Thread sealant question
NUTTSGT
Northern Central Ohio
I'm trying to extend my airlines in the addition. Like the rest of the garage, 1/2" black pipe. I was out of the Oatey stuff I used before. The only thing I could find was at Ace Hardware.
When I opened the bottle, it had liquid on the top. I stirred for like 5 minutes, trying to mix it completely.
It you look at the second attached pic, this stuff is runny, like cold syrup out of the fridge. No real thickness to it. I tried it out threading on a tee. It acted like nothing was there.
Should I use it ? Would you use it or go buy something else ?
LXCam
I'd buy something else. What no teflon tape laying around anywhere. Who doesn't have at least one roll missing the cover and one side busted off in some oddball drawer?.
rlitman
Long Island
I think I'd look elsewhere too. I prefer thread sealants that are thick. Play Dough consistency is still fine, but watery, not so much.
N
NUTTSGT
I have teflon tape but I had some leaks when I first did the air line with tape. I wanted to use some similar to what I used before.
This was the only stuff in town. Worst thing is, the 10" pipe wrench, Master Mechanic brand from Ace, came apart as I was breaking apart the old lines. I only used the thing a couple of times to boot.
N
NUTTSGT
I didn't want to get it all together and then have to take it back apart sing this stuff. Looking online, Lowe's has the Oatey stuff I used before.
LXCam
Youre more then welcome to borrow mine E
You won’t need no stinking tape once you’re done wrenching on it. ;)
N
NUTTSGT
Thanks but freight might kill the deal. ;)
Step-dad has a 36" or 48" one from his years as an electrician if I need a large one. I might grab another 10" one when I grab a bottle of sealant later.
tarmy
Nor Cal
10” is not very big...might want to get a larger version so you can have a variety.
I have many Rigid pipe wrenches and have found that a 12 and 15 are my go to size used.
BlakeTheCarGuy
Roanoke Virginia
That stuff looks more like anti seize. When I do anything that requires thread sealant I use the Permatex Thread Sealant in a tube it’s white with PTFE.
N
NUTTSGT
I have a few. I was using the 10 because it allowed me to get close the existing airline about 3/4" off the garage wall. I finished taking it apart with an offset headed pipewrench.
aussieblake
I was on a construction site years ago, and a sprinkler fitter was using both tape and pipe thread compound on each set of threads. He said it was his best option to avoid leaks. So you might try both tape and pipe thread compound if you don't have an option for a different type of pipe thread compound. Just a suggestion.
LJZ
Rochester NY
Everyone should have a tube of loctite 567. I know that does not help you now but do yourself a favor and grab one for future use. Good luck bruddah.
PFSard
Mesa, AZ
After seeing the experience you've had with Ace products, I'll be rushing down there to buy a few things. LOL
And I wouldn't use that liquid ****. I have an aversion to doing a job more than once. Good luck with the Oatey.
toyotadriver
I always put teflon tape on the threads first and then put pipe dope on top...usually Rectorseal but have also used the Oatley. I've never had a leak when I have used both. I have had leaks with just one or the other.
73eldo
Lamar Arkansas
I have used them all and nothing comes close to Loctite 545 Hydraulic/Pneumatic Thread Sealent
N
NUTTSGT
I've been less and less impressed with ACE Hardware. They were expensive before and since they got sold 2 years ago, I believe the prices went up again. The previous owner had an awesome drill bit selection, now. . .. :mad:
I can either make the 15 mile round trip to town (other side of town) and hope they have it or just make the trip to HD, Lowe's or Menard's and I know one of them will have what I need.
N
NUTTSGT
Yeah, it's small piping, 1/2" black iron pipe.
I have nothing against the Rectorseal but I had good luck with the Oatey in the past. I just thought I had a can when I started getting stuff for the airline addition but couldn't find it with the rest of my plumbing stuff. I was going to start the airline last week but got side tracked. . . much like today.
Spring and tab came out of the 10" pipe wrench and spent 20 minutes trying to put it back together. Realized it has a limited lifetime warranty so it's going back.
Then the pipe sealant as I got progress going again. . .. . created thread. . .
Stopped at DQ to grab a burger and Blizzard for supper on way home. They totally screwed up the order. . . in front of me, mine and the one behind me. I left hangry. Some days, you have plans and they just don't pan out. I know there's an OT slot tomorrow and it shouldn't get to me but. . . .
rangerfredbob
Oregon
The Loctite stuff is fantabulous, a little dab will do ya, most people use too much, about 3 dabs on the second thread for 1/4" pipe, probably 4 for 3/8" and so forth is all ya need
Firebrick43
West central Indiana
I agree on ace. Really down hill in the past year or two. The other day I picked up some JD green paint. No where close to being correct.
Retroman
Mojave Desert
I prefer Blue Monster thread sealant. When I was in the field I cored thousands of holes for sprinkler fitters it was always pipe dope then Teflon tape.
Jeepster04
Anyone know the actual purpose of teflon tape or sealant on NPT threads? Is it just a lubricant or does it actually help seal the threads?
rlitman
Long Island
Both. The teflon lubricates the fit so that it can be fully tightened, and much of the rest of the material packs the helical leak path formed by NPT threads.
