Is that a CV2?I think I probably bought into the Festool track saw system when it was first released in the US. I previously had been using a homemade track with a Makita circular saw. One of the rubs with that was the inability to plunge cut and the awkwardness and weight of my homemade system. I remember seeing an ad in Woodworker News for the Festool system and immediately knew I had to have it. A track saw is definitely one of my most used fabrication tools.
Yes, it was originally supposed to be for the wife because she's always wanted one, but since she never drives it, I wish we would have bought a Fourgonnette instead. Not that I don't like the 2CV, but because I could load a Fourgonnette with tools and materials, I think I'd actually use a Fourgonnette a lot more than I drive the 2CV.Is that a CV2?
I like CV2 but the Fourgonnette would be defiantly my choice too.Yes, it was originally supposed to be for the wife because she's always wanted one, but since she never drives it, I wish we would have bought a Fourgonnette instead. Not that I don't like the 2CV, but because I could load a Fourgonnette with tools and materials, I think I'd actually use a Fourgonnette a lot more than I drive the 2CV.
I think people eventually become a fan of the tool they own.
Vacuum? Sometimes I use it, sometimes I don't. For the track saw I have a vacuum drop from the ceiling, it never gets in the way or drags when using the saw.
Nothing fancy. The main vacuum line is above the ceiling, there's just a stub out in the ceiling. The gate is on the other end of the branch. Ceiling surface is 1/2" ply. I use the same overhead line for things like handheld sanders and for the router table.Got any pics of the vac setup to share? I'm wanting to do something similar
While certainly do-able the eventual downfall to systems like this is doing math for offsets, bit sizes etc.
I live those Porter Cable saws. Bought mine around 2000 while working at sears.Here's a jig I made a long time ago from a commercially available clamp/guide. It does eliminate the math:https://photos.app.goo.gl/XXCtXmZAPUGeE3Td8
Love this right on. The bevel was a big part of my decision to upgrade from a circ saw that runs on track to a real track saw.At this point if you havent bought into a track saw system you are either
a) not needing that kind of accuracy and speed
b) love the "set up time" and process
The fact that a track saw will hold X + Y + Z axis (some models for angle cuts) is clearly an advantage
add to that:
superior dust collection
splinter reduction
plunge safety
blade to shoe edge offset for tight cuts
ability to 2x 3x etc... track length easily
Do you, but please dont say they are basically the same thing
Yes. Cutting bevels is one advantage of a proper track saw versus a circ saw with an adapter plate that runs on track. So if you look back on this trhead, you will see I have both types, what I would call a proper plunging track saw, and a circular saw that has an integral groove that runs on track and I use them both!So is this the advantage of an actual track saw over one of the clamp on styles? I see that kreg has a couple models that you attach a circular saw to a sled on their track, and I thought that would work well enough for breaking down sheet goods.
Where are you getting the modern sealsLove this right on. The bevel was a big part of my decision to upgrade from a circ saw that runs on track to a real track saw.
In carpentry, just being able to do a 5 degree bevel is huge. When I was making windows, I installed all my sills at 5 degrees with bevels inside and out for a nice plumb fit and no gaps to collect rain (despite flashing)
I made the new jambs out of pvc, again angling the sills 5 degrees with the outside face plumb with the ground for a nice finished appearance. Track saws can also plunge to a depth so the capillary stop groove under the sills was possible.
Here they are ready to get installed. Most of the cuts were just cut to length. It’s the bottoms of these that really needed the track saw.
Here they are installed. Notice the inside edge of the framing all nice and plumb.
Now I could have done all this with a table saw, but I don’t own a table saw and that’s kinda the point. This is my future home, not a woodshop. I move my stuff to clear the work I’m doing.
Can’t really see from the picture but the sash are the originals from 1912, and the glass is original. We actually removed the panes, polished them with cerium oxide and reinstalled with tradition glazing compound.
In case anyone asks- no I didn’t want double pane insulated glass. I like the crystalline wavy glass these windows have. From outside, they shimmer as you pass by. From inside, there’s an impressionistic blur when you look quickly, but if you stop to gaze out, you don’t really see the distortion. The sashes run against modern plastic seals like any other window and are as air tight as the best windows. (That was tricky). I think air infiltration is the bigger energy loss with windows. Insulated glass is 2 or 3x better than single pane, but 2x r1 still ain’t good.
I can't speak for AEAdam, but I got mine on Amazon. In 2020, it was $5 for a 16' strip. Looks like the price is even better now.Where are you getting the modern seals
