thread size / pitch for porta power rams ?
The Cobbler
Does any one know off hand if porta power threads are common place? I'm talking the ram threads for accessories, not the hydraulic lines .
I have the chain hooks both male & female but hoping to fab up a special puller "tang" for a job. That's if it can be done fairly easily . I have not measured anything yet, I have to dig for the stuff in my shop. I think the diameter is about 1-1/2" on the puller ram male threads . not sure of the pitch . This is a Chinesium set.
Just curious if any one knows ?
Tks
I think mine are common pipe threads, cuz there was a pipe ****** in the box, but a much thinner wall it seemed. Been a few months since the box has been open. Mine is a real Porta Power, 4t version.
Firebrick43
West central Indiana
Tks
are you talking about the collar threads which are on the outside of the cylinder? Most of those of 10 ton and under cylinders are 2-1/4-14
Some of the smaller cylinders that are hollow and threaded called "plunger threads" are 5/8-18 threads to match puller threads when that is most common in 5- 10 ton pullers and slide hammers have. These are actually not that common in the gist of porta power cylinders.
T
The Cobbler
no, not the external threads to install a foot on to, the pull ram has male and female threads on it to thread on chain hooks .
I have it in my hands now and it seems like 1-1/4 running pipe threads from what I can see
Firebrick43
OK, I am going to assume your talking about the universal maintenance style set cylinders instead of the sized lifting cylinders and pulling cylinders.
5 tons use 1-1/4 x 11.5 NPT
2 tons use 3/4 x 14 NPT
12 tons use 2 x 11.5 NPT
Firebrick43
:dunno:
I Checked in my enerpac and OTC porta power catalogs.
Those are the power houses in the industry with simplex pulling up third place. I think OTC was the first to market such portable hydraulic hand pump rams.
If the Chinese made a bad copy of the threads or used something else entirely ?????
T
The Cobbler
the threads look good. but they are not tapered like sealing threads, , rather straight threads such as found on things like lamp pipe & fittings etc.
I did determine its 11.5 tpi and it does thread in to a ( crappy thread) 1.25 pipe coupling I have
Thanks for the info
