This is the pro way to store extension cords
NUTTSGT
Northern Central Ohio
I've seen that before but I won't do that. I don't like to put my cords in that tight of a loop for long periods. I just loop them like he does in the beginning. I've not really had an issue doing that and unwinding it.
I cant stand that method.
Much prefer the over-under method.
If done right, one can toss the cord out while holding the plug and it will unwind and go to where you need it.
esvee
Portland, OR
From working with AV equipment I learned counter-coiling (or over-under as folks have mentioned here).
Fast, easy on the cables, makes for a perfect throw every time. All of my extensions and rope are stored this way.
alfredeneuman
Fullerton, CA
I always do it like the guy frank001's youtube vid shows.
It really makes quite a difference when dealing with 100' cords like on construction sites.
rharman
SoCal
Over/Under is the way to go. Once I got comfortable wit that, there was no going back.
Miss the Pontiacs
Saskatchewan Canada
I started doing it as the OP’s video demonstrated. The jury is still out on if I will continue.
I did this method with 2 100 footers. Haven’t had to use them since lacing them. Actually once you split it in two it really doesn’t take long to lace them once you get the pattern down. It will be great to not have to over arm the whole cord once you have completed a project. Just unlace what you need and redo when completed.
Zeke
I've done it that way for years,nothing new.
Yeah, he acts like he's just invented the newest and best way to lose belly fat.
I wouldn't bother with a 25' or even 50' cord, I do the over/under (or just wind them up, who cares about a silly 252 footer?) My 100' cords are done in chains but started with 4, not 2. Then the stupid thing isn't seven feet long all *******.
If you're unlucky enough to have a 16 ga. 50 footer(or a 100 footer, godforbid), the chain works pretty well as they become spaghetti just looking at them. I only have such animals for corded yard tools. I have a thing about cordless yard tools — too expensive and I hate fooling with the batteries. I get enough of that with cordless tools on the truck.
Bad00SS
Rockford, IL
This has to be the stupidest way I've ever seen in my life. I don't have time to weave some complex chain of ****. I can put away my 25ft'r wrapping around my arm in 10 seconds and hang it on the hook in my garage and done. Don't re-invent the wheel. geez.
slow
near Orlando
Over under for me, after doing audio/video/ and stage lighting, no going back to other methods.
jives
Central NY
^^This. On heavy gauge 100 footers, double them up twice, then chain 'em. Too heavy to coil. . .
Robert Haas
Known as a "Bosuns weave" long heavy gauge cords tossed into tool lockers or job site work boxes need to be weaved. Roll them up nice and then put 10 of them in a pile and you will quickly understand why.
Over under for all hanging stock around the shop but the stuff out on my job sites or in my wrk trucks is weaved.
techieman33
Kansas
You just have to tie them up when they're coiled. Leave a piece of string or a velcro wrap near the male end of the cable.
Robby321
Olympia, WA
Damn! Did they stop making cord reels? Or get a 5 gallon bucket and and loop it around in there. Or drill a hole and stick the plug out side bottom, and then take out what ya want...(world getting SOOOO stupid)
LS6 Tommy
Northern NJ
I like the chain method, but the reality of it is it takes up too much space to store multiple cords. After being in bands since the late 70's, it's always been over/under for me.
Tommy
Arkansas COB
Arkansas
I chain my 100' 10 ga cords. All others just get looped and tied off.
One thing for sure is on the 10 ga cords they really need to be not twisted to begin with to make the chain work properly. Getting them non twisted took some doing but once done and chained they havent got twisted again.
When buying a brand new cord thats been rolled up I find it best to stretch it out tightly in the sun for several hours before trying to chain or loop.
Have never seen the over/under method. Seems like this would be good on small gauge cords. Will have to give this a try.
COB
Bretny
Dutchess county NY
If your looping it around your arm you will have a twisted mess of a cord in short order...also dont touch my cords.
The only cords i loop in a circle are 25ft and the loop is roughly 4ft. So very few loops.
Bretny
Dutchess county NY
techieman33
Kansas
COB
The other thing to do is to unroll it properly. New cable is rolled around a drum, not coiled from the side. It needs to be unrolled the same way or you’ll introduce a ton of twist right from the start.
Chukster
Cary, NC
I'm curious what a wire & cable manufacturer would suggest. For one, repeated flexing of copper work-hardens it; so the more flex, the harder the wire.
I'm all for good care of wire & cable; I just want to know what a metallurgical engineer would say.
Chukster
Cary, NC
cadunkle
I hate braiding, the cord will never be straight again, many twists and tangles. I roadie wrap, or over/under. Same for air and water hoses. Works great and the cord doesn't get any kinks or tangles.
SGKent
Citrus Heights CA
water skiiers have the same issue with tow ropes. Fishermen have issues with anchor line. If you put the cord in a 5-gallon bucket randomly it will come out exactly the same way it went in without tangling. A figure 8 is preferred to a coil. My father was USCG officer for years, sea duty, coastal search'submarine bombing WWII, and SAR. If anything had to be coiled it was in a figure 8. That said I have tried looping, figure 8's, buckets and reels. My 100' cords are on a reel. A little silicone spray on it once a year and it will spin with no friction. 10', 25' & 50' cords are figure 8 using my arm and elbow. I get tired of trying to store loops in the shed where they get in the way. Also if someone else tries to use it I end up undoing knots because they didn't understand how simple it was to start. Like pulling a string on a potato sack. There is an easy way and a take all day way. Everyone should know how to do it but using it depends on the use and frequency. My 2 cents.
