thoughts on a air compressor purchase
COBRA5LADDICT
i have been hitting the used took scene to try and find a nice 60+ gal 2 stage compressor (prefer a single phase). my budget is about $650. i need a unit to keep up with sand blasting and cut off wheels, paddle sanders etc. i have had my eye on this one
http://denver.craigslist.org/tls/3863525892.html
i know it is over my budget but i wanted some feedback:lol_hitti
Speed-Racer
The tools you mentioned eat a lot of air. You should really consider an 80 gallon tank, they take up almost as much room.
For your CL find, you need to find out if it is a phase 1 or phase 3. If you are running this at home, you need to purchase a phase 1 motor or a converter. If it is a phase 1 and you could hear it run, that seems to be a fair price especially if they would accept a lower cash offer.
Winmon
Sequim, Wa
Here is also something to think about when buying a compressor off Craigslist from an industrial type seller. I will just post the quote from member All from another thread....
Another thing... I noticed in the pics of the other ads you posted that these compressors were in a commercial environment where there was a possibility of employees present (evidenced by forklift, many pallets, etc). If this is the case, then it is highly likely that at some point or another, an OSHA inspector came in and inspected the tank.
Given the age of the labels on the tanks in the pictures that you showed, the probability that the tanks were at some point inspected by OSHA is even higher. This applies to California and metropolitan areas of New York, the two most progressive (some would say aggressive) coastal states with highest population densities where regulations (some would say invasions) are on the cutting edge.
So, if CAL-OSHA inspected those tanks, they would have stamped (with a punch) a serial number on the head of the tank. The numbers would be at least 1 inch in font size. When you look at the tank, look for that serial number, and write it down. Then, go out to your truck and "think about it" for a while, and while you are thinking, call the OSHA office in So Cal that is responsible for keeping track of state inspections for pressure vessels, and have the record pulled for the serial number you obtained.
They can tell you on the spot if the tank was condemned for use in commercial service with employees present. They will have made that determination utilizing an ultrasonic thickness tester, comparing their readings with the minimum thickness specifications found on the welded on National Board Registration tag that is part of every code welded ASME pressure vessel, which all the Husky's in your links have.
This way, you don't get burned by a business craigslisting away a condemned tank they can't use in their shop anymore. Also, look for any circled X punched into the tank. That is a sure sign of state condemnation.
sberry
Brethren, Michigan
For that kind of money would be hard pressed not just to bite the bullet and buy a new one from a box store. They say 17 or 21 cfm on the side. By the time a guy fuks around, replaces a couple belts and a switch it costs about the same.
