Above 1200 Sq/FT The Salvage Garage
Strouty
Southern Maine
No one sells duplex cable that large without buying a lot of it, I have done two separate cables before and used a sleeve, but it just wasn’t the same. 25’ of 1/0 cable is pretty pricey anyways, then the clamps are about $65 a set, so as much as it sounds like they are overpriced, they really aren’t and you definitely get what you pay for. If I buy two sets then get 10’ of the duplex cable, I can make up some pretty adaptable sets of cables. One set would live at the Hill, the other set would live at the Salvage Garage. I have had a couple occasions where I didn’t have my truck with jumper cables, no way to easily jump a vehicle and that can ruin my entire reason for going to either location. I figure saving the day a few times and the cables are paid for. If they are taken care of, they last forever, I still have my good set of smaller cables from when I got them for Christmas at 17, only 31 years ago. Sometimes good equipment is worth the investment.
gte718p
If you do the math, the 25’ set ends up being about $17 a foot, buying cable and clamps would put me at $400 anyways and then I don’t have the super duper duplex cable, plus I have to make them.
Unfortunately my favorite supplier doesn’t carry the duplex cable anymore, nor the good alligator clamps. However 50 foot of 1/0 welding cable is $340 bucks. 2/0 is $380
A couple of wire ties or some cable lacing and they are one cable.
I highly recommend making one set with Anderson connectors on one end and permanently wiring and Anderson on one or two of your most used jump vehicles. It is so nice to not have to open the hood. Wire up a short piece with the clamps and you can still use them as regular jumper cables if your primary is out of service.
Or if you want to be super fancy, you can put them on both ends and then one set of jumper cables becomes a giant extension cable. It adds $120 bucks or so to the build.
I did it for my F350 and it was wonderful. Didn’t have to drag around 50 ft of cable when I didn’t need it. I mean 25 ft of cable works 95% of the time. However when I couldn’t get close or pull out the extension and now I had 50 ft. I also had a winch on an Anderson as well as 100 ft of 6 gauge and some 12v lights and power tools.
Retctddvr
Hang in there Strouty, taking life one day at a time is the best any of us can do. We're all glad to hear from you, and hoping for the best for you. How's Chuck?
bimmer1980
York, PA
I wish it was that way, but almost no work I want to do has gotten done, I take that back, no work has gotten done except for office work. Even that feels like I haven't gotten anything done. :(
Yup, This would probably align with many of us that work a day job. Whether that may be office work, manufacturing or service, etc. Some days are hard to be fulfilled with a perception of hard to see progress. It can be a churn. Hence, I'm often amazed at the latitude that you do have for much of your working days. The days that are most fruitful is when there is a clearly defined purpose and goal, and it is realistically achievable. Candidly, it is remarkable at the level of bureaucracy in many companies.....
Hopefully it get's better on your end, but just know that many people feel the same way about paperwork... or emails/digital coordination......
Strouty
Southern Maine
I guess I should have put the sander in, it is raining going to be slick as **** tomorrow and I won’t be able to get the sander in and replace mining without canceling the accountant. :(
walrus
Maine
It’s a mess here, driveway is ice, little melting later as temps go up but doubt it melts driveway. Ice *****. Wife almost went it ditch about a mile from house, made it to work safely though. Main roads will clear up. Side roads not so much.
Strouty
Southern Maine
I have to try and get the sander setup, the Fird is inside thawing out.
Glad I came up to the Hill yesterday, the waste oil furnace was out and it would have been a worse problem this morning. That furnace is totally random as to why it decides not to fire, I hope the newer furnace does better, won’t know until next winter though (maybe longer). I plan on bringing in the next tote of oil today too, would be good to let it warm up a bit before transferring it into the shop tank.
Strouty
Southern Maine
The accountant is running late, but I am ready, minus the sander. Got my oil tank inside to start the warming process. I hate freezing rain, makes everything worse.
All the major snow is off the Ford and I am melting the last bits off now, only thing I can’t find is the rubber mat I used for the sander, looks like it is MIA, guess I will have to order another one.
kaymccampbell
Upstate New York
You sure it isn't rolled up in the sander? That's where I'd put it.
Strouty
Southern Maine
I actually think it got tossed out, I remember a piece of rubber that had disintegrated that I threw away last fall, I am thinking it was just **** rubber that wasn't UV stable. I ordered a real 3/8" thick mat that is designed to be in the sun, I may have to trim it down to clear the wheel wells since it needs to hang out of the back of the truck a ways. It is more of a skirt than anything, just there to keep the salty mess from filling the bumper and receiver tube.
Strouty
Southern Maine
That poor U-Joint, it saw salt all year long thanks to snow and boats. We got it taken care of, but it took some effort to get the old caps off after we cut the cross out. At least it doesn’t slam or squeak anymore, vibration is gone too. My back is not so happy, I am grabbing some dinner, had to come back to the Hill to put away the 3500 and the army forklift. I am not sure what tomorrow will be like, I have heard a couple different guesses, so I figure I am ready for whatever the ***** throws at me. ;)
