Above 1200 Sq/FT The Salvage Garage
Strouty
Southern Maine
Thanks guys, not a miracle, just doing things that need to be done.
Right now I have the plow hooked up and I am revisiting the wiring, looks like I left a few things not finished. Have done some temporary wiring to figure out how it works and I now know exactly what I have to do, at least for the plow to function properly. I have not checked the lights yet, but I need to get this thing outside and then get the other one inside. It is supposed to precipitate tonight and I would prefer that the non running vehicle be inside instead of having it melt inside tomorrow.
Strouty
Southern Maine
And the maroon burb is inside. I am thinking it is time to go home, didn’t eat lunch and I have plenty to do at home, at least the truck is inside. Now all I have to do is fix it.
xtremek
St. Johns, Mi
I'm glad things are moving your way. I know how frustrating it can be when it seems you bust your hump to try and get the hill, only to have a bag of poo knock you down the hill.
Strouty
Southern Maine
The last couple days have kind of felt that way, but I knew there was an issue with the maroon burb, it did some funny stuff this summer and all my research led to the injection pump. I was ready to do the repairs, but it stopped having the issue and just kept working. Now I wish I had fixed it in the summer, but I couldn't bring myself to fix it when it was still working. So the maroon one is most likely going to need an injection pump, but I am going to do all the things that should be done and get it over with. The list includes injectors, glow plugs, fuel lines, lift pump, check over fuel lines, vacuum pump, check starter out, oil cooler lines, and a new PMD.
86turbodsl
Has the maroon burb got the funky electronic DB4, or the older one that's cheaper? I have a buddy that his dad had one of the electronic ones that was always a problem. and was quite expensive to get a new pump.
Strouty
Southern Maine
All of mine are the electronic ones. I have not had nearly as much trouble with them as others have had, usually the problem is just the PMD/FSD, so this could be my first actually bad injection pump.
Strouty
Southern Maine
More snow today, should be just an inch or so, then another 2-4” tomorrow. I am soooo excited. :(
I drove Bev the last couple days, but she is a hand full in the slippery stuff, makes me think I should but the bullet and get new traction tires for the rear, right now she is wearing steer tires as I was doing lots of highway driving.
Today I am definitely going to figure out what plagues the maroon burb, that way I am not just blindly throwing parts at it. I will still probably replace a bunch of parts, but if it is not the injection pump, I would prefer to not spend all the time and money for no reason.
Strouty
Southern Maine
I agree. When I am done, I should know the true issue.
Spent the day getting things situated, now I need to work on putting stuff away, we moved way too much stuff and moved it quickly, now I need to sort things and put tools away.
Strouty
Southern Maine
Dump truck looks like it will need some parts to dump again, need to check with manufacturer about availability, most likely will replace entire pump due to costs.
Clark is inside.
Strouty
Southern Maine
There is actually quite a bit of room, once I sort some of the **** and put things away, it should be better.
Going to work on wiring up lights and things for the forklift today, also need to investigate the burb. They said we were getting another 2-4” of snow, I think I have 3” already and it is supposed to snow until about 5, tomorrow is supposed to be colder, then Thursday will be low teens, can’t wait.
rmalkow2
Brighton, MI
Too early for this much winter already. At least you are ready for the white stuff. I was hoping for a warmer winter but now I hear the forecasters are changing that prediction for this half of the country.
Your shop looks great actually. You are bringing vehicles in and out as needed and have room for repair work etc. The place is functioning nicely.
:beer:
kent_323is
South Dakota
Hey Strouty,
I just finished reading through the entire thread over a few days. You've made a lot of progress in the shop, and you should be proud of that!
I like some of the vehicles you've got, particularly the 6x6, and that 37 Dodge. I'm also into tracked vehicles, can you share some more pics of that little tracked vehicle you posted a little bit ago? Check out the links in my signature for some of the tracked projects I've got going on.
For keeping track of projects, I use some simple tools....
Colornote on my smartphone: master list of big picture projects, and then individual lists for specific projects. I list at the top items that I need to buy, and to-do items. As I finish items, I list DONE and the date and move to the bottom of the list.
Since my smartphone is almost always with me, I can easily add things as I think of it, and it's with me when I'm in the store buying things.
I also keep a small whiteboard in my office, and I have my top priority items listed there. Having that visual reminder helps me stay focused, and not get sidetracked.
On the Mill, Lathe, drill press... what's the main thing you're interested in doing with those pieces of equipment? I use my mill the most, so handy for a wide variety of fabrication.
I feel your pain on the burbs, especially the one with the starter issue. I had a starter go out on my 3/4 ton chevy truck, but fortunately it was in the parking lot of the parts store. I ended up changing the starter right there after getting a ride home to change into shop clothes. Access was decent, but it's the 6.0L gas engine.
I've got many other projects as well.... I feel your pain with the projects, but I also enjoy the thought of them, and most of them I have de-prioritized for now while I focus on the top priority ones.
