Thin wrenches?
Rickkyyr8
Looking for a set of SAE thin profile wrenches. Who do you guys recommend?
Meursault74
Southern California
discussed here recently
Grant Gunderson
Bellingham, WA
I have a set of the Snapon low-torque ones ( top left of pic) mine are metric, I use them for rebuilding suspension on bikes. They excel at that. They are about twice as thick as my Park cone wrenches, but hell of a lot nicer in finish and won’t damage delicate parts that require thin wrenches.
That a Park 14mm cone a Snapon 14mm low-torque and a 14mm Snapon flankdrive plus.
Also many people don’t know this, but that funny hole in the park cone wrench is so you can use them with a Torque wrench. image.jpgimage.jpg
I prefer crowfeet for this, but some of the stuff I work on, only the cone wrench will fit and it requires a precise torque. 94B508FE-D13B-4F09-8627-EB6B9197E569.jpeg
nadogail
Coronado, CA
Bicycles use thin wrenches. Park Tool and Campagnolo (sp?) are the leading makers of bicycle tools. Automotive Tappet Wrenches were thin, they were used for valve adjustments on Inline Flat Head engines.
As a kid I was given a set of thin wrenches intended for the maintenance of a machine made by the Cissel (sp?) company, a maker of laundry and dry cleaning equipment. I have made thin wrenches from standard wrenches by carefully grinding their width away; this was a slow process because I had to be very careful to not overheat the wrench and draw the temper from the metal.
If you get to San Diego, you may find a used tool store. I bought a lot of tools from Pat's Tools during the 80's and 90's.
SRU1436
Bay Area, CA
I have one Snapon low torque really thin wrench that I use on my chevelle carburetor, it’s super thin and works really well for my needs. Using it on my carburetor and is the only instance where I’ve needed something that thin.
joe_padavano
Northern VA
If you only need one particular wrench, it's usually more cost effective to just buy a used one at a swap meet and grind it down to fit. I've done this multiple times for specific applications. Typically $2-$5 each, depending on size.
Odd-job
For some reason never knew that slot was for a torque wrench. Guessing you have to do the 90 degree trick I learned on GJ to get the right torque?
anndel
Hawaii, USA
Those are nicer than the Park tools wrenches I use on caliper pin bolts.
cherrybomb
Near Madison Wi.
If you research the Stahwille brand thicknesses, I have found they beat my Snap,Proto,S.K and Wright,and they are a great wrench,a more reasonable price.
Grant Gunderson
Bellingham, WA
Interesting.
I just looked them up, the Stahwille 13mm are 3mm thick according to their site, the Snapon low torque are 4mm according to their site (for a 13mm I measure 4.25, a 10mm is 2.66mm) and a Park cone wrench measures 2.17mm. Price wise the Parks are about $100 a set, the Stahwille are about $200 and of course Snapon is $630
I use these a lot, so the Stahwille could fit perfectly for me in a few applications... but I am curious as to the quality of the polishing in the open end of the section, as I am very concerned about not scratching suspension componets.
bob15
Northeasten, CT
I have a set of Mac and a set of Snap On. Zero issues with either.
The Snappy's can be gotten cheaper on ebay.
n8n
Curtis Bay, MD
Thicker than a cone wrench or tappet wrench, but thinner than a standard open end wrench, are some German DOE wrenches I found in a Goodwill years ago. I will have to check brand however. They were unbranded but I found one to fill out the set (there was one missing) that appears identical, but I'll have to actually look at them to get the brand for you as my memory is not so great. I used them a lot for brake jobs on GM trucks as a standard open end was too thick to hold the caliper sliders.
Vwpower
Erie PA
My thin metric wrenches are vim. They are double open end and we’re around $35 or so.
i also have the park tools cone wrenches in sae and mm.
wafrederick
Holton,Mi
Thin wrenches come in handy on brake caliper slides.Sometimes you have to support the brake caliper slide to get the bolt loose,The 15mm works good on the Chrysler brake caliper slides
Mytoolsupply
Central Ohio
What's your application? Some of my thinnest wrenches are service wrenches, I use them a lot for hydraulic hoses because they are so short its easy to get them into tight places and spin fittings fast. A 1" Wright service wrench is 7/32" thick but it's only 6-7/8" long
Walkers
Cave Creek Az
Dang, just when I was perfectly happy with my wrench drawer. I have long, stubby, standard, reversible ratcheting, flare nut, and now, I guess I have to go find my dealer and have him hook me up with thin wrenches. Thanks a lot!
jmf535
Interesting.
What Stahwille series were you looking at that is 3mm thick? I have a set of the 14's and the 13mm is 6.5mm.
I've been on the hunt for a good set of thin wrenches, so if Stahwille offers one, it's going to the top of the list.
Then, regarding the open-end finish. Stahwille's don't have a mirror-type polish to them, like your snap-ons, but the finish is still quite good. I use mine on motorcycle suspension, and have no concerns about them scratching the coatings.
Grant Gunderson
Bellingham, WA
These. https://www.stahlwille.de/products/de_en/40063232-40063232.html. They range in size from 3.2mm to 14mm.
Sgtboz
Palmera from Spain. Nice and thin yet strong. At least the one Palmera wrench I own is!!
EzGoingKev
I have a couple of Snap-on low torque thin wrenches I use for servicing motorcycle forks and shocks. They have always worked great for me.
neophyte
Pennsylvannia
Look up “Check Nut” wrenches.
These are specifically designed as a very thin wrench.
The design goes back to the early 1900s, at least.
A bunch of manufacturers used to make Check Nut Wrenches, and even used the same wrench model number system.
Armstrong, before the brand was murdered, and Proto, and Martin were all the main recent US manufacturers.
The Martin ones I have were thinner than my Craftsman/Armstrong Tappet wrenches.
Martin and Proto are probably the best current options.
I believe both manufacturers make both SAE and Metric.
( either Martin or Stanley may make both brands)
cannuck
Rural SK
I am a mechanical guy who works with electrical stuff. Althought Stahwille is my go to for flat wrenches, I have never seen the set from post #25. As usual, you guys have cost me a bunch of coin, but one I am glad to spend.
I scored some sort of Asian brand from a bargain table that covers sizes well up to 3/4" to 2" stubby single enders in 1/16" increments (we need these for jam nuts on high voltage bushings in power transformers) and two smaller sets of plate double enders from Princess Auto sale a few years back that covers the lower end 1/2 to 1 1/4 and 8 to 32mm. They are all from Grand Rapids Industrial Products (GRIP) but I don't see them on their website. 100% Chineseum and the plate wrenches are a bit on the delicate side, but the forged single enders are actually quite useful and useable. Just with I had them up to 4" or so.
Dave455
Sussex, England
I’ve been reading the recommendations for the Stahlwille No.12 “Electric” wrench and can only agree. I’ve used these and they’re quite nice.
The Hazet 440 are very similar. So much so that I wonder if both wrenches are made by one company on behalf of both?
Maybe go with whatever you get the best deal on. I know Stahlwille are available in SAE though, not sure about Hazet.9FF5A91D-3AD5-4E1B-8EC6-8750737EDA04.jpegBD3DC540-FE3C-4D9A-B58C-30BDB6B3DFE4.jpeg
