xtremek
A couple of days without a Strouty update? I need my Chucky/Burb/trailer fix. I'm almost to the point where I'd settle for a cat/Expedition/hand truck.
How the heck do they check your filter? Make you take it off and cut it open?It doesn’t take hardly any of the red dye to contaminate everything. They can also check your fuel filter if you think having two tanks will trick them.
Yes, of coarse.what i'm getting at is, if you want to check the color of the filter paper in the filter, don't you have to destroy it?
This was in response to "they can check your filter too", so am i to believe they can pull you off the road, make you take off your fuel filter and cut it open on the spot to check for if you ever used red fuel? How would they prove you didn't use it on the farm and you have clear in the truck now? If i'm sneaky enough to have 2 tanks on board, i promise you i'm sneaky enough to have a switchover valve to run clear when i'm being checked. Hypothetically. I don't have 2 tanks, but just saying.
FWIW at work we store sheet steel on pallets on shelves, and have a rack like that but much narrower for offcuts and remnants.right now I don’t have any good way to store sheet steel, except leaning it against the wall.
