........but do you have a Warthog in the Hidey Hole?
https://vignette2.wikia.nocookie.ne...warthog.jpg/revision/latest?cb=20100401212828
When I saw the size of the beams I figured it was a frame table, not to mention the length you described. Very cool! I'll have to look into the chop saw.
Looking forward to your review of the Evo saw. I want one just haven't pull the trigger.
Do you have any kind of Ac in the hidey hole or is it just smoking hot in there.?
that sounds like a lot of money for a 4 door? be interesting none the less.
I just watched a video by Hand Tool Rescue where he restored a forge like that. Pretty cool stuff.
How did I miss this thread before? Will be looking forward to updates on the shop, tools, and projects!
Thank you for stopping by Mr. Hair.
Probably not but the hose of that warthog should would keep sticky fingered people at bay. lol
Oh that would be too cool to have in there!Thank you for stopping by Mr. Hair.
Love the ruler by the way!
I have thought it would be cool to take a motion following camera , just the motion outputs sent through relays to larger stepper motors and have it control a machine gun looking contraption that didn't actually shoot. Or MAYBE hook it up to propane so it had a good pop and flash.
Some updates to come,
JB
JB, I saw the saw and realized I don't have one. When I searched for it, Home Depot had it for $187.00 (http://www.homedepot.com/p/Evolutio...p-Saw-RAGE2/203633549?keyword=Evolution+Rage2). I don't know why they list it because there are none available in the stores within 100 miles and they aren't available online.![]()
An Evolution Rage2 metal chop saw, I've seen some good reviews about this online from owners not just people paid to review tools. Once again it'll come in handy for working on the table. Check out the teeth on the blade:
JB needs a privacy fence so he can start a real salvage.
I had seen the metal saws but never dreamed they would cut a 6" I-beam. More than once on the same blade. Thanks for the research, Bob!![]()
. Seriously though, that is some pretty good life out of a blade and I do know how good the old stuff is.
While I'm never against cleaning up before welding, you'll find 6011 run hot will burn right through that surface rust and give you a good weld. far different that flux core.
Great find on the Corvette. Can you accommodate the greater weight of the 57 on the suspension? The gear ratio will be great for road trips. Might even go with a Powerglide![]()
JB, with 2.59 gears and a 28" tire, you could get away without running an overdrive ******. Food for thought. The C4 setup should be awesome. The tri-five four doors still carry the same beautiful lines, and there is nothing wrong with a "crew cab" hot rod. I would totally drive a 57 4-door daily.
What is your planned wheel/tire combo?
) I will probably eventually swap out gears to some in the mid 3 range. I could put in factory G44 gears into the Dana 36 to get to 3.07:1 or I think as high as 3.73:1 with aftermarket gears. If the 2.59:1's are too high (low? I can never remember which I'm supposed to say.) with OD I can always lock it out of OD with the 4L60E right?Man moons ago I got a call for a scrap Corvette. I brought it home for $100. He just wanted it out of his shop. The interior was missing and it had two holes cut in the rear deck lid. Other than that it was complete. I sold it two days later for $700 to a guy who just wanted the frame. He was up in the rust belt and his was rotted.
JB, Sounds like things will get exciting with the 57. Will be glad to follow along. Good news on the new job assignment but sounds like it will keep you busy.
Glad the trip to help your brother is working out so that someone can go with you and it sounds great for your mother to go. I'm sure it is good for her to see your brother again.
Be safe
Dwight
Need to see some pictures of your saw results. I may have to have one of those.
Looking forward to seeing some action on the Chevy!
The saw's slow speed was what attracted me (1,450 rpm instead of 3,900 rpm like most abrasive chop saws). If HD doesn't get them back in stock, I may end up buying Northern Tool's Ironton version (http://www.northerntool.com/shop/tools/product_200641810_200641810). Maybe a 20% coupon will show up in the mailbox.
My 1987 Corvette's registration is due for renewal next month. I think of it as my "new" Corvette but it's eligible for Antique plates this year. The C4 Corvettes are the red-headed step-children in the Corvette world but they really are pretty advanced. I can't imagine trying to buy all those forged aluminum suspension pieces for $1,000 and then have enough of a car left to part out for at least that much again.
Andy: I guess you don't realize how soft those I-beams are. If only you could have held them, say for 30 or so years you might. Maybe if you had helped him load them last week or something..... Seriously though, that is some pretty good life out of a blade and I do know how good the old stuff is.
