mybigwarwagon
Sweet pink Jeep. Reckon it will still be around when she gets her license.
One day.....l
I will find the right S10@ the right $$$’s
Square backs are great, but Notchbacks rule Herb![]()
Like the Pink Jeep!
The brakes should not have to be pumped. Air is the usual culprit as you know, but it can also be a bad master cylinder. As long as that thing is you probably need to bleed a quart through to the rear cylinders to be sure to have swept the lines.
Now that I've shot off my loud mouth I'm starting on the 48 Coupe brakes.
Great to see the progress.
I drove it for 12 miles last week total with no issues like this. I noticed the fuel filter was almost empty so I put a couple of gallons in the tank, still nothing. The fuel tank, lines, pump, hoses etc. are all new, there is no reason it shouldn't be getting fuel. Well it turns out one of the check valves in the fuel pump fell out of its seat. Back together now and on the lift for brake adjustments once again.The brake issue you describe makes it sound like the brakes are just out of adjustment. The m/c only moves so much fluid per ‘stroke’ and if that’s not enough fluid to cause the wheel cylinders to put the shoes in contact with the drum it’ll require more.
But something I didn't completely notice when I picked them up was what kind of shape the lug holes were it, I don't know what happened to the rear wheels but they are wallered out bit time. I installed one and tightened the lug nuts but was just too afraid they would eventually pull through and cause a very bad day for me to I'm not going to use them for the time being.I may end up using them as roller spares for Project Pinkie Pi though.
JB
Bing bing bing, we have a winner, Nlped, that is exactly what I was going to do, if only I knew someone with a mill big enough...
JB
JB
those are re-pop C6 wheels (I assume you knew that when you bought them though). Probably still workable with the inserts Nlped posted but those style wheels are really common as well, can probably pick up another set pretty easily. if you absolutely have to and swap tires.
I always wonder on deals like that - did the seller know that or? Had they driven around with loose lugnuts at some point but just tightened them up and thought "yeap that's fine now"?
The jeep is awesome!
Get out there with a file. Mills are for wimps.![]()
I was thinking if the wheel cylinders weren't leaking then they are good. I'm leaning more to, has air in there still floating around. I mean the car is almost as long as a football field.
I think I have a brake line vaccum from HF. I also have the new hood hinges. They are kindof cheap looking from China. The springs are different, instead of the big spring, it has a coil type spring like on a watch. Tell me when you want me to come back down to helf on the brakes and stuff.![]()
Awesome picture.![]()
), I wired one in, wrapped it in split loom and tied it in place. Sadly no photos but the light output was much better at full running voltage.Nothing like parts that "fit perfectly" and have to be beat into submission.
One has to wonder about the genius brain surgeons who wire up stuff like that.
If they reproduce in the same way, it’s no wonder the world is so messed and filled with the people it is filled with.
My Blazer had the same guys brother or cousin do the lights. Or possibly his mother who is also his sister.
What have ya'll done to keep them out of the engine bay altogether? It is odd they will keep eating on this one but don't touch other vehicles.JB: get a CAT. here's my rodent's worst nightmare and her name is Cleo. she was a rescue (so probably a bit wild) that was 4-5 years old when we got her and she's got our perimeter (about a 2 block radius at last siting) pretty much rodent free except for a rabbit and squirrel she likes (she kills pretty much every baby bunny though). I haven't seen rats, mice in years and even the raccoons are taking a different route to avoid her.
with a property as big as yours maybe a few ferral cats would be great cause I had one at a rental years ago that i'd feed in the winter time, but come spring she'd follow me around and as i pulled out stuff of the burn pile to re organize for the next burn she'd eat a mouse almost as fast as they'd run out from the pile. one time i swear that she ate 5 or 6 mice in maybe 15 minutes.
meet CLEO. if you look close in the tree she's bird hunting in the tree in front of our house.
best of luck and even though i know you have the skills to fix bad or damaged wiring it's a PITA so hopefully you get the rodents to go to the next farm.
Anywhere else in the shop was fair game though.
Grizz,
I really think most of it is people that just don't know better. I know I have done some hack jobs in the past and try to do better now that I know better, but old habits die hard.I will say all of the connections were pretty good and still clean. Now in the pink Jeep they used a grand assortment of connection methods and few were what I'd like to see. All back together now though and a stereo in each that works just fine.
JB
Good thing the safety switch killed the motor. I found it a few hours later in the barn behind some plywood leaning against the wall.
you need a couple of good snakes. This is the one that was riding around under my tractor seat, when it popped its head out from under the seat and started to come up between my legs I seen something moving from the corner of my eye. This is when I knew that ********* thing wasn't a part of me, and jumped off the tractor while moving.This snake was at least 10 feet long. Had really pretty blue eyes.Good thing the safety switch killed the motor. I found it a few hours later in the barn behind some plywood leaning against the wall.
This will take care of your RATMOUSE problem.![]()
Get a Great Pyrenees to take care of the predators. Then get a cat.
JB,
Have you thought about getting rid of the old grain? It could be a source of food for your population. Other than that no good ideas.
Dwight
Morning JB.
Check my update on the thread I do.....
Repaired and refitted the radio and horn buttons last night, guess you know the answer already.
Yup, same guys did that too.
How about 9am ish Sunday morning?
X2 on the grain. Even though it's a ways from the shop.
Also, leaving the hood up is good for vehicles parked inside. The rats or mice like a dark place. Moth balls under the vehicle is a remedy I've heard but not proven.
Living in the midst of fields like you do is a natural habitat for them so your situation will be worse than most. The guys in Illinois in the middle of corn fields have it tough too.
Sealing the shop is not a very viable option for you because of your doors.
JB: I still feel bad that one of our dogs may have passed a year or two early cause she got in my garage where there was rat poison. I can't recall, but I think you have a dog or dogs so putting out poison could have a terrible side effect.
I like the food chain way to get rid of pest issues hence me not tearing down spider webs anywhere in our bushes and moving them from across the paths that they seem to learn not to make webs across now. that keeps the NO SEE UM bugs to a minimum here and haven't seen many mosquitoes in years that used to be an issue.
one of the members found 2 copperheads in his garage or burn pile and actually has them as pets now. i'm not a snake guy but having a few RAT SNAKES might be your answer and get a cat or two cause even though you might lose one or two maybe the coyotes will survive to flush out the rats so the hawks and other critters can kill them.
good luck and hope you are having a great weekend!!
If I saw that peaking out between my legs, I would have been off that tractor and in the house without my feet ever touching terra firma.
Holy ****!
