Above 1200 Sq/FT "Thisland" - a 50x100 build thread
P
Psychoholic
Bogart, GA
Impressive building. I want to follow this build to see how you finish the inside.
Honestly it's pretty much what you see with a lot more wiring and random ****. We have a bunch of banners, some neon, and random pieces of randomness we might hang on the walls (and my soapbox car from the ceiling) but that's pretty much it. The 'machine shop' area under the mezzanine will get plywood walls to reduce chips destroying the insulation.
P
Psychoholic
Bogart, GA
Well we managed to finish moving in before I had to turn in my keys to the old shop on July 1st. The place is an absolute and utter disaster right now (you REALLY don't know how much stuff you have until you have to move it). Yesterday we finished the mezzanine and putting the floor down on it. I probably could have gone a less expensive route than the LP Legacy subfloor but it's damned nice stuff and the floor feels almost as solid as the concrete does. Also went a little overboard with the amount of strap used on the floor joists to prevent lateral movement but walking around up there it's so sturdy I'm really glad we did everything we did.
I'm so freaking sore this morning. It was hot as hell up there (one advantage of the mondo high ceiling is that the heat pocket isn't as bad on the floor but when you're working up on the mezzanine it's easily another 5-10 degrees hotter) but we got it done!
Next up we need to finish wiring so we can get the machines making money again, put the shelving up, and build a bathroom.
