Theories why power tools aren't higher voltage
bsaint
Manchester, CT
Theories why electric power tools aren't higher voltage
0.5hp air motor (like on a die grinder) would be tiny with a 400v ac motor. 0.75a. Probably the same size as the air tool counterpart but with higher efficiency than an air motor.
Professional Tool User
BC
If you are talking about corded tools, I'm guessing that the additional electronics for stepping up the wall outlet voltage would be too expensive and that it would generate a ton of heat. Another potential problem is that your household outlet wiring won't cut it.
As for cordless tools, the last time I checked, lithium ion batteries have a standard voltage of 3.7V. Cordless battery packs are just batteries hooked up in series. So any increase in voltage will necessitate an increase in battery pack size.
rlitman
Long Island
Re: Theories why electric power tools aren't higher voltage
Wait, what? Voltage doesn't significantly change motor size.
My 3HP tablesaw motor can be connected to 120V or 240V depending on how you wire it up, but the motor is still the same size.
If you want to get smaller AC motors, you need to step up the frequency.
...As for cordless tools, the last time I checked, lithium ion batteries have a standard voltage of 3.7V. Cordless battery packs are just batteries hooked up in series. So any increase in voltage will necessitate an increase in battery pack size.
The limit here is that too many batteries in series becomes dangerous.
GerMec
Battery cells have a voltage of eeh around lets say 3V. That would make around 120 cells in series connection. Pretty heavy cordless tool...
Plus safety is an issue with those high voltages.
bsaint
Manchester, CT
Voltage does change physical size when you can use smaller wire. Lets mix high voltage and high frequency. And 400v batteries. Now we are cooking with fire
PhysicsDude
Dallas, TX
They'd make higher voltage tools if they could easily make higher voltage battery cells.
3-10 18650 battery cells work pretty well for most handheld tools.
I'm no battery engineer or anything, but from what I understand, if you make a battery much smaller than an 18650 cell, you get less power density and its harder to draw a reasonable amount of current from the cell. Pretty true for most battery chemistries as far as I understand.
If you put 20 tiny battery cells to make 80v or whatever, but you have half the capacity of a 5 cell 18650 battery of the same overall size, then you're still at a disadvantage, even if you can theoretically make a more efficient tool with the higher voltage.
I'm pretty impressed with what they can do with 18V brushless motors. Most of the major brands have an 18V circular saw that's pretty darn near as powerful as a 12amp corded one, not to mention stuff like the 36V or 60V tools. When you can achieve those kind of results with 18V, its hard to justify going to higher voltages with bigger batteries.
Maybe in the future they'll have some new battery type that can be a smaller form factor, or have a higher cell voltage or something, but for now, li-ion batteries and tools are so impressive, its kind of hard to argue that we need to radically improve them.
dr_clyde
Holland, MI
God I can’t imagine the carnage if you turned the general public loose with 400v+ batteries. Most folks can’t be trusted with a 9 volt.
Seriously, 400v+ is extremely dangerous if not handled properly. Have you ever been around 480v power? Yeah the wires are smaller, but all the rest of the system is bigger and more robust due to the ability for higher voltages to arc bigger gaps. Breakers, receptacles and everything is also $$$ due to the higher volts.
Brushless tools are tiny three phase AC motors. Vary the frequency to vary the speed.
Thats why they are brushless.
I can't be 100% sure on brushless power tool motors, but they are not true "phased" motors. Typical brushless motor have powerful rare earth magnets attached the inner part of the rotor shell. (N and S in the image below.) A true DC current is applied to sets of winding (A, B or C), one at a time, synchronized with the position of the magnet.
Watch the video. How Does a Brushless DC Motor Work
There are some "battery powered" motors that DO convert the DC to true 3 phase AC. They do vary the frequency for speed control. More electronics required.
Somewhere in the deep. dark, recesses of my brain, I seem to recall that "power" out of a motor is proportion the number of turns of wire (N which implies the size of the magnetic field) and current (I), so N*I.
Any EE power engineers here ?
