Through wall AC unit, mount high or low?
Strouty
Southern Maine
I have 12'6" walls and I just bought a 28k BTU AC unit that will be mounted through the wall. Yes it is designed for this purpose.
Would you mount it higher or lower? It was a wireless remote so I can control it without having to reach it.
Strouty
Southern Maine
That is what my thoughts were, but I was not sure if there was something I was missing. I guess more like over thinking it.
Mike007
Mount it as high as you plan on working in the space. No sense in cooling at the ceiling if you only plan to work at ground level.
sublime68charger
SW Wisconsin
I'd go higher but only so that it's still in easy reach,
That way if you loose or break the remote you can still turn ac unit on/off.
Or "drives" would say put it up high and then you have a built in workout routine going up down the ladder!
Slowgsr
Southern ontario
Care to share which unit you picked up? I've been interested in something like this for awhile but can never pull the trigger on anything specific
LS6 Tommy
Northern NJ
It says window, but it will work in 10" thick walls as well. I downloaded the manual and went through it before ordering. I bought it yesterday with a 30% off coupon, so it only cost me $532.64
http://www.zoro.com/frigidaire-window-ac-28k-btu-208230v-ffra29222/i/G5352532/
Those are good machines. You also got a VERY good price. That was the standard 28k unit for me in my last school district. They guarantee a replacement unit of the same model line will fit in the original slide-out chassis for something like 10 years.
IDK if it's an issue for you or not, but they are made in China.
Tommy
Slowgsr
Southern ontario
BadgerBoilerMN
Minneapolis
If you don't have significant internal gains i.e. lights, people, machines and the unit is not sized properly you may not get the drying effect you seek.
Strouty
Southern Maine
I installed it last night, it is very quiet and works very well. It seems to be drying things well, I will have to test it more to be sure.
It does come with the sleeve and the coupon codes are available from time to time. Sign up for emails at www.zoro.com (they are not always the best price, but I always check) and the thread on the forum is another place to look. For today Tuesday August 18th, 2015 they are offering 20% off $200 or more.
http://www.garagejournal.com/forum/showthread.php?t=274166
Trey T
Houston, TX
If you look at maintenance perspective, I suggest mounting it high (8-10ft). There will always be dust produced from your work and the higher your AC filter is, the less likely the dust will airborne as high; the result will less likely of cloging your filter in short period of time.
