I have one Snapon low torque really thin wrench that I use on my chevelle carburetor, it’s super thin and works really well for my needs. Using it on my carburetor and is the only instance where I’ve needed something that thin.
I have a set of the Snapon low-torque ones ( top left of pic) mine are metric, I use them for rebuilding suspension on bikes. They excel at that. They are about twice as thick as my Park cone wrenches, but hell of a lot nicer in finish and won’t damage delicate parts that require thin wrenches.
That a Park 14mm cone a Snapon 14mm low-torque and a 14mm Snapon flankdrive plus.
Also many people don’t know this, but that funny hole in the park cone wrench is so you can use them with a Torque wrench.
I prefer crowfeet for this, but some of the stuff I work on, only the cone wrench will fit and it requires a precise torque.![]()
Those are nicer than the Park tools wrenches I use on caliper pin bolts.
Yes. I was always taught to set it at 90 degrees anytime you use a Crowfoot of any type.For some reason never knew that slot was for a torque wrench. Guessing you have to do the 90 degree trick I learned on GJ to get the right torque?
Interesting.If you research the Stahwille brand thicknesses, I have found they beat my Snap,Proto,S.K and Wright,and they are a great wrench,a more reasonable price.
What Stahwille series were you looking at that is 3mm thick? I have a set of the 14's and the 13mm is 6.5mm.Interesting.
I just looked them up, the Stahwille 13mm are 3mm thick according to their site, the Snapon low torque are 4mm according to their site (for a 13mm I measure 4.25, a 10mm is 2.66mm) and a Park cone wrench measures 2.17mm. Price wise the Parks are about $100 a set, the Stahwille are about $200 and of course Snapon is $630
I use these a lot, so the Stahwille could fit perfectly for me in a few applications... but I am curious as to the quality of the polishing in the open end of the section, as I am very concerned about not scratching suspension componets.
I like mine. When buying, look for the 16mm to be missing. Capri has it!I recently bought this set from Capri on Amazon for a small project and they worked fine. Give them a look. Capri Tools Super-Thin Open End Wrench Set, Metric, 6 to 19 mm, 7-Piece (11850-7MRK)
These. https://www.stahlwille.de/products/de_en/40063232-40063232.html. They range in size from 3.2mm to 14mm.What Stahwille series were you looking at that is 3mm thick? I have a set of the 14's and the 13mm is 6.5mm.
I've been on the hunt for a good set of thin wrenches, so if Stahwille offers one, it's going to the top of the list.
Then, regarding the open-end finish. Stahwille's don't have a mirror-type polish to them, like your snap-ons, but the finish is still quite good. I use mine on motorcycle suspension, and have no concerns about them scratching the coatings.