Robbie B
Sunny side of hell
Voltage changes amperage load in electric motors. Frequeny also doesn’t change the size of the motor. Frequency adjusts the speed through a VFD. A/C and D/C motors don’t work the same. The more voltage you put through a D/C motor the faster it will go until it self destructs, on an A/C motor if you put to much voltage to it you just burn up the windings.
zkling
:spit: This
rlitman
Long Island
Frequency absolutely does change the size of AC motors. Why do you think airplanes run their 120V power systems at 400Hz?
Or, why do you think that motors rated at 60Hz have derated speed and HP output at 50Hz?
JRC3
Southwestern OH
When I was like 14 I got an idea to put a standard 6" grinding wheel on an old electric lawn mower motor...I was trying to one-up my grandfather's old washer motor bench grinder setup. I did not end well. lol
lafester
Northern CO
The milwaukee mx fuel stuff looks interesting as far as high power goes.
For regular tools I like the where Dewalt is going with power detect and even flexvolt in some cases.
Firebrick43
West central Indiana
Its more because the gear reduction ratio to generate 60 hertz with a turbine running 24000 rpm would be huge, in the neighbor of 12:1 for a 4 pole or 6:1 with a 2 pole! Or we can just have a minimal single reduction of 2:1 or so which is already present in the accessory gear box or even direct drive if its a 2 pole generator
but smaller motors, smaller capacitors, smaller transformers all make for lighter planes also
dutchgray
Dorset. England.
There is a 3 phase 400Hz power standard in industry, the Germans use it a bit, and their higher end tool makers make corded power tools for it, it provides increased reliability and efficiency and allows smaller motors.
Safety is a major concern, DC is more dangerous than AC so 400V cordless is definitely out.
We even use 110V tools here in the UK on construction sites even though all our power is 240V for safety (though there is no real need nowadays since RCD's became common)
exmaxima1
Midwest
I think you have that reversed: AC is alot more dangerous than DC, roughly 4 times as dangerous. There are multiple movies about Edison (DC) and Westinghouse (AC) arguing that very fact. Prisoners once called being electrocuted, "Being Westinghoused".
That said, I get pretty nervous when working on tube guitar amplifiers and poking around 400-500 volts DC.
Showkey
"MEMBER EMERITUS"
Wausau WI
When the vehicle manufacturers were thinking 24-36-42-48 volt systems for the public use.
Safety and cost were the BIG problems or concerns .......safety, was arc voltage and sustainable arcing that killed the idea.
Hybrid at high voltage were deemed an acceptable risk. Whole vehicle at 48 volts was not acceptable.
matt_i
Trying to maintain balance in the series-ed cells is the issue. Any single cell that gets out of line is a limiter in the overall current flow.
Keeping the number of cells lower makes a higher probability the cells will stay in balance just by open-loop equivalent internal chemistry and construction.
seber
Deep East Tx.
When I first started as as a customer engineer we had solenoid operated tube systems. The solenoids and relays were DC. For that reason we were limited to 48 VDC. High voltage DC is a killer. Touch it and you are unable to let go. Back when it was being debated they were still trying to figure it out. We now know that DC is the more dangerous system.
As stated before, higher voltage allows smaller wires and less metal mass but the insulation required generally cancels the advantage.
Motors are derated for 50 htz because the slower speed with the same torque means less hp. Simple math.
rlitman
Long Island
The true history is that Edison paid people to use AC for electrocutions (there is even gruesome film of an elephant being executed on Edison’s dime) in order to spread the false perception that AC power was more dangerous.
exmaxima1
Midwest
Do a quick search and virtually every study has concluded that AC is the more dangerous. While DC does tend to contract the muscles (limiting the ability to let go), it is amperage that kills. The capacitive nature of skin allows more AC to flow than DC. Basically your "resistance" (actually impedance) is lower for AC so it takes less AC voltage to kill you. You might be able to handle several hundred volts DC, but even 40-50 volts AC can be lethal under some circumstances due to the frequency and the skin passing it thru.
