Test fitting the bodywork.
Stripped it all back off to paint it. Pulled the steel frame out the bonnet , cleaned it up and painted it before reassembly.
Rear tub floors pretty grim - pressurewashing blew holes in the alu where it contacts/rests against the steel. Due to time contraints and the fact that they wont be an MOT failure they will be repaired at a later date - Same thing with the rear most quarter panels - I have 5 months now to get it road worthy - and im currently sat in perth australia for the next month with work.
Reassembled properly now. all bolted up- all looks pretty good on the alignment front which given how much ive chopped and welded up this chassis and firewall has made me pretty happy , the proof will be in the door fitting i guess - which i will be ordering in a couple of weeks , brand new series conversion items from SP4x4 back in the uk. Still undecided about splashing out on rocky mountain ALU door tops but i guess at 49 quid for a glazed door top from SP i can order them for now and decide if i really need rocky mountains (folks say the RMs being stiffer create a better seal with the door frame and thus you stay drier - give my LR its due even in the pishing rain i NEVER got wet - i think its a rare beast that...
Need to do something with that chequer resh - chequer rash is for places you might stand ..... you cant stand on a vertical surface. How ever close inspection shows its holding that tailgate together. I might see if i can unrivet it and turn it over to the smooth side and rerivet- then spray it blue- or i may just spray it blue Till i can find another tailgate.
How she stands now in the scottish winter. hopefully not ******* the neighbours off too much since its progressed significantly in the last week from a heap on the floor to an actual car
dear lord it is tall though , its only a 2 inch lift. I hope it settles a little as its still rolling on 205/16s and it will be 750x16s on the lime stone rims that are leaning against it once im done which will be another 1.5 inches height i believe !
PS the engine(a newer 200 tdi so needed to do some loom chopping) even turns over now - after i wasted friday looking for a black earth wire from the starter relay which goes into the wrapped loom as a black and according to my multimetre probing it comes out as a black with green trace. this is the "starter inhibit" wire according to my wiring diagram - not exactly an obvious one is it ! - it earths on the gear box not the bulkhead as my diagram says it should.
