Thoughts on this air compressor?
isuhunter
What are your thoughts on this air compressor? For a light user, nail guns, tire filling. Maybe 3/8" impact.
I
isuhunter
Theisens used to car PUMA but now this is the brand they are carrying.
Leaflessshadetree
Don't ask.
Might be a bit large to tote around for nail guns. Check the CFM of impact wrenches but it should work fine, especially if not being used constantly.
2jz4me
se indiana
Am I missing the price? I would say its a fine candidate for the purposes you listed. If you plan on doing weekend automotive work with it I can tell you from experience to forgo the 20 gallon and just get a 60. Unless you need it to be mobile dont make the same mistake I did.
jallyn
Fort Wayne, Indiana
Looks great for light duty tasks you mentioned. Nice "Made in the USA". Park it in a corner of the garage and can be mobile if you need it to be.
mikegt4
sw ohio
I had an "Industrial Air" brand compressor of similar configuration. Like Magna Force it was made by Coleman/Powermate/Sandborn. It was a residential / hobby level so don't expect to pass it down to your kids. Occasional use for lower CFM requirement jobs. Much better than an oilless or direct drive compressor.
My compressor was the same size upright, be aware that it is VERY top heavy and can easily get away from you when trying to move it around. I got mine free less motor after the PO dropped it destroying the handle and regulator. I had a spare motor and used it for about 2 years before giving it to one of my son's friends.
For your stated use it will probably work well.
IIRC, Powermate has their parts manuals online for download.
anndel
Hawaii, USA
What do you have now? I'm in the market for a compressor as well mainly for removing wheel lugs, air ratcheting. I was looking at a 30 gal Husky belt driven since my garage is so small and can't fit a 60 gal or larger. Also don't want to hire an electrician to add 230v.
mikegt4
sw ohio
For what you need a 2-3hp belt driven compressor should be fine. I used a CH 2hp 20gal horizontal tank unit for 35 years until the tank rusted out. Since I got a blast cabinet I upgraded to a Emglo 2 stage compressor. I still have a CH 27 gal portable upright, it takes about 5 minutes to fill up to 135psi. The Emglo takes about a minute to 175psi but it has a small tank.
An upright take doesn't take up a lot of floor space but if you have to move the compressor around often I would opt for a horizontal tank.
anndel
Hawaii, USA
Thanks very much for your thoughts! I'm using a 10 gallon California Air tools 10020 and if removing 2 sets of wheel lug nuts the impact wrench slows down until the tank refills. I got it because of the space limitations but also it was supposed to be quite. My wife says it's not much quieter than her father's 20 gallon Craftsman oil less compressor.
oilslick
Central illinois
5.3 @90 psi seems pretty weak to me, maybe that's as good as it gets in a Malone but I was thinking my nail gun tank was 4.0 and its oil lubed and tiny!
Tenex
Theisens farm store in Iowa. Regular price is $399
Which Thiesen's? If you're around the Des Moines area then you should check out Bob's Tools on Army Post Rd. They sell Puma compressors. Menards carries Sanborn. Northern Tool has a decent collection and I think I remember seeing Quincy at Bomgaar's.
I
isuhunter
I'm up by Waterloo, I think i saw this in Marhsalltown
Tenex
I live in Iowa City where there's not much around in the way of quality tools. I'm not real familiar with Waterloo, but I know there are plenty of shops in Cedar Rapids.
