Thinking of a New Compressor
Contract_Pilot
Vancouver, WA
Time for a Compressor that can handle my current requirements and go above and beyond possible future requirements. Prefer made in the USA Quincy is known to be USA Made but the FS-Curtis? local distributor says yes, FS made in usa but a web search give conflicting info. I can get the FS-Curtis locally for $100.00 less than the Quincy.
Space limits me to about a 60Gal size unless some how a larger shop appears on my lot.
1st One is the Quincy 2V41C60VC
2nd Choice is the FS-Curtis CT5 05C55V6XX-A2D
Any other Recommendations? for the $1,300 Price Range!
matt_i
I don't think you can go wrong with either one. With reasonable use you will probably be passing it along to someone in the next generation.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Ingersoll-Rand 2 stage 80 gallon. You can get one for around $1000. And IR has a good reputation
52wrench
western NYS, land of taxes
What do you have now and what do you need? No need to buy a whole new tank, etc. Buy a pump and motor for the add'l SCFM you need and run parallel into the existing tank. I have a 5 HP Campbell Hausfeld with 60 gal, picked up a 5HP GE three phase for $100 off CL and a new 11 SCFM pump at HF for $40 ( clearance sale) and I run it into the 60 gal tank only when I need the add'l SCFM for the blaster. I'll have about 22-23 SCFM @ 90 when I need it. Takes a little work but is well worth it. I built a rotary phase converter to run my lathe, mill, grinder so went with three phase for this but not a requirement. Used three phase motors are CHEAP and much more robust than a single phase. This 5 HP three phase weighs 85#. The heavier the motor the better it is.
larry_g
oregon
If you get into Oregon then check at Coastal Farm store. They have the low end Quinceys and on Tuesdays they have a 10% senior discount and no sales tax. They were able to beat the mail order places on price.
lg
no neat sig line
md21722
Mt Juliet, TN
Harbor Freight recently changed their 5HP compressor to a single stage. The high ratings are for the old compressor.
Both are the low end of the spectrum for their respective brands. The Quincy uses a 3450 RPM motor and spins the pump at 1310 RPM. I am not sure of the specs on the Curtis. This is a cheaper place:
http://www.portlandcompressor.com/s...hp-60-gallon-2-stage-230v-air-compressor.aspx
I know the local Curtis, Champion, and Sullair distributor in my town sells a ton of Curtis 7.5 HP CT series. They say all the shops in town use them because of the price point. We also are at 6,000-6,500 feet where a 7.5HP is downrated about 20-25% due to altitude so its closer to the way a 5HP would work at sea level. They will sell you a Champion but move more of the Curtis because of price.
C
Contract_Pilot
Vancouver, WA
lg
no neat sig line
Checked they only have an 80 gal and I only have room for a 60
C
Contract_Pilot
Vancouver, WA
New to me 1.5 years old Quincy Qt-54 got for a good price locally.
I Have to poor a pad make a lean-to shed and finish wiring the sub panel. Busy till next week....
Now the Hunt for a Blast Cabinet. Thinking of the TP Tools 960 or the 970.