I look forward to future posts, especially the vehicle ones.
86turbodsl
You have come SO FAR from where you were. I am proud of the work you've done. You've got 3... *3* vehicles in your shop to do work on them. GOOD JOB!
I hope i can make HALF as much a dent in my shop as you have made in yours. Well done sir!
Strouty
Southern Maine
Thanks guys, been busting *** on Clark, totally redoing the wiring, I have a buddy that makes fuse and relay panels and we are doing a custom installation. I am using this as practice for the M37 and possibly the J5. Should be done by next week, will have all the lights working too.
As for the snow, we are closing in on another 8” so far. I measured this morning and it was over 4”
Strouty
Southern Maine
I am bummed too, we could be having a great time. Instead I am here stuck with 8” of snow and no vehicle to safely drive. Bev weighs about 12k pounds with 8k on the front axle, basically I have to put it in neutral when I come to a stop light as the automatic trans tries to overpower the brakes. It is downright scary. I am going to wait for a while before leaving, hopefully the roads will be better and traffic will be less. I need to have Clark movable tomorrow so I can get the plow lights figured out on the black burb, really annoying that I can’t plow after dark, the ford has no alternator and the burb has no headlights, go figure.
xtremek
St. Johns, Mi
It'll cost you a round trip plane ticket from Lansing, 4 cans of cashews, 3 bags of cheese cubes, and ton of diet coke. Good luck with getting your toys back on the road.
Strouty
Southern Maine
You could have shot for a Lista, but the other stuff sounds like a deal. ;)
I figured out that the high beams were working on the black burb so I plowed, then tilted the lights down a bit and drove it home. Hopefully it will start this morning, it is only 20, but I am not sure it will start and it is plugged in. :(
I think I finished cleaning up the snow at the house around 11:30 PM, but it was still fairly warm and there was no wind at all. Of course around 1 AM the plow went through again, just hope he didn't make a mess of things, whatever is there now is probably staying there for a bit due to the fact that there was lots of water draining across the front of my driveway, so it will freeze.
Should have the forklift running today, fingers crossed.
Strouty
Southern Maine
I may have enough room, but actually doing work is proving to be an exercise in futility. I need to spend a week in here just organizing things. I needed some plow wiring parts, my buddy thinks we can make everything for a lot less, so I may hold off on installing that stuff for now.
PelicanPines
Time is money... big money... if it's gonna take you a bunch of time to make the wires you need... Ponder the true savings. Waiting is also time... that has a value.
Strouty
Southern Maine
Today, money was money, time was wasted. I keep trying to be conservative with estimation of how long things will take, but I guess I need to back off my estimating even more. Tomorrow will be sorting and cleaning, I have found a bunch of things that should be grouped together, today was an eye opener, I had to place an order for a bunch of things that I "knew" I had, but couldn't find anywhere. Maybe the stuff will turn up later, if it does, great, if not, then at least I ordered what will be needed for the next project.
Bob Heine
Boca Raton, Florida
I always find those things right after I install the new ones. Then I keep the stuff for "the next time."
Strouty
Southern Maine
The stuff I am buying will get used, this is just the first of my projects, almost a test of sorts. Once I get into the next couple, I should know where the stuff is, I hope......
Strouty
Southern Maine
Labeling will help for sure.
7 degrees right now, high of 17 today. Will find out if the burb will start, I plugged it in when I got home at 9:30 last night. Wish me luck.
Strouty
Southern Maine
That is not good, hope it starts too.
This morning I need to stay clean, then after dinner I can decide to either get to the grubby stuff or just go home. I guess it all depends on how much I overeat or how good the cook is. ;)
Happy Thanksgiving to all of you guys and gals!
Strouty
Southern Maine
My burb started no problem, I guess I am not remembering things very well last year. Plugged in with the 5 glow plugs it started with half the glow cycle no problem. Maybe I am just losing it?
I am at the shop now, need to fix the handle to a shovel. This shovel has some meaning as it was my GF’s late Dad’s shovel that broke and he wanted me to fix it, I did, then when he passed, I commandeered it again. I have fixed it twice now and it gets worse each time. Probably have to make a new handle next time.
Strouty
Southern Maine
One of the top ten worst thanksgivings I have ever had. Got trapped in a corner so I couldn’t get out from the table without have nine people move, then my GF makes desserts, yet one base pecans, the other is all marshmallow, both of which I hate. To top it off no cranberry sauce at all.
Strouty
Southern Maine
I am a jellied cranberry sauce type, I could eat it out of the can. I am not a fan of fresh made stuff. I would have reported them, but I thought calling 911 was a bad idea.
Sifan
Southern Illinois
I can relate to the 911 dilemma, we had no dressing, none, zip, nada ????
Girls decided to go with baked cheese hashbrowns ... why ask me 4-1 is the same as 4-0
I do have 4 pumpkin pies in my fridge ++++