JB: I have an old furnace blower (date stamped 9/27/1957) that moves some serious air around my shop. The newer ones are designed a little differently, but I think you might be able to engineer a frame to hold one up. Too bad our paths won't cross on our respective holiday road trips because I have an extra one. Of course if it is November when you read this, too hot will not be your problem most likely.![]()
Thank you for taking the time to share your different interesting projects! I have enjoyed your humor... I would have walled off the one corner and insulated it for Winter projects, but that is because i really dislike being COLD... love the more door family cruiser. and I am very jealous of the availability of CHEAP duramax's! I have a project of a 40 chevy cabover-crewcab-firetruck... that I plan on putting a duramax in....
THANKS
whats keeping you away from the shop for 2 months?
I'll try to check in on my thread from time to time but don't expect much.
JB - you are keeping busy as always. The lot is looking terrific. I still can't fathom how much you can get accomplished. It would take me four times as long to do what you do. (and I'd have no clue how to do most of it).
Since I see you as the Duramax Whisperer, I wanted to run something by you. My dad has a 2006 Silverado 2500HD LT - Duramax. 210,000km on it. Quad cab, leather, pretty loaded. Fully operational.
Here is a pic when he imported it from the US in 2008.
He is looking to downsize and get out of the RV lifestyle. He is offering me the truck and the camper for $12,000 CAD. In other words, he is giving me a free truck and wants $12k for the camper.
I want to say yes because it is a free truck.... but it's two more things to store, two more things to maintain, two more things to insure etc.
Since you know a lot about that era Duramax, what do you think it's worth? What are the things that wear out? He has already done the brakes, power steering, brake booster, ball joints, rear axle seal.
I've never owned a diesel in my life, so I thought I'd come to the master. My poor Avalanche is just getting over-worked this summer. Last month alone I spent $1250 on gasoline.
Sorry for the derail....
In my neck of the woods, a clean/little to no rust, low mileage LLY/LBZ like that would go for $18,000 USD minimum, probably more if it's an LBZ because they're highly desired.
I believe the 8th digit of the VIN should be a D if it's an LBZ in a 2006 otherwise if it's a 2 it's an LLY.How do you know if it is an LBZ/LLY or other? What changes on the truck in those cases? I'll grab the VIN tonight, but all I really know is it is the Duramax/Allison combo and he has kept it bone stock. Old man driven....
Sent from my XT1585 using Tapatalk
thanks, in my case right now I am too sick to do much. and reading your posts and others, lets me live vicariously through your adventures, and inspires me to get out and work on my junk! plus I seem to spend less on ebay,, except I am buying more storage stuff!!
I forgot to mention that a cobra is one of my favorite cars! I owned a real 427 SC for about 2 weeks in 1974...... a real shelby backup car with history at riverside and sebring! I became a electrician apprentice at 19. when I got my first tax return. I was RICH! a friend in the bakersfield sports car club, had it and the motor was out... and he would let me make PAYMENTS! Well my Dad, girlfriend and tax lady SHAMED ME INTO BUYING A HOUSE because it was a better investment,, INSTEAD...sold the house ten years later and made 30K......... that year THAT same car sold for 1 MILLION..........
here are some photos of my firetruck as it arrived from south carolina. we narrowed a 1980 chevy 1 ton front suspension and added air bags that are too small... then was talked into fixing my 55 ford because it needed less work.... I would love to take that motor and trans off your hands, but my health is not good enough yet. I am so much better that last year! last year at this time my kids were deciding who got what!
i hope the photos loaded??
Now heal up and get back to it so we can see that thing on the road.JB good progress going on over here, the place is looking very green now.
Is Bob coming for a visit to help lift that new table ?
Borgy, that is a cool truck, hope you get back on your feet to start up a thread on it a some point.
Cheers GB
The yard is really looking sharp JB.
I like the Lincoln Tombstone welder, I learned to weld on one exactly like that when I was about 12 years old from my father. We had one on the farm and I wish I had it now if for nothing other than a conversation piece.
Anxious to see your welding table when done.
Mike
FYI, JB is off on a work assignment until November. I hope I got that right.
JohnnieMo,
Sorry for such a late reply but others have hopefully covered it for you. You are correct, all 2006 model year duramax trucks were the LBZ but the early ones were not as powerful as the later ones. That is a screaming deal on that truck and I personally would jump on it let alone if it comes with a camper. At about the mileage (Kilometerage?) that truck is likely to need the injection pump and water pump replaced soon, and injectors before 300,000km. Another thing to consider is the transfer case pump rub kit, if not fixed it will wear a hole in the case and have to be replaced ($300 for the case half), plus other parts. Otherwise it is a very solid truck and will tow 15,000 lbs (7 metric tons) with ease. I'm sure you've already made a decision and I'll find out as soon as I make it to your thread to catch up.
JB
