that pouring water on the injection pump let it start we changed the fuel shut off solenoid and didn’t change the issue one bit.
I am sure there were other things done, I know we swapped in a new PMD in with no change as well, never had a check engine light or even a pending code, except for when we first started it with the rebuilt pump, but those went away after adjusting the timing and have never been back.
I may have to start from square one, it starts perfectly when cold, runs fine just gets terrible mileage and long cranks to no start depending on how long it sits after being hot.
Plastikosmd
Most of this you have been thorough but maybe it has some hints:
Not necessarily a “hot start” diagnostic as that seems to point to worn LP on net
there was a mention of bypassing the glow plug relay and adding a moment switch to allow glow plugs when hot to give that “boost” that is needed with poor fuel delivery at “no start”
maybe something to try
Garage Coffee Roaster
Pittsburgh, pa
I second the above post. I am not a diesel mechanic but, I understand mechanical things and am a google expert. :lol:
It is a strong possibility that your injector pump rebuild was bad from the start. The guys from Diesel place forum said this:
If the fuel pump works, than the issue can be a failing IP or low compression. If you poor cool water on the IP and it fires up, the head/rotor has wear and it has trouble getting prime hot. Its worn.
https://www.dieselplace.com/threads/6-5-wont-start-when-hot.772481/
Strouty
Southern Maine
I would totally agree, except this problem was essentially across two separate pumps, the latest one has taken it to the extreme by not starting, the previous one would only long crank (maybe 15 seconds, then start). I know that we have no fuel delivery issues to the pump itself, just from the pump out to the injectors, it could be, but unless I am the one to redo the rebuild, how can I verify this without buying a NEW pump?
Pittsburgh, pa
Can you test the pressure after the pump and before the injectors with a gauge? You could test it cold and after it is hot to determine if the pressure has decreased.
Strouty
Southern Maine
I know when it is hot there is essentially no fuel pressure after the injection pump, there is no smoke while the engine cranks. Before the injection pump, it has been proven to have plenty of fuel, the fuel filter housing has a drain valve and all you have to do is see fuel coming out when it is open, they only need maybe 3 PSI to keep them running. This is definitely injection pump related, pouring water on the IP would not change how much fuel the lift pump delivers.
Strouty
Southern Maine
I wish I could talk to someone that rebuilds these, it would be nice to know if there is a way to test for heat related issues while on the test stand. Seems that there would also be specs that say it is in tolerance or out of tolerance. I have no issue paying for another pump if it resolves the issue, of course Stanadyne no longer makes this particular pump, so all I can get is a rebuilt one or have one of mine rebuilt. I don't think I will use the same guy we used last time, especially if I put another pump on and it solves the problems.
Strouty
Southern Maine
I have found some NOS pumps that are not the newest version, but the most common one, price is reasonable. Also found that it appears GM still sells them new for about $1500, won't know about stock until tomorrow at the earliest.
Pittsburgh, pa
Here is another thread on warm start problems on the 6.5. https://www.thetruckstop.us/forum/threads/6-5-warm-start-problems.14499/
The '92 and '93 are known for hot start issues, the DB2-4911 IP's in those years develop excesive head-spaceing and when warm/hot don't generate the pressure needed to start right up. (my '93 included) Next time it does that, pour about a gallon or room-temp water over it and see if it starts. If so, you'll need a new/rebuilt IP in the near future. The glowplugs won't come on if the coolant temp is above approx 85-90F on those years.
Don
As for a test ,another poster, suggested this:
For a test
Add a gallon of motor oil to a full tank (fill up) of fuel and see if the issue improves.
This will "Thicken" the mix and if its a pump head issue the truck will likely start a lot better.
The only remedy at this point is to get the pump rebuilt or replace it.
Missy
I don't know enough about diesels, if this test would hurt your engine, but I thought I'd throw it out. Maybe somebody else could chime in on this..
Strouty
Southern Maine
I am going to concentrate on getting the timing within spec and see if it still does this before I go crazy. I also will add the clear line on the return to see if there is any air, but I don't suspect that I have an issue, if air was the culprit, it would still try and start, just run like ***.
Bob Heine
Boca Raton, Florida
I know next to nothing about diesels but wrote some manuals for high pressure hydraulic systems 50 years ago. If pouring water on a hot part solving the issue, it sounds like a critical tolerance is opening up, probably between the pump stator and case. Sounds like your pump rebuilder is cutting some corners (or failing to cut them).
walrus
Maine
Don't put anything in fuel that optic sensor won't like. 1/2 ounce per gallon of diesel of 2 cycle oil to lube IP is recommended by many on diesel place
86turbodsl
I seem to remember a friend of mine having the same problem on a 6.5 years ago. Same issue. Pump wore out and would start to make pressure when the pump was hot and dumped water on it. cooled the housing down and the internals were still big. would start then. it had that weird electronic pump on it too.
Alfman
Can't you get the parts you need off the collection of suburbans (you must have several GM diesels) you have instead of spending money on the parts?
