thermostat
rob in nh
kingston nh
i think my thermostat has gone bad, it doesn't seam to be calibrated anymore. i was thinking on just getting a new one. it has a honeywell stat right now, any recommendations for a replacement? thanks
ForceFed70
BC, Canada
Honeywell is the brand to go with.
Nest is also a good one if you want something fancy with all the bells and whistles. Overkill in a garage IMO.
vietnastee
SF Bay Area, CA
I went with Nest and it's super easy to use compared to the other programmable thermostats.
The Nest version 2 is really afforable right now, under $200.
Be careful and don't get the super cheap ones like I did in the beginning. I got the cheapest Honeywell one for like $20 and it kept on blowing my 24V transformer. Took me a while to debug the problem.
nadogail
Coronado, CA
IMHO, Honeywell is the Gold Standard of the industry.
I have head "Just as good as a Honeywell" when other brands are compared, but never "better than a Honeywell".
zmaxmotorsports
South of omaha
Heres the brand I normally use from the supply house,they work just as good as any other normal stats out there.
The high tech stats are just more complicated/easier to break down in my book anyway.
The regular non programmable digital H/C stat costs me $29.00 and change.
The heat pump version is programmable and costs me like $51.00 ;)
Dragfluid
Pillager, MN
Also something else to consider. If you aren't in the garage every day, and don't want to heat it up much past freezing, you can get what's called a "low temp" thermostat. It will go down to 35F. That's what I put in my shed. It's not programmable, though.
Jarnipman
I am extremely happy with this one. Honeywell has a great app and online interface. WiFi is key because programming it for certain hours is not good unless you are in there on a constant schedule, otherwise you might heat it when you are not in there. I don't think the Nest knows either when you have truly variable schedules. WiFi lets you turn up the heat before you go in anytime. Sometimes I go in the shop at 7AM, other times at 6 PM, WiFi let's me adjust it before i get to the shop anytime. Keep it at 40-50 and then crank it to 65 from home. Also sends you alerts if it drops below a setpoint so if your are away from home and there is a problem that could freeze your stuff costing you money, then you can address it with the alert. It's nice when it's -30 to crank the heat from your bed before you get up in the morning with your phone or tablet. Right now I was drying something at 70F in my shop, I forgot to turn it back down to 50 and it's freezing cold outside - I'm on the couch, wallah, I just changed the shop to 50 on my computer.
Honeywell RTH6580WF Wi-Fi 7-Day Programmable Thermostat
http://www.amazon.com/dp/B00A97FIG0/?tag=atomicindus08-20
R
rob in nh
kingston nh
Well i suppose i should have checked the obvious first, took it apart and found out it was out of level, works good now.
