Threaded Stem Caster Selection (for QuickJack 5000)
PCMusicGuy
Houston, TX
Hello all. I am going to put some swivel casters on the power unit of my QuickJack 5000 and was wondering if anyone had done it already and can share some recommendations.
I measured the hole size and it is right at 1/4" (~6.36mm) and I cannot seem to find any thread stem casters that don't look like office chair casters.
Example:https://www.amazon.com/Twin-Wheel-Caster-Solutions-TWHN-50N-T03-BK/dp/B00JRYIW14/ref=sr_1_10?ie=UTF8&qid=1544381935&sr=8-10&keywords=threaded+stem+caster
I'm looking for something more along the lines of an industrial caster like this:
https://www.amazon.com/MySit-Casters-Rubber-Shopping-Trolley/dp/B07597TSHK/ref=sr_1_4?ie=UTF8&qid=1544381935&sr=8-4&keywords=threaded+stem+caster
I did find one called the Mighty-Mite made by Shepard, but it seems unavailable. Most of the rest I see are really tall. I only need the unit to be a total of a couple inches off of the ground but most casters will raise it 3+ inches total. I did find one caster that seems lower but the stem size different. https://www.homedepot.com/p/Richelieu-Hardware-1-9-16-in-Light-Grey-Swivel-with-Brake-Threaded-Stem-Caster-77-2-lb-Load-Rating-815110611/301453558
Would it just be better to drill out the hole to 3/8" (M8?) and use some more readily available stem casters?
foilingfool2
I have purchased items from castercity.com before. They might have what you are looking for....
PoorOwner
CA
It doesn’t weight a lot. Any threaded caster will do.
But 3/8 is more common.
I put some shepherd ball bearing on my mechanic chair it is almost too slippery to the point of maybe dangerous. It rolled like a skateboard
Lynden
Southern California
1. Enlarging the holes to 3/8" is probably the easiest solution.
2. You could drill additional holes and use plate casters.
3. You could bolt a piece of 3/4" plywood (or 1/4" aluminum plate) to the bottom of the unit and use plate casters. The plywood could be oversized if you want to make the unit more stable.
https://www.amazon.com/dp/B071GTK6NZ/?tag=atomicindus08-20
https://www.amazon.com/dp/B06Y4GLGHC/?tag=atomicindus08-20
csp
Franktown, CO
Harbor Freight 2" diameter casters have an 8mm (approx. 1/4") threaded stem.
Rated at 150 pounds each
delman1012
I found these threaded casters on Amazon.
“Norgail 1 Inch Small Tiny Shopping Cart Wheel Trolley Swivel Caster Wheels Soft Rubber TPE M6x 15mm Mini Threaded Stem Caster Wheel, 44lb/20kg Load Capacity, Set of 4”
They worked perfect with the existing holes on the Quickjack power unit in place of the little rubber feet that came with the Quickjack. I used M6 lock nuts to secure the casters.
Dustball
Hudson, WI
Could you rob the casters off of snowmobile dollies?
Edit- old thread. I'm sure it's been completed by now.