Strouty
Southern Maine
Alfman, are you here just to antagonize me? I am trying not to end up with the same result or make another running diesel not running, wouldn't that be working towards your goals for me? While I appreciate constructive criticism, I am not really sure what you are trying to accomplish.
Life is too short. All the money you spend per year on things that “need” work to be usable for a “hobby” or because “it’s the garage journal way” makes no sense to most of us on here. You claim to be a “perfectionist “, but nothing ever gets finished and most likely never will. Everything is a dream or hope that gets shuffled outside or crammed inside SG when the next idea is purchased.
You seem to make decent money. At your age now and invested properly, you could be very well off at age 60. Buy yourself something that runs, so you don’t have to borrow your dads vehicles all the time.
A lot of people on here try to help steer you in the right direction, but you don’t seem to see it or don’t want to see it.
Sure the used market is crazy now, but what you have invested now in your older suburban collection (15-20 range in various states of disrepair), would have bought something less than 5 years old and actually be reliable and left money in your bank account.
What goals? You don’t have one that’s drivable or reliable let alone ten.
Alfman
No, just trying to understand why you buy so much "stuff" without actually doing, using, completing anything with it.
xtremek
St. Johns, Mi
There's a fine line between constructive criticism and antoganism. And it's not like our hero in this story hasn't been going at this very methodically. And that he hasn't found multiple things wrong, and made corrections.
But you have to admit, you've done a lot to this thing, and I know I can't keep track of all of what you've done.
But my last thought is, I'll be damned if I let an inanimate object get the better of me. And that's not just "No", or even "Hell No", but "OH HELL NO!" Keep at it Strouty, and thanks for letting us ride along.
Alfman
Not a bot. I think most of the posts on this thread are enabler's to keep him going. In a previous thread, he would buy things to flip or keep, and then be broke for a while, complain about it and not know how to fix. Now he seems to be some kind of expert on everything. He's like a kid given a pocket full of money and let loose in a toy shop, unsupervised. Then everyone here fawn's over it (in a weird way, me too), encourages him. Wash, rinse, repeat. His dad and especially his stepmom have him fiqured out as somebody with no direction, yet he blames a lot of it on them or ex-employee.
Strouty
Southern Maine
Back to the burb, I got an answer to the question about testing the injection pump, basically they would need to run a longer test and wrap the injection pump in a thermal blanket while increasing the thermostat to heat the fuel up. That makes me feel better that they can be tested for heat failure. I am not sure I would go back to the same "reputable" rebuilder without having a discussion with them to help bring my trust back. I have found a GM NOS crank sensor, everyone that knows anything about these engines says to only use the GM version. I think that NTK was the maker for the GM part, but can't prove it yet. I would be curious if they would tell me if they were the OEM for the part or not? I will have to send an email out and wait. I have confirmed stock on the NOS injection pump, I now just need to figure out what pump number is better to have, this particular pump is for a 2000 model, but every pump (except the very first one in 1994) has just been superseded by a newer version, so it should fit regardless of year and ECU/ECM. It also looks like they didn't do any sort of upgrade beyond 2002 and the one that I am looking at is a very common one, but technically second to last generation. Interestingly, the Hummers got a Caterpillar control setup at one point with a specially upgraded pump, but they never really went into all out production, this was for the P400 engines that were supposed to be the direct replacement answer to the duramax engine. I would love to get my hands on one of those engines.
Strouty
Southern Maine
This week, on Thursday. I do not think I will be attending, but I haven't officially decided yet. There are people that attend that I haven't seen in a while, would be kind of nice to at least visit for a bit. Of course there tends to be something that catches my eye, so it is always dangerous to attend.....
xtremek
St. Johns, Mi
I'd still go for the ice bag first, since that doesn't require any "outside" help. Good to hear you took the weekend off to regenerate. Hopefully that is enough to get you moving forward again.
speedracer_uk
UK
There's a big difference in "fawning" and supporting, and maybe even being understanding and sympathetic to a lot of situations that we've all battled.
Agreed, who here hasn't gone all in and bought more stuff than they needed at the time and ended up with a workshop full of bits. I know I have. More than once! I buy classic bikes then I end up buying more of the same model for rare bits, then piles of bits for one thing.. then before I know it I can't even find the original bike anymore!
impala4speed
Youngstown, Ohio
It's like strouty show and tell when he buys something and everybody feigns there oohs and aahs. What is there to support? He accepts very little advice. He thinks he's in control, when actually his stuff controls him (just wait until fall when he has to move it all around for snow plowing). He's in over his head. He only buys junk, with big plans to transform everything into transformers and such. Forklifts and loaders with no motor's. He buys storage systems made for commercial applications that he thinks will work in his small garage that if you open the overhead door would give most people anxiety just looking at the collection of junk packed in it.
I really don't understand this phenomenon. If this thread bothers you so much why don't you just move on? And if you think you're being helpful, well, you're not.