Here's an example I referenced from:
https://www.electronicsforu.com/resources/learn-electronics/ac-dc-current-body-dangerous
Robbie B
Sunny side of hell
But that size reduction isn’t a function of the Hz. It’s a function of design for the application. Motors have decreased speed and HP at lower hz because when you decrease the Hz in an electric motor you are decreasing the speed and hp. I never said you couldn’t make a high Hz motor small, but size doesn’t necessarily change relative to Hz. Motor size is determined by application.
cycle61
Middle of Oregon
It absolutely is a function of frequency. At higher frequencies, the magnetic field is building and collapsing much faster, which results in a higher counter-emf and more physical force generated for the same size winding.
20 years ago I was in the Navy, and I can tell you from personal experience that a 5hp electric motor off an F-14 Tomcat can be held in your hand.
https://fcxinc.com/why-the-aviation-industry-operates-on-400-hz-power/
Mechanical Noise
Southeast of O'Hare
I don't understand this part:
Due to the capacitive behaviour of the skin coming in contact with the current carrying conductor, more current can pass through the body if the voltage is rapidly changing. Studies have shown that twofold of increase in the voltage increases sevenfold increase in the current.
Even if the dielectric effect if skin is significant, the relationship between voltage and current should remain linear. Doubling the voltage should double the current. I can imagine a non-linear relationship considering ion flow in the skin but that's just based on my intuition, not my education. And I'd think that nonlinear relationship would hold at least as much for DC as AC.
How significant is the dielectric effect of skin? How much additional current flows? If the dielectric effect was significant at 60Hz, shouldn't we we get at least a tingle when we grab a vinyl insulated wire? Even more with the very thin polymer insulation on magnet wire.
Mechanical Noise
Southeast of O'Hare
There were high voltage AC arc street light systems in use in a few localities when Edison started his DC system. The high voltage was necessary because the arc street lights were wired in a series string. Arc light don't work well in parallel because whichever arc light fires at the lowest voltage hogs all the current.
Edison's low voltage incandescent bulbs were significantly safer than series string arc lights. Safe enough to be used inside the home. Of course, Edison's incandescent bulbs worked perfectly well on AC and improvements in AC transformers and such posed an existential threat to Edison's empire.
So, Edison was happy with any sort of ******** argument telling people that the AC system was still more dangerous than the DC system.
Vvmvbb
CT
—-you might be overthinking it a little there, mech noise. People are dielectric. We are capacitors. No current flows through capacitors at DC. Impedance of a capacitor decreases with frequency so, for any voltage, more current will flow with increasing frequency. That’s the primary effect going on.
Two secondary effects arise. 1) leakage through the ‘capacitor’. We are imperfect capacitors. Imagine a high, ordinary resistance in parallel with our capacitance. That resistance is generally too high to permit much current flow, but this leakage current will be proportional to voltage so will become dangerous at some high voltage 2) dielectric break down. At some high voltage, the dielectric that makes up the capacitor transforms into a highly conductive plasma permitting very large currents to flow. The plasma ordinarily burns out like a fuse so the current surge is short lived. But that’s flesh burning out like a fuse when people are the capacitors.
Norcal
Edison coined the term referring to electrocution with AC as being "Westinghoused" as we can see it did not take off.
Mechanical Noise
Southeast of O'Hare
OK, current in a capacitor increases with frequency. But power line AC is going to stay the same, so that's not an issue.
As the author of the cited article states:
This is somehow peculiar to AC? How?
With either a resistance or capacitance, AC current changes linearly with voltage. Twice the voltage, twice the current.
Would something akin to ion flow/insulation breakdown account for a seven fold increase of current with a doubling of voltage? I think so. But such breakdowns aren't peculiar to AC. DC voltage does it, too.
I have been in and around the automotive industry for almost 50 years. 48V has come up every few years for the past 20 or 30. Too many cheap 12V devices out there to justify the DC-DC converter and a 48V battery.
... we were limited to 48 VDC. High voltage DC is a killer.
Most safety standards classify anything about 50V (AC or DC) as "high voltage" with totally different safety requirements.
The telephone system gets away with it (max ringer voltage is about 96V ?) because they were around long before any standards were written and the are an intermittent voltage source AND current limited.
As with almost everything, it boils down to COST ! Add in feasibility at the time when the technology was rolled out. I can not imagine anyone at Westinghouse thinking of anything much higher than 60Hz in the late 1800s !
