zmotorsports
***** about the gauges JB, but daayyuuuummmm, that intake is bad ***...
Time will tell, but I'll get a group of messages out when/if we make it down there.Just let us know when and if you want to meet.......
I was getting some parts for the Lemon yesterday and a guy came in with a battery he had that was 4 months old and a cell died, sadly sometimes these things just happen. The best part is I had a newish good one on the shelf ready to go on.Awesome!!!
I understand all too well the battery ****. The suburban we bought the battery was enough to start it and drive it home from the dealer, but I let it sit 2 days, and it was a block of ice!
I am making progress too, got the 350/60e mostly out. just need to disconnect the rear u-joint straps but couldnt't find my 11mm wrench, so i gave up for last night lol.
Wow Mike, I don't ever think I've seen you get that excited before.***** about the gauges JB, but daayyuuuummmm, that intake is bad ***...![]()
If I was good with GIFs or MEMEs I'd post one from the original Godzilla movies, but that is more work than I want to deal with.Godzilla is ALIVE!!
Come to find out, yeah they are not an 11mm lmao, they are 7/16". One of the only non-metric threaded bolts on the truck.Those being 11 mm is still hilarious to me, it is one of the few applications for an 11 I've had, but done it a ton so just know I'll have to bring it with.
JB
I thought the exact same thing, I was thrilled when it fired to life.The fab on that intake is secksee!
Congrats!
Thank you, I saw someone else use one somewhere else and really liked the idea.I like that JB, very creative!
Thanks for pointing that out, I'll have a look at the substructure more when I get home, you might be saving me some broken or cracked fiberglass.I hope you put a plunger lock on both sides of the trunk. Having it just on one side can put too much stress on it.
I think it will, but time will tell. What stinks is I have so little time left before this outage I may not get to drive it.I hope your oil pressure repair idea works like you hope. Good luck!!
With just one side done a good gust of wind could be heartbreaking.Thanks for pointing that out, I'll have a look at the substructure more when I get home, you might be saving me some broken or cracked fiberglass.
I'll have a look and see if there is more structure I'm not able to see in the area beside the mount, but you have a very good point and could be a bad day if it were to crack the fiberglass.With just one side done a good gust of wind could be heartbreaking.
You are more than welcome to, after finishing this I thought of a good way to use gas struts as well, the fun part will be determining sizing so they would have enough strength to hold it open.
Isn't it amazing how generous our members are?Well, if you just need someone to come drive it, I am available.
I'm afraid I'll have it tucked away in the garage, keys removed, computer pulled, booby trapped etc.Well, if you just need someone to come drive it, I am available.
I know they are an amazing bunch aren't they.Isn't it amazing how generous our members are?![]()
For this being such a little fire within easy reach of the water hose already hooked up I wasn't worried about it getting out of control so no they weren't notified.Was the fire department alerted to you burning again or are you off probation now. Looks like it worked great this time. FYI I was torching weeds and had a few big flames to hose down (ran for hose and turned on) and thankfully no wind here yesterday either so just burnt a few of my brides flowers that should grow back.
happy to see the hood is on and not sure how you got that picture.
if you just need pictures of it driving down the road I’m sure more than a few of us would volunteer.
nice work on the others too.
best of luck with the outage and long hours at work and send us smoke signals or post on our threads if you can cause we’ll miss our regular JB infusions.
Did you torque the wheels yet? It's one of 2 things not crossed off lol.I made a little more progress on the cobra last night, checking a few things off of the to do list that somehow seems to grow slightly the more I work on it. To start off the new air filter showed up, I played with the 4" aluminum piping I had on hand and it just wasn't going to work without doing a pie cut intake tube, that will have to wait for future improvements. Not ideal but it does fit on the throttle body directly as so:
Next up was the 4 point harness mounts, specifically the shoulder mount. I noticed the "bolt" holding them in seemed small, I didn't realize they were just tech screws into the square tubing behind the fiberglass, partially removed to show size:
That wouldn't do so I through drilled the square tubing and installed 1/2" bolts, I only had grade 5 in the proper length on hand so I used those for now, I'll pick up some grade 8 bolts the next time I go to the store:
With those knocked off the punch list here is where it stands:
I hope to get the oil pressure regulator soon so I can install it, but if it doesn't arrive before I leave it'll have to wait until I'm done with the outage, I'm so close to being done I can almost feel the wind in my hair.
JB
I have not, I was going to wait to install the front wheels until after installing the inner fenders after doing the oil pressure regulator work. Not added to the list in the photo were breather vents and the horn button needs to be installed too. Should be a quick short amount of work left.Did you torque the wheels yet? It's one of 2 things not crossed off lol.
You and me both, I've talked to the manufacturer about them but haven't heard back if they were done by a human or a robot, if a human, they are a machine!I love seeing the welds on that intake JB. I could drool over them all day long.
I won't be cutting a hole in the hood of the car, worst case scenario is I trim the motor mounts down an 1/8" but don't really expect any contact.To do list is really getting checked off nicely. I hope you don’t have to cut a hole in your hood too but I guess time and performance will let you know.
in case it matters to you your pics of your gauges on your dash board looked great to me.
Mine as wellJust a big silly grin here for your success.
Nicely done.
Fluids have been checked multiple times now, test drive is a given, cold beverages were used a thinking fuel, could be why I had to redo a few items.Does the completion of one list lead to another list? That seems how mine go.
New items I see;
-check fluids
-test drive
-cold beverage
I've only pulled off one of the valve covers and it looked okay at the time, but I was also planning to replace them with the CNC aluminum ones I have. I also picked up a catch can for use with them that I could use as well. time will tell if I need to go that route. Sadly I don't have the time to figure out the coil situation so the stock valve covers will stay on until next winter most likely.Do the inside of the valve covers have sufficient baffling? I had a loose ring LS7 and a vac pump ( bandaid) that filled a 1qt reservoir for every 20 minute track session once. I rebuilt the motor and vented both covers to the dry sump tank. Guess you will find out if you need a catch can soon enough.
I do appreciate the kudos, it does feel good to have knocked so much out and at the very least I'll get to pull it from the shop to the garage before I leave. I'm surely looking forward to driving it when I get back. The job does get in the way but sure helps with the fun money.JB: congrats on finishing up that long to do list!! I know with a family and a farm with several outbuildings and lots of vehicles you probably have other to do lists too plus that JOB that helps pay for some of this.
you’ve really done a great job so far with this Cobra engine swap and it’s been a pleasure following along. Best of luck with the outage and when you get back to this it should be hot and sunny and ready for a test drive.
It was a good trip, but glad to be back home for sure. Cobra is certainly fun, it really needs a good cleaning though, I hosed it off at a car wash on the way to work today but needs some love.Looks like you had a good trip up north, always hard to be away from family though.
Cobra is looking choice!
